Northern Virginia Roll Call
Discussion in 'Virginia' started by r6hokie, Nov 17, 2011.
  1. Jan 19, 2019 at 9:05 AM
    Hafaday
    Hafaday Well-Known Member
    Bill
    Richmond, VA.
    19, DCSB, Off Road. 23 KLX300, 14JKU
    Good meeting ya.
  2. Jan 19, 2019 at 9:12 AM
    Hafaday
    Bill
    Richmond, VA.
    :thumbsup:
    I started out in the woodland cammies in 89. then thru several changes. Finished out with the digi ACU's.
    ready6delta likes this.
  3. Jan 19, 2019 at 9:59 AM
    BTHawk
    BTHawk OFP
    Will
    Warrenton, VA
    2025 J250 LC Prado
    Welcome back!
    Halffast555[QUOTED] likes this.
  4. Jan 19, 2019 at 10:00 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Had a couple people ask me about mounting the Plano so I thought I’d share this in here as well.
    How to mount a Plano on a prinsu
    Materials needed:
    1/4”x1” carriage bolts
    1/4”x1.5” washers
    1/4”-20 nylock nuts
    7/16” socket/wrench
    Drill w/ 3/16” drill bit
    Something to mark where to drill
    T30 bit
    Optional:
    Silicone
    Hacksaw
    Set Plano on prinsu and mark where you want to drill. Just gonna have to eyeball this part
    Drill your holes
    Unbolt one side of crossbar using the T30 bit and set carriage bolts in rails
    Loosely place Plano on bolts, and start the nuts but don’t tighten yet
    Squeeze some silicone under the washer
    Tighten down nuts, add silicone if needed, and trim excess off bolts.
    quis23, Hafaday, chiefcrunchy and 9 others like this.
  5. Jan 19, 2019 at 10:23 AM
    LocoLocal
    LocoLocal Aspiring Polymath
    39.081221472127545, -77.45538862919935
    Large American
    You as well. @m3zy6 too.
    Hafaday did you make it out of there without too much damage? I just got ammo and a shirt.
    chiefcrunchy and buyobuyo like this.
  6. Jan 19, 2019 at 11:30 AM
    Large BajaBlast
    Large BajaBlast Squatchin Snorlax
    James
    Virginia
    17 Silver TRD OR DCLB
    SSO Slimline, MBRP OC Rear Bumper, Cooper AT/3 LT , Smittybilt x20 winch, Bilstein 5100s all around, OME 888s, TRD Pro Grille, Softopper
    I hope you have a cutout for a potato gun too, or a rocket launcher.
  7. Jan 19, 2019 at 11:32 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    That tube disguised as a driveshaft is actually a mortar tube.
  8. Jan 19, 2019 at 11:34 AM
    Large BajaBlast
    James
    Virginia
    excellent we will need to test that soon!
    EatSleepTacos[QUOTED] likes this.
  9. Jan 19, 2019 at 12:12 PM
    PyritePirateBill
    PyritePirateBill Well-Known Member
    Bill
    North Myrtle Beach, SC
    2014 pyrite mica TRD Sport 4x4 AC
    OME 886 Nitrocharger lift, Dakar HD leaf pack, u-bolt flip kit, Bilstein b110 rear shocks, Wheeler's super bumps,18x9 Worx Havoc, 35/12.50/18 Nitto Ridge Grapplers, ENVE Grille with LED lightbar & raptor leds, ditch lights, 6k hid, tinted tails, AtTheHelm bed stiffeners, SOS Concepts rear bumper, Demello baja front bumper, Smittybuilt 9.5k winch, Mobtown weld-on sliders, AllPro IFS & transm. skid, Mobtown transfer case skid, led fogs, led lights in rear bumper, 54" Bulldog hi-lift jack, Razorback shovel & axe on Quickfist mounts, Cobra CB w/Firestik antenna, Yellow wire mod for 4Lo, URD y-pipe, 2.5" custom exhaust w/ Borla muffler, Viair portable air compressor, Kryptek Typhon seat covers, AJT dash knobs
    Nice setup! But I don't have a roof rack on my access cab...and I'm not drilling holes in the roof to have one. Also, I'm too old for retrieving heavy objects from the roof.
    I think what I am going to do is get the 52" Pelican case, which is built a bit thicker and stronger. I'm considering mounting it in place of the back seat bottoms so that it'll flip up and I'll still have access to the cubbyholes in the rear floor. The 52" model will fit perfectly between the rear doors.
    What do you think? I'll of course have to make the brackets to make it work with the seat hinges. And the case will be strong enough to be used as a seat base still, if needed.
    Edit: It seems I may need to research this further...
    The case I was referring to is actually 56" long(outside dimensions). So I need to remeasure the rear seating compartment and find one that fits:annoyed::rolleyes:
  10. Jan 19, 2019 at 12:18 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Ooooo, that’s a pretty slick idea. Could put a little padding on the lid too. I haven’t seen anyone do that before so if you did you should document it thoroughly
  11. Jan 19, 2019 at 12:21 PM
    PyritePirateBill
    Bill
    Thanks. I just had to edit the post tho. Lol
  12. Jan 19, 2019 at 12:23 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    well regardless the concept is a good one, and if you made it work i think that’d be really cool if you could find one that fits
  13. Jan 19, 2019 at 12:34 PM
    PyritePirateBill
    Bill
    The V730 is 47"×19"×7".
    The V800 is 56"×19"×6.7".
    So, we'll see. Probably have to go with the V730.
    19" wide may be too wide to fit without hitting the back of the center console
  14. Jan 19, 2019 at 12:38 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    This is 52x17 but it is Plano. Pelican is hands down a better product but this may fit a bit better
    Plano PLA11852 All Weather Case, Doublex 40mm Rifle/Shotgun, Black, 52 https://www.amazon.com/dp/B07B7ZB484/ref=cm_sw_r_cp_api_i_iQ4qCb8CNTCTB
  15. Jan 19, 2019 at 12:48 PM
    PyritePirateBill
    Bill
    Yeah, I looked at them in person at Cabelas. The Plano was a little bit flimsy compared to the Pelican and the Cabelas(Boyt) brands...not really "flimsy", but just not sure about someone sitting on the Plano. The other two brands are made with a different, harder material.
    Just looked online at the Boyt, who makes the Cabelas branded one. It comes in a 55"×18.5"×7".
    Dammit, I'm going out to the truck now to measure again:rofl:
  16. Jan 19, 2019 at 12:58 PM
    PyritePirateBill
    Bill
    Ok. 52" is the max length that will fit. Width won't be an issue up to 20". So pelican may be out of the question. Gotta shop around some more
    the.sight.picture likes this.
  17. Jan 19, 2019 at 1:08 PM
    Demo man
    Demo man Well-Known Member
    Dave
    Fredericksburg, Va
    2020 OR
    Patio chair cushions from Walmart. Problem solved. Lol
  18. Jan 19, 2019 at 1:17 PM
    PyritePirateBill
    Bill
  19. Jan 19, 2019 at 1:31 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Yeah I’ve used pelican cases at work before and they’re hands down a superior product. Extremely stout and I would love to run them, but for what I need I can’t justfiy the price. I hope you can find one that fits in there
  20. Jan 19, 2019 at 1:38 PM
    Demo man
    Dave
    Fredericksburg, Va
    2020 OR
    That driveshaft looks familiar. Lol
