Northern Virginia Roll Call
Discussion in 'Virginia' started by r6hokie, Nov 17, 2011.
  1. Jul 24, 2018 at 9:35 AM
    113tac
    113tac Well-Known Member
    Stephen
    Northern Virginia
    2017 Magnetic Gray Tacoma
    Mostly Stock for now, 265 75 16 Falken AT3W, Tinted fronts...
    You talking CB or music radio?
    ready6delta likes this.
  2. Jul 24, 2018 at 9:36 AM
    steiner9er
    steiner9er Well-Known Member
    Ethan
    DC area (home), Cincinnati area (school)
    2018 Cement Tacoma off-road
    Prinsu Cabrack ALLPRO bed rack Tepui Kukenam 3 Wrangler Duratrac
    CB. I just want to fit in with everyone else, and not be the loser that can't communicate when we are out, you know
  3. Jul 24, 2018 at 9:38 AM
    113tac
    Stephen
    Northern Virginia
    Haha I just have the cheap midland cb off Amazon, I think it’s like 30 or 40 dollars. I think it’s more important to have your antenna setup dialed. Since I fixed my antenna I haven’t had any CB problems.
    Mine is the midland 1001z
  4. Jul 24, 2018 at 9:40 AM
    steiner9er
    Ethan
    Where did you put your antenna? The back of the bed?
  5. Jul 24, 2018 at 9:41 AM
    ready6delta
    ready6delta REGULAR GUY
    JACOB
    Still in PNW but moved to Boise.
    Black pinstriped 2014 DCSB 4x4
    IT NEVER ENDS..........
    ^ this........
  6. Jul 24, 2018 at 9:41 AM
    ready6delta
    JACOB
    ^ this........
    113tac[QUOTED] likes this.
  7. Jul 24, 2018 at 9:47 AM
    ready6delta
    JACOB
    Yeah back left or right on a mount with wire running into taillight. You can also mount in front where ditch lights mount. Not a fan but it works. 30-50$ CB is fine it is the antennae setup which will make or break you.
    all the stuff for it is listed below in our Amazon list following the thread.
    113tac likes this.
  8. Jul 24, 2018 at 9:47 AM
    113tac
    Stephen
    Northern Virginia
    Yup, back of the bed on the rail. I bought one of the cheap firestik mounts, drilled out the holes to fit a bolt for the Amazon t-slot bolts. I had to use a ground strap to get it grounded for best reception.
    I am using a 4’ firestik with coil, quick disconnect and 18ft coax with k4 stud. You need to cut and solder that cable to length though.
  9. Jul 24, 2018 at 9:50 AM
    steiner9er
    Ethan
    Thanks. I think I am going to mount the antenna on the back inside the bed near the tail light, so I can run the chord through all that good stuff in there
    EatSleepTacos and ready6delta like this.
  10. Jul 24, 2018 at 10:18 AM
    buyobuyo
    buyobuyo Read The Fucking Manual
    Jeremy
    Camden, AR
    08 PreRunner SR5, I4, Manual, Silver
    A thing or two...
    That's a whole lot of vacuum tubes. Where's the punch card reader? :rofl:
    The Cobra 75 is a nice unit. The main unit is small, so you can hide it away. All the controls are through the handset.
  11. Jul 24, 2018 at 10:25 AM
    the.sight.picture
    the.sight.picture Wishes he was in the woods.
    Nick
    Blue Ridge
    2018 QuickSand
    Check out my build thread (Beginning of Money Pit)
    I have my antenna mounted to my Tc bed stiffeners
    ready6delta and 113tac like this.
  12. Jul 24, 2018 at 10:40 AM
    Rome604
    Rome604 I am the Captain now
    Dave
    Alexandria, VA
    2023 TRD Pro Sequoia
    That's kinda what I did.20180521_153801.jpg 20180713_080119.jpg I just made mine able to fold down when not in use.
  13. Jul 24, 2018 at 10:51 AM
    3pooches
    3pooches Well-Known Member
    VA & WV
    15 tacoma dcsb Sc Linked, 2014 reg cab locked
    I like that!
    Rome604[QUOTED] likes this.
  14. Jul 24, 2018 at 10:53 AM
    3pooches
    VA & WV
    So is there a jack point when you have skids, to lift the whole front? do you have to take your skids off?7D223889-B2F6-45D6-B1B9-5B8D7EAA6CEB.jpg
  15. Jul 24, 2018 at 10:55 AM
    steiner9er
    Ethan
    Did you wire it all the way down through the tail light?
  16. Jul 24, 2018 at 10:57 AM
    Rome604
    Dave
    Alexandria, VA
    I drilled a small hole in the bed, removed the passenger cubby to run the wire through the bedside to the grommet under the passenger seat.
  17. Jul 24, 2018 at 10:58 AM
    Truggin
    Truggin What a long, strange trip it's been
    Don
    39.15737720308645, -77.92212986904099
    Black 2016 TRD Sport V6 4x4 Access Cab
    It's a work in progress. See my build thread.
    Punch cards would have been high tech. The program loaded from a long spool (roughly 150 feet) of punched paper tape encoded in Octal.
    buyobuyo[QUOTED] and ready6delta like this.
  18. Jul 24, 2018 at 11:00 AM
    Truggin
    Don
    High-lift on the rock sliders.
    3pooches[QUOTED] likes this.
  19. Jul 24, 2018 at 11:04 AM
    TaKoToy
    TaKoToy Well-Known Member
    Robbie
    Prince George VA
    2013 4x4 OffRoad, 2020 cement DCLB OR
    Mostly stock
    I usually use a 2x4 to spread the load a bit but I have aluminum skids so have to be a little more careful
  20. Jul 24, 2018 at 11:05 AM
    3pooches
    VA & WV
    That lifts one side at a time. I want to lift both front tires at one point.
    the.sight.picture likes this.
