Northern Virginia Roll Call
Discussion in 'Virginia' started by r6hokie, Nov 17, 2011.
  1. May 7, 2018 at 8:11 PM
    chiefcrunchy
    chiefcrunchy Well-Known Member
    Brian
    Between North and South Virginia
    '15 DC MGM TRD Sport 4x4 6spd 4.0
    5100s, 885s, deaver AAL, Waiting impatiently to install Demello front bumper, Mobtown sliders & skids, and safari snorkel.
    I didnt realize he was there at first, the tree was between us and i couldnt see him until i got closer and the dog started going bonkers. I was only 12 ft away:eek:
  2. May 8, 2018 at 3:35 AM
    standard
    standard Well-Known Member
    David
    Delaware
    2003 Tacoma Double Cab
    Morning gents...
    Man, had the weirdest dream last night. The Caps beat the Penguins in the 2nd round to... adv...
    WTF? Not a dream?!?
    CAPS LOCK ENGAGED!
  3. May 8, 2018 at 3:55 AM
    CaliDevilDoc
    CaliDevilDoc Well-Known Member
    San Diego, CA
    2016 Barcelona Red TRD Off-Road 4x4. 1995 FZJ80
    OME nitrochargers, 886, and Dakars
    Flagpole knobb? Any other ideas?
  4. May 8, 2018 at 4:00 AM
    113tac
    113tac Well-Known Member
    Stephen
    Northern Virginia
    2017 Magnetic Gray Tacoma
    Mostly Stock for now, 265 75 16 Falken AT3W, Tinted fronts...
    I’d probably be down. I’m stock with sliders and skids so should be fine at flagpole, I think haha
    CaliDevilDoc[QUOTED] and Cody23 like this.
  5. May 8, 2018 at 4:04 AM
    chiefcrunchy
    Brian
    Mornin fellas
  6. May 8, 2018 at 4:33 AM
    IPNPULZ
    IPNPULZ Well-Known Member
    Deeper in the South…….
    2023 TRD Off Road Premium 4R
    going to be fun!
    I bet you never asked her to try waffles and peanut butter again.....:D
  7. May 8, 2018 at 4:43 AM
    ilubtimmyhos
    ilubtimmyhos Brewer
    Adam
    Haymarket, VA
    2012 Blue Tacoma 4x4 Pre-Runner
    4x4 Conversion w/ FJ T-Case, King 2.5 Extended Travel Coilovers w/ JBA UCAs, King 12" 2.0 Smoothies w/ BAMF relocate in the rear, OME Dakar leaf pack, 4.56 gears w/ ARB air locker, Archive Hammer Hangers w/ crossbar brace, ARB Snorkel, Custom Bed cap w/ Roofnest Sparrow XL, Retrofit Headlights, Wrapped in 3M Satin Perfect Blue
    Morning y'all
  8. May 8, 2018 at 4:53 AM
    Truggin
    Truggin What a long, strange trip it's been
    Don
    39.15737720308645, -77.92212986904099
    Black 2016 TRD Sport V6 4x4 Access Cab
    It's a work in progress. See my build thread.
    No but he did invite her to have breakfast!
    :D
    LocoLocal likes this.
  9. May 8, 2018 at 4:57 AM
    TacoCat
    TacoCat These pretzels are making me thirsty
    Johnny-5
    Chantilly, VA
    25 Crosstrek Premium CVT (first ever automatic!)
    I think I wouldve needed a fresh pair of drawers.
    chiefcrunchy[QUOTED] likes this.
  10. May 8, 2018 at 5:28 AM
    BTHawk
    BTHawk OFP
    Will
    Warrenton, VA
    2025 J250 LC Prado
    Morning... :pccoffee:
  11. May 8, 2018 at 6:06 AM
    BTHawk
    BTHawk OFP
    Will
    Warrenton, VA
    2025 J250 LC Prado
    So, I believe my driveline vibration is gone after the shim install; I now just have a slight and constant vibration in the steering wheel throughout all speeds that I am attributing to running the E-rated St Maxx tires. It is not a pulsating or harmonic vibration and it doesn't go away when I shift in to neutral, so my gut tells me its just the tires. All this is good news for me, but putting the shim in raised the rear end even more and accentuated the Detroit lean. I'm considering possibly removing one of the leafs from the Dakars, basically turning them into the "medium" packs, but I will have to think for a bit on that one.
    One other issue I have noted is with the front of the truck. I drive Joplin Rd every day for my commute, and the road has several little rises in the road that ascend and descend quickly; almost like a tall whoop or the little hills that make your stomach feel like you are on a roller coaster (lousy descriptions, but the best I can do). Anyway, when I crest these rises, the front of the truck bounces or rebounds a couple of times. I believe that this is because I am running the 886 coils up front with no weight on the front end (yet). Anyone have any ideas or theories on this one? I'm considering swapping out the front coils for 888s until I can afford to add significant weight up front.
    At any rate, thanks for all of the suggestions on the shims and thanks in advance if you have a thought on the front coils.
  12. May 8, 2018 at 6:07 AM
    Cody23
    Cody23 Well-Known Member
    Cody
    probably hunting or camping
    2022 TRDOR 6MT
    6112/5160 SCS 285s GFC
    Morning gents
  13. May 8, 2018 at 7:25 AM
    3pooches
    3pooches Well-Known Member
    VA & WV
    15 tacoma dcsb Sc Linked, 2014 reg cab locked
    Your leafs will settle a bit but if you aren’t carrying much weight in the rear, removing a leaf will make for a less harsh ride. I think you are right about the bouncing. The shocks can’t dampen the over sprung coils. 886’s usually lift the front a lot if you don’t have any weight there how much higher is your rear sitting than your front?
    ready6delta and 113tac like this.
  14. May 8, 2018 at 7:51 AM
    BTHawk
    BTHawk OFP
    Will
    Warrenton, VA
    2025 J250 LC Prado
    I don't mind the harsher ride, just the increased height difference. I need to re-measure tonight, but I think the rear is ~1.5 inches higher than the front. The 888s are a bit higher than the 886s and have the correct spring rate for not running any weight. That is why I am leaning that way. The local off-road shop in Warrenton quoted me $80 to swap both coils for me (bringing the coils/struts into them off of the truck).
    ready6delta likes this.
  15. May 8, 2018 at 8:57 AM
    LocoLocal
    LocoLocal Aspiring Polymath
    39.081221472127545, -77.45538862919935
    Large American
    So is the plan to wheel Saturday? Or are we meeting for drinks/eats?
    CaliDevilDoc likes this.
  16. May 8, 2018 at 9:22 AM
    113tac
    Stephen
    Northern Virginia
    I’d like to go wheeling somewhere but I’m also down for drinks if people prefer to do that
    3pooches and CaliDevilDoc like this.
  17. May 8, 2018 at 9:31 AM
    ilubtimmyhos
    ilubtimmyhos Brewer
    Adam
    Haymarket, VA
    Keep me looped in.
    113tac[QUOTED] likes this.
  18. May 8, 2018 at 9:35 AM
    CaliDevilDoc
    San Diego, CA
    Preliminary plan is flagpole knobb saturday, we can drink and eat after. Maybe wheel from morning till early afternoon and then relax/split off after that.
    113tac and 3pooches like this.
  19. May 8, 2018 at 9:42 AM
    2016Taco4Me
    2016Taco4Me Well-Known Member
    NOVA
    2016 Tacoma TRD OR DCSB AT SuperWhite
    Billstein 5100's Wheelers 2" AAL BFG KO2 295/75/16 on FJ Trail Wheels Tires and stock wheels sold 03Jan21 Toytek 1" Lift Block WT Floor Liners and Vents HID Headlight Upgrade Redline Hood Struts White Knuckle Sliders MESO Ultimate Turn Signals MESO Dome and Map Lights MESO Chrome Delete Interior Mobtown Front and Mid Skids - awaiting transfer case skid (08Jan21) Warn Rear Bumper (08Jun20) Tailgate Pop and Lock - Install TBD Mobtown Low Profile Front Bumper - Installed by @ilubtimmyhos SPC UCAs - Installed by Adam @ilubtimmyhos OME 888 front coils - Installed by Adam @ilubtimmyhos Smittybilt XRC Gen 3 Winch Synthetic - Installed by Adam @ilubtimmyhos Overland Equipped Power Auxiliary Box with Blue Sea Systems ST Blade Fuse Block Installed by Adam @ilubtimmyhos Nitto Ridge Grappler 285/75/16 - Installed Oct 2020 Awaiting DS Grab Handle Mod arrival from KTJO 4X4 - Installed 05Jan21 after much asspain! Inner fender mud guard upgrade. LCA replacement - All work done by Justin: @TacoFMS
    ...19 years I hear it's been since they last made it to the third round. Congrats on finally solving the Pens and getting to the third round. Good luck with Tampa. See ya next year!
  20. May 8, 2018 at 9:43 AM
    3pooches
    VA & WV
    I might be in. I’ll know closer to Friday
    CaliDevilDoc[QUOTED] likes this.
