Northern Virginia Roll Call
Discussion in 'Virginia' started by r6hokie, Nov 17, 2011.
  1. Dec 3, 2018 at 11:08 AM
    Comatose
    Comatose You snuff it, we stuff it.
    Miguel
    San Diego, CA
    2008 TRD OR Indy Ink
    Missing Critical Hardware Edition
    @EatSleepTacos
  2. Dec 3, 2018 at 11:08 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    You already have two rails on there, that run front to back?
    ready6delta likes this.
  3. Dec 3, 2018 at 11:09 AM
    RUSSELLTACO
    RUSSELLTACO Well-Known Member
    Blacksburg Va
    silver shitbox
    bolt ons and autozone decals
    they are two seperate sets of towers (sorry old potato pic)
  4. Dec 3, 2018 at 11:14 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Ahhh I gotcha. Then yes I would add the tracks. Helps distribute the weight a bit.
    I have a reinforced roof so I just drilled holes in my roof and bolted the feet right on, but not everyone has that ability.
  5. Dec 3, 2018 at 11:17 AM
    RUSSELLTACO
    Blacksburg Va
    silver shitbox
    is there a way to tell? the towers are just drilled right into the cap right now.
  6. Dec 3, 2018 at 11:19 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Yeah you can tell by looking at the inside of the roof. What do you plan on putting on the prinsu? Anything heavy like an RTT or is it just for the occasional long object?
  7. Dec 3, 2018 at 11:21 AM
    RUSSELLTACO
    Blacksburg Va
    silver shitbox
    ive had my RTT on my bars before and it was fine, the center of my cap kind of drops down
    had no issues and im a bigger guy
  8. Dec 3, 2018 at 11:21 AM
    RUSSELLTACO
    Blacksburg Va
    silver shitbox
  9. Dec 3, 2018 at 11:25 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Personally I’d spring for the tracks then. Sucks as it’s a little pricier but it’ll be done right as they’ll help distribute the load better.
    There are cheaper options though. Start here and read down.
    https://www.tacomaworld.com/threads/subway4x3-shameless-copycat-build.459570/page-58#post-17294597
  10. Dec 3, 2018 at 11:29 AM
    ready6delta
    ready6delta REGULAR GUY
    JACOB
    Still in PNW but moved to Boise.
    Black pinstriped 2014 DCSB 4x4
    IT NEVER ENDS..........
    Yeah i would Recommend the tracks and at least 6 mounting feet for a RTT. I used The Yakima tracks but Thule makes some
    As well. 54 in length for tracks. Make sure you drill outside of honey comb for bolts through tracks. And order extra A anchors unless your rack came with them.
  11. Dec 3, 2018 at 11:29 AM
    RUSSELLTACO
    Blacksburg Va
    silver shitbox
    thank you!
  12. Dec 3, 2018 at 11:31 AM
    RUSSELLTACO
    Blacksburg Va
    silver shitbox
    im buying off a guy who is getting an alucab, so i dont have the rack in my possesion just yet but for a little under half of what it costs new im not gonna let it slide. Just wanted to see what all is going to be required to install it.
    thanks for the quick help guys!
    ready6delta[QUOTED] likes this.
  13. Dec 3, 2018 at 11:31 AM
    SportsmanJake
    SportsmanJake Well-Known Member
    VA
    2006 Tundra
    I just purchased Rhino Rack tracks because they were cheaper than the thule/yakima models. I have not used them yet, but when I compared them to my old Yakima tracks, the quality appeared to be the same.
  14. Dec 3, 2018 at 11:32 AM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    Id check out Yakima spare parts tracks (if you have Yakima feet) or equivalent. The "spare parts" are usually cheaper than a new kit.
    not sure if this is what youre looking for..
    https://www.amazon.com/Yakima-Contr..._rd_t=40701&psc=1&refRID=W2AQ148SW9ZVCBV6WFDH
    RUSSELLTACO likes this.
  15. Dec 3, 2018 at 11:32 AM
    RUSSELLTACO
    Blacksburg Va
    silver shitbox
    should i just mark on the track where the pre exsisting holes are and drill through for another tie down spot?
  16. Dec 3, 2018 at 11:33 AM
    RUSSELLTACO
    Blacksburg Va
    silver shitbox
    i currently have thule feet not sure if it would matter but yeah that style of track.
  17. Dec 3, 2018 at 11:35 AM
    fatfurious2
    David
    Ashburn, VA
    look for Thule replacement parts. Im sure they are out there
  18. Dec 3, 2018 at 11:36 AM
    BTHawk
    BTHawk OFP
    Will
    Warrenton, VA
    2025 J250 LC Prado
    @Cody23 X2 and who makes it? Also, aren't there different bolts required to fit the 3rd gen? I could have sworn I read somewhere that the main difference from 2nd to 3rd Gen was bolts. I'll see if I can find it.
    Halffast555[QUOTED] likes this.
  19. Dec 3, 2018 at 11:37 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    What you have now doesn’t matter, you just need some tracks. Check out the thread I linked you to for off brand tracks. You can get fully set up for less than $200. Then the prinsu feet will bolt directly to the tracks with the supplied prinsu hardware.
  20. Dec 3, 2018 at 11:44 AM
    RUSSELLTACO
    Blacksburg Va
    silver shitbox
    just grabbed 2 thanks again!
