Northern Virginia Roll Call
Discussion in 'Virginia' started by r6hokie, Nov 17, 2011.
  1. Jul 16, 2018 at 6:31 AM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    Definitely euro-sounding but will still make people shit themselves. :thumbsup: :crapstorm:
  2. Jul 16, 2018 at 6:32 AM
    boogie3478
    14 TRD Off-Road V6
    All the mods
  3. Jul 16, 2018 at 6:34 AM
    Large BajaBlast
    Large BajaBlast Squatchin Snorlax
    James
    Virginia
    17 Silver TRD OR DCLB
    SSO Slimline, MBRP OC Rear Bumper, Cooper AT/3 LT , Smittybilt x20 winch, Bilstein 5100s all around, OME 888s, TRD Pro Grille, Softopper
    @EatSleepTacos so the relay that comes with the kit is enough for those right? I shouldnt need to buy that recommended relay kit?
  4. Jul 16, 2018 at 6:36 AM
    GoGoGadget
    GoGoGadget Well-Known Member
    2017 DCLB OR
    It is a 12 step program. In most programs, step 1 is to admit you have a problem. In my 12 step program, step 1 is to admit that you probably are not going to get laid regardless of what you do and accept that. Once you can do that, the rest is easy.
  5. Jul 16, 2018 at 6:36 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Yeah the relay it comes with will be fine. But then you’ll need wiring and connectors and stuff. I have all the stuff needed if you wanna do it here.
    boogie3478 likes this.
  6. Jul 16, 2018 at 6:37 AM
    Rome604
    Rome604 I am the Captain now
    Dave
    Alexandria, VA
    2023 TRD Pro Sequoia
    You could do what I did and keep the stock horns but add a relay and install both the Supertones and the Sharptones......All of those different pitches make the truck sound like it has a train horn. I'm a fan.
  7. Jul 16, 2018 at 6:37 AM
    Large BajaBlast
    James
    Virginia
    Sounds good to me unless the #RandyFab Mobile Bus is operational by then! I really gotta get that damn alignment done on wednesday when im off.
    EatSleepTacos[QUOTED] likes this.
  8. Jul 16, 2018 at 6:38 AM
    GoGoGadget
    2017 DCLB OR
    Do any of those pull enough amps more than OEM to even need different wiring or relays? Seems it should be a straight swap.
  9. Jul 16, 2018 at 6:38 AM
    boogie3478
    14 TRD Off-Road V6
    All the mods
    Hmm I like it! Can't remember if I tossed my stock horns though.
  10. Jul 16, 2018 at 6:41 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Yeah I have a similar set up on my Subaru. I have two pairs of the sharp tones and they’re nice and loud.
    I’ll habe to double check the spec sheet, but the supertones are close to the limit if not over. They draw a lot of power.
    On my old Scion I installed with stock wiring, and then wired in a relay and it was a night and day difference. It may be different on a Tacoma though since the circuit may be able to handle more
  11. Jul 16, 2018 at 6:44 AM
    Rome604
    Dave
    Alexandria, VA
    The Sharptones are fine to swap out with the OEM horns, they are a little lower pitch than the Supertones and have a much lower amp draw. The Supertones are suppose to be around 7amps a piece so you could blow a fuse on the OEM circuit....
    Edit: The interwebs say 5.5Amps for the Supertones
  12. Jul 16, 2018 at 6:45 AM
    LocoLocal
    LocoLocal Aspiring Polymath
    39.081221472127545, -77.45538862919935
    Large American
    Now that I have my rears figured out, thanks to @Darkgoatracer (too easy, again, I know, please @Superman910 and @Cody23 don't go too overbaord with this, we want @IPNPULZ to come back to the thread eventually), I am looking for 5100s for the front and some 884s. Let me know if you all come across a good deal or have a good used pair you're looking to get rid of. I will be checking ebay and prime today, but doesn't hurt to have some feelers out here.
    ready6delta, 113tac and EatSleepTacos like this.
  13. Jul 16, 2018 at 6:47 AM
    Large BajaBlast
    James
    Virginia
    This is also sounds very appealing.
    EatSleepTacos likes this.
  14. Jul 16, 2018 at 6:50 AM
    Truggin
    Truggin What a long, strange trip it's been
    Don
    39.15737720308645, -77.92212986904099
    Black 2016 TRD Sport V6 4x4 Access Cab
    It's a work in progress. See my build thread.
    Well... I didn't fall off of the 10 ' ladder. AND I got all of my storage units hung. (Man do I hurt - I may be too old for this shit)
  15. Jul 16, 2018 at 6:51 AM
    BTHawk
    BTHawk OFP
    Will
    Warrenton, VA
    2025 J250 LC Prado
    Will have to request later tonight...no FB at work (probably a good thing).
    ready6delta and EatSleepTacos like this.
  16. Jul 16, 2018 at 6:52 AM
    Superman910
    Superman910 Epic Dirty
    Eric
    Northern Virginia
    2009 Tacoma TRD Sport DCLB 4x4
    Stock as Fuck or Not Fucking Stock
    So did he really work on your rear...or just give you a little support...
    ready6delta, 3pooches and 113tac like this.
  17. Jul 16, 2018 at 6:53 AM
    boogie3478
    14 TRD Off-Road V6
    All the mods
  18. Jul 16, 2018 at 6:53 AM
    BTHawk
    BTHawk OFP
    Will
    Warrenton, VA
    2025 J250 LC Prado
    Can't be taught...only learned. :D
    chiefcrunchy and 3pooches like this.
  19. Jul 16, 2018 at 6:56 AM
    BTHawk
    BTHawk OFP
    Will
    Warrenton, VA
    2025 J250 LC Prado
    Looking good! Damn...I need more space so I can build me one of these (said every guy everywhere).
    boogie3478 and Truggin[QUOTED] like this.
  20. Jul 16, 2018 at 6:57 AM
    Truggin
    Don
    Space... The final frontier. This added 128 sq-ft of space for storage of "stuff". Needed when you move from 4000 sq-ft to 1000 sq-ft.
    BTHawk[QUOTED] likes this.
