Northern Virginia Roll Call
Discussion in 'Virginia' started by r6hokie, Nov 17, 2011.
  1. Dec 6, 2018 at 4:26 PM
    IPNPULZ
    IPNPULZ Well-Known Member
    Deeper in the South…….
    2023 TRD Off Road Premium 4R
    going to be fun!
    I only drove a few miles home from the tire shop but these things are tight and stick to the road
    Casper66 likes this.
  2. Dec 6, 2018 at 4:26 PM
    IPNPULZ
    going to be fun!
    LMFAO
    Casper66[QUOTED] likes this.
  3. Dec 6, 2018 at 4:28 PM
    IPNPULZ
    going to be fun!
    Those Wrangler Kevlar OEM tires sucked bad I have hated them ever since I bought the Truck two years ago.....
    ready6delta and ovrlndkull like this.
  4. Dec 6, 2018 at 4:38 PM
    Rome604
    Rome604 I am the Captain now
    Dave
    Alexandria, VA
    2023 TRD Pro Sequoia
    Does it vibrate in 4hi?
    ready6delta likes this.
  5. Dec 6, 2018 at 4:39 PM
    Demo man
    Demo man Well-Known Member
    Dave
    Fredericksburg, Va
    2020 OR
    No idea. Haven’t tried that. It did t vibrate any where near this bad with the old CB in.
  6. Dec 6, 2018 at 4:42 PM
    Rome604
    Dave
    Alexandria, VA
    If you're sure you put everything back right I'm just curious if the cb was your problem to begin with. That's why I asked.
  7. Dec 6, 2018 at 4:46 PM
    Demo man
    Dave
    Fredericksburg, Va
    2020 OR
    It was. Squeaking in reverse and the bearing was anything but round not to mention the amount of play it had. I should mention my mechanic is the one doing all this but I watched lol
    Rome604[QUOTED] likes this.
  8. Dec 6, 2018 at 4:48 PM
    Rome604
    Dave
    Alexandria, VA
    Do you have a lift? Maybe the play in your cb was making it so you didn't need a cb drop kit or rear axle shims Just throwing out ideas .
    3pooches likes this.
  9. Dec 6, 2018 at 4:50 PM
    Demo man
    Dave
    Fredericksburg, Va
    2020 OR
    Icon Stage 3.
  10. Dec 6, 2018 at 4:52 PM
    Demo man
    Dave
    Fredericksburg, Va
    2020 OR
    I know there is a TSB on the driveshaft they extended to 2013 models. But being I have 113k and a lift they won’t touch it.
  11. Dec 6, 2018 at 4:52 PM
    ovrlndkull
    ovrlndkull STUKASFK - HC4LIFE
    Skip
    Burlington, NC
    2005 DCLB Silver
    63s, XD Machete, Beat not Babied
    Does he have the driveshaft sync. properly. What I mean by this is are all the U-joints lined up on the same plane yes even the one at the t-case. if on is off plane or 180* from the others can cause a vibration.
    Comatose and Rome604 like this.
  12. Dec 6, 2018 at 4:54 PM
    Demo man
    Dave
    Fredericksburg, Va
    2020 OR
    You mean from the front all the way back. Including front driveshaft?
  13. Dec 6, 2018 at 4:56 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Was gonna say the same. Basically the middle u joint has to go back on the same exact spline it came off of so the u joints are lined up.
  14. Dec 6, 2018 at 4:57 PM
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    Yes. every U-joint the caps should be in line with eachother. If one is off it can cause a vibration. Also they can be 180 out so if they are all inline then try taking the back one off and rotating it 180 to the front one.
  15. Dec 6, 2018 at 4:58 PM
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    If you want to mess with someone take the shaft off the diff pull apart the slip yoke and turn it 180 it'll have them chasing a vibration until they go to the looney bin.
  16. Dec 6, 2018 at 5:02 PM
    Demo man
    Dave
    Fredericksburg, Va
    2020 OR
    I know he marked everything and it lined up. But I called him(good friend who just happens to own his own shop) and he said he’s going to check that the CB is centered.
    EatSleepTacos[QUOTED] likes this.
  17. Dec 6, 2018 at 5:08 PM
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    o_O As soon as you put the DS through it and it has it's weight hanging down from it the bearing won't be exactly centered. What does he mean by that?
    As a tech we all make mistakes I've done this one before. The DS came apart at the slip yoke and I hastily put it back together not paying any attention. The customer returned not 5 min after leaving for vibes because the DS was out of sync. Doesn't hurt to double or triple check things to make sure.
    Rome604 likes this.
  18. Dec 6, 2018 at 5:11 PM
    Demo man
    Dave
    Fredericksburg, Va
    2020 OR
    Lmao. Brother I’m just the guy who has a guy to do the work. But in all seriousness. I did return probably 3 minutes later and he crawled under the truck. Looked and said he’s going to order a new bearing just in case but to come by tomorrow. He just closed the gates so I wasn’t going to complain. Since I do t pay for any work but the parts. Sooooooo
    ovrlndkull[QUOTED] and 113tac like this.
  19. Dec 6, 2018 at 5:49 PM
    PyritePirateBill
    PyritePirateBill Well-Known Member
    Bill
    North Myrtle Beach, SC
    2014 pyrite mica TRD Sport 4x4 AC
    OME 886 Nitrocharger lift, Dakar HD leaf pack, u-bolt flip kit, Bilstein b110 rear shocks, Wheeler's super bumps,18x9 Worx Havoc, 35/12.50/18 Nitto Ridge Grapplers, ENVE Grille with LED lightbar & raptor leds, ditch lights, 6k hid, tinted tails, AtTheHelm bed stiffeners, SOS Concepts rear bumper, Demello baja front bumper, Smittybuilt 9.5k winch, Mobtown weld-on sliders, AllPro IFS & transm. skid, Mobtown transfer case skid, led fogs, led lights in rear bumper, 54" Bulldog hi-lift jack, Razorback shovel & axe on Quickfist mounts, Cobra CB w/Firestik antenna, Yellow wire mod for 4Lo, URD y-pipe, 2.5" custom exhaust w/ Borla muffler, Viair portable air compressor, Kryptek Typhon seat covers, AJT dash knobs
    Worked on mine...maybe you shouldn't have put the fumotovalve on it:rofl:
  20. Dec 7, 2018 at 2:01 AM
    the.sight.picture
    the.sight.picture Wishes he was in the woods.
    Nick
    Blue Ridge
    2018 QuickSand
    Check out my build thread (Beginning of Money Pit)
    the system exist for a reason, and if your supervisor is not a physician then he/she can eat ass. That is 30 percent why soldiers get hurt worse.
    the other 40 percent is alcohol and stupidity, followed by 30 percent lod
    ready6delta and Casper66 like this.
