Northern Virginia Roll Call
Discussion in 'Virginia' started by r6hokie, Nov 17, 2011.
  1. Jan 22, 2019 at 12:14 PM
    pabstsmeared
    pabstsmeared Simulated Weight
    Tappahannock, Va
    '13 Super White DCSB TX Baja
    Mud Tars & Shit
    Hey @EatSleepTacos, on the subject of $80... Those B110's, I can run those on stock leaves/progressive AAL's and just not get the full effect right?
    Ultimately I'll do Dakar's, Bumps, and Brake Line's and hopefully wouldn't be installing the B110's until then. However, I read like 7 pages of 5160 horror stories in the Baja thread this morning that have me concerned with how long mine will hold out....
  2. Jan 22, 2019 at 12:16 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    You could, but the only thing that may be an issue is uptravel. You may run out of shock before you hit bump stops, so you'd be bottoming out the shocks and risk blowing some seals or something. On mine I was like 1/3" off so I limited my uptravel by 1". If you were to get some wheelers superbumps then that limits travel enough that you wouldn't risk bottoming out. It's only stock bumps you have to worry about.
    ready6delta and ovrlndkull like this.
  3. Jan 22, 2019 at 12:16 PM
    pabstsmeared
    Tappahannock, Va
    Mud Tars & Shit
    Look at me, progressing from asking annoying truck buying questions to annoying suspension questions. @ovrlndkull predicted this IIRC....
  4. Jan 22, 2019 at 12:18 PM
    pabstsmeared
    Tappahannock, Va
    Mud Tars & Shit
    Got it. Worst case scenario. Once Antarctica takes it's weather back I'm going to take some scotch brite and wd-40 to my 5160's and determine how bad they are.
  5. Jan 22, 2019 at 12:22 PM
    ovrlndkull
    ovrlndkull STUKASFK - HC4LIFE
    Skip
    Burlington, NC
    2005 DCLB Silver
    63s, XD Machete, Beat not Babied
    Shocks are a wear item if you talk to any manufacturer they recc. replacement every 50k miles. Performance shocks are a different story call king, icon, bilstein, etc. They'll tell ya a lot less before a rebuild is needed and that you need to be regularly checking a lot of parts on those shocks like the heim joints and replace as needed.
    :thumbsup:
  6. Jan 22, 2019 at 12:37 PM
    pabstsmeared
    Tappahannock, Va
    Mud Tars & Shit
    The issue I'm reading about with these is corrosion. Bad. The shock and resi body I'm not too worried about, that should be mostly cosmetic surface rust, the banjo fittings that connect the shock to the resi's is what has me worried.
    ovrlndkull[QUOTED] likes this.
  7. Jan 22, 2019 at 12:48 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Here's the reason I'm selling the cage. My current optima 31M took a shit at 14 months. Froze two nights ago, split the case, and that's all she wrote. It's been having issues lately holding a charge, and because it was low on charge made it susceptible to freeze. So I'm taking advantage of the sale @buyobuyo turned me onto, and got an X2 27F, which is the same as northstar.
    50613536_312418276068990_145724564720268_23ecfc728cc73334455f7bbbc77cc31af9b854e1.jpg
    50272063_239706586943704_837692255792372_05334b989fac52ce7f086112e00aa65cb72c6189.jpg
  8. Jan 22, 2019 at 1:12 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Here’s a pic of the cage. Still in excellent condition.
    buyobuyo and EagleUSMCRet like this.
  9. Jan 22, 2019 at 1:58 PM
    alexmb1
    alexmb1 Member
    Virginia
    2010 TRD Sport Double Cab
    Exterior: Fab Fours Rear Bumper N-Fab Nerf Bars Front: Bilstein 5100 (1st setting) Headstrong Off-Road Coil Rear: Headstrong Off-Road Leaf Pack Bilstein 5100 (Ext. Length) Tires: 265/70/17 Falken WildPeak AT3W Interior Pioneer FH-X820BS Image Dynamics x4 (TacoTunes)
    Just to build on this a bit:
    Upgrading your system is quite simple and cheap than what it used to cost 15 years ago. Swapping the head unit for an aftermarket unit will give you a huge improvement. However that really just makes it louder, not better, if you keep the stock speakers. ********* has some options to upgrade the speakers that will add bass and clarity without a sub. While I was doing the install i added the noico sound mats to the inside of the door. That helped reduce noise from the road about 20 percent. The real noise issues are from the back wall and the floor. But that doesn't bother me enough to go threw the effort. If I wanted quiet, I would have bought a Mercedes.
  10. Jan 22, 2019 at 2:08 PM
    pabstsmeared
    Tappahannock, Va
    Mud Tars & Shit
    Right on, thanks man! When it gets to the point of bothering me enough to do something about it, sounds like I can take my time and do it piece by piece. Any time I have things torn apart to the point that I can get sound deadening in, I plan on it.
    I'm with you though on the Mercedes. It's a truck. I'm a truck guy. I've driven a bunch of different 3/4 - 1 ton work trucks over the years. Plus I'm a heavy equipment operator, loud things make me happy. All that said though, this '13 Taco is the newest, nicest thing I've ever personally owned, I want it to be quieter than a bulldozer. :rofl:
    buyobuyo, ready6delta and LocoLocal like this.
  11. Jan 22, 2019 at 2:13 PM
    ilubtimmyhos
    ilubtimmyhos Brewer
    Adam
    Haymarket, VA
    2012 Blue Tacoma 4x4 Pre-Runner
    4x4 Conversion w/ FJ T-Case, King 2.5 Extended Travel Coilovers w/ JBA UCAs, King 12" 2.0 Smoothies w/ BAMF relocate in the rear, OME Dakar leaf pack, 4.56 gears w/ ARB air locker, Archive Hammer Hangers w/ crossbar brace, ARB Snorkel, Custom Bed cap w/ Roofnest Sparrow XL, Retrofit Headlights, Wrapped in 3M Satin Perfect Blue
    Anybody in here hiring? I decided today but I definitely need to make some changes.
    3pooches, HCJ, buyobuyo and 4 others like this.
  12. Jan 22, 2019 at 2:36 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    #RandyFab is hiring!
  13. Jan 22, 2019 at 2:39 PM
    pabstsmeared
    Tappahannock, Va
    Mud Tars & Shit
    I hear they're stingy with company swag though....
    3pooches, BTHawk, TacoCat and 3 others like this.
  14. Jan 22, 2019 at 2:40 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    You’re certainly not wrong :laugh: maybe I should get some t shirts made. But I’m the only one who gets any lol
  15. Jan 22, 2019 at 2:40 PM
    Cody23
    Cody23 Well-Known Member
    Cody
    probably hunting or camping
    2022 TRDOR 6MT
    6112/5160 SCS 285s GFC
    i heard the same..
  16. Jan 22, 2019 at 2:43 PM
    Cody23
    Cody
    2022 TRDOR 6MT
    im also looking for new jobs. got a couple interviews coming up.
    buyobuyo likes this.
  17. Jan 22, 2019 at 3:37 PM
    ready6delta
    ready6delta REGULAR GUY
    JACOB
    Still in PNW but moved to Boise.
    Black pinstriped 2014 DCSB 4x4
    IT NEVER ENDS..........
    Anybody want some used all pro standard leafs?
    pabstsmeared likes this.
  18. Jan 22, 2019 at 3:37 PM
    TacoCat
    TacoCat These pretzels are making me thirsty
    Johnny-5
    Chantilly, VA
    25 Crosstrek Premium CVT (first ever automatic!)
    I just want one who wont withhold my paycheck :laugh:
    Havent been on much lately, any meets coming up? I thought someone mentioned thursdays once a month.
  19. Jan 22, 2019 at 3:45 PM
    pabstsmeared
    Tappahannock, Va
    Mud Tars & Shit
    :drool: Ugh. My wife is going to kill me. I've literally been looking at rear spring options all day. How much use and what are you looking to get out of them?
  20. Jan 22, 2019 at 3:57 PM
    buyobuyo
    buyobuyo Read The Fucking Manual
    Jeremy
    Camden, AR
    08 PreRunner SR5, I4, Manual, Silver
    A thing or two...
    Is it time for a mass TW exit from VA? I got an offer on a position I interviewed for. Running the numbers now to figure out my counter.
    quis23, ready6delta and TacoCat like this.
