Northern Virginia Roll Call
Discussion in 'Virginia' started by r6hokie, Nov 17, 2011.
  1. Feb 20, 2019 at 3:36 PM
    CTtoNoVa
    CTtoNoVa Well-Known Member
    2017 DCSB TRD OR Magnetic Gray
    Pop N Lock
    Blah... was just pulling into a gas station that had the snow plowed into what I later found out was the entrance. So I went to the left of it which was not plowed but had tire marks and seemed like the actual entrance but was a side walk with a 5 inch snow covered curb. Hit it dead on, 90 degrees maybe going 10 mph. Alignment seems fine, tires seem fine. No wobbling, took on highway and suspension seems fine. Made a pretty big thump. Wondering what else I should be looking for? I think I would know if I had a bent tie rod or if the alignment was way off. Seems to drive straight as an arrow. Thoughts?
  2. Feb 20, 2019 at 3:36 PM
    Arcticelf
    Arcticelf Well-Known Member
    Gladiator
    Yes, you need to gear both ends the same.
    Otherwise the front diff will grenade.
    ovrlndkull likes this.
  3. Feb 20, 2019 at 3:37 PM
    Arcticelf
    Gladiator
    You're probably fine.
  4. Feb 20, 2019 at 3:37 PM
    buyobuyo
    buyobuyo Read The Fucking Manual
    Jeremy
    Camden, AR
    08 PreRunner SR5, I4, Manual, Silver
    A thing or two...
    I'm down for a meet up. I could do Th, F, or S.
  5. Feb 20, 2019 at 3:39 PM
    BFRT_King Ranch
    BFRT_King Ranch Well-Known Member
    Northern VA
    '18 Cement TRDOR DCSB
    Thursday I think seems to be the consensus.
    ilubtimmyhos and Rome604 like this.
  6. Feb 20, 2019 at 3:43 PM
    TaKoToy
    TaKoToy Well-Known Member
    Robbie
    Prince George VA
    2013 4x4 OffRoad, 2020 cement DCLB OR
    Mostly stock
    Did mine at ECGS as well they are only a couple hours from me so was a no brainer. I just let them do it so I wouldn't have to fiddle with core fees and shipping.
    Yup he quoted me " manufactured cover" and said if I agreed to drive away with the gloves on he would pass it. They had a state trooper pull a truck they had just inspected with a light bar. The kid of course said it must be legal just passed inspectiono_O
    ready6delta and Rome604 like this.
  7. Feb 20, 2019 at 3:53 PM
    ovrlndkull
    ovrlndkull STUKASFK - HC4LIFE
    Skip
    Burlington, NC
    2005 DCLB Silver
    63s, XD Machete, Beat not Babied
    Yes for 4wd you would technically, but there is an exception which isn't applicable with us.
    You can get a front clamshell pre built from ecgs as well.
    Arcticelf likes this.
  8. Feb 20, 2019 at 4:00 PM
    Halffast555
    Halffast555 Half-Assed
    Jacob
    NOVA
    2012 Tacoma TRD Off-Road
    How much does it usually cost to regear? Also since @TaKoToy bumper sold Im still in the market for a rear bumper with a swing out if anyone knows one floating around
    113tac likes this.
  9. Feb 20, 2019 at 4:05 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Depends. If you're *only* regearing, front and rear, it costs about $1,400 when it's all said and done. Adding lockers is when it starts getting expensive. For reference, an ARB locker for the rear is an additional $850 or so. Another $850 for the front. You get the idea.
    edit: high clearance or standard?
  10. Feb 20, 2019 at 4:06 PM
    BTHawk
    BTHawk OFP
    Will
    Warrenton, VA
    2025 J250 LC Prado
    I would vote Friday, but...
  11. Feb 20, 2019 at 4:06 PM
    buyobuyo
    Jeremy
    Camden, AR
    A thing or two...
    Cost depends on what locker you get. My rear was about $1200 after I returned the core. Just go to their website and price out what you want.
    Halffast555[QUOTED] likes this.
  12. Feb 20, 2019 at 4:06 PM
    Rome604
    Rome604 I am the Captain now
    Dave
    Alexandria, VA
    2023 TRD Pro Sequoia
    Do people actually lock the front? With IFS isn't that a bad idea? Genuine question.
    Halffast555 and ovrlndkull like this.
  13. Feb 20, 2019 at 4:08 PM
    GoGoGadget
    GoGoGadget Well-Known Member
    2017 DCLB OR
    Only if they came with Walmart bags or something similar originally.
    Inspect for and reject if:
    1. Auxiliary lamp is being used for a purpose other than for which it is manufactured or previously approved by the Superintendent.
    2. Auxiliary lamp does not have a clear lens.
    3. Any reflector in such auxiliary lamp device is not clear.
    EXCEPTIONS: Any lighting device that is both covered and unlit shall not be considered for inspection. Fog and driving lamps mounted below the level of the regular headlamps must be checked for aim as outlined in subdivisions I 12 h and I 13 f of this section if not covered.
    NOTE: The covers shall be a type that would be installed as original equipment and not tape, paper bags, aluminum foil or similar materials.
  14. Feb 20, 2019 at 4:08 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    It's not uncommon for people to lock the front. I would like to whenever I regear. You just have to be very mindful of steering and wheelspin while locked. And also carry spare CVs and tie rods because there's a higher chance to break one.
  15. Feb 20, 2019 at 4:10 PM
    ilubtimmyhos
    ilubtimmyhos Brewer
    Adam
    Haymarket, VA
    2012 Blue Tacoma 4x4 Pre-Runner
    4x4 Conversion w/ FJ T-Case, King 2.5 Extended Travel Coilovers w/ JBA UCAs, King 12" 2.0 Smoothies w/ BAMF relocate in the rear, OME Dakar leaf pack, 4.56 gears w/ ARB air locker, Archive Hammer Hangers w/ crossbar brace, ARB Snorkel, Custom Bed cap w/ Roofnest Sparrow XL, Retrofit Headlights, Wrapped in 3M Satin Perfect Blue
    I'm not planning on locking my front when I do my rear......
    Arcticelf, 113tac, buyobuyo and 3 others like this.
  16. Feb 20, 2019 at 4:10 PM
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    Yes lots of people do. Also go look up the Rock Bouncer Outlaw he was running IFS and IRS! Spools front and rear. It's only a bad idea if you bounce around a lot and use it at the wrong times otherwise it can help out a lot.
    chiefcrunchy and Rome604[QUOTED] like this.
  17. Feb 20, 2019 at 4:10 PM
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    :rofl::rofl::rofl::rofl:
  18. Feb 20, 2019 at 4:16 PM
    Halffast555
    Jacob
    NOVA
    Thats actually not that bad. I dont mind what ever shows up and is a decent price lol.
    EatSleepTacos[QUOTED] likes this.
  19. Feb 20, 2019 at 4:37 PM
    BFRT_King Ranch
    Northern VA
    I am down to get together Friday evening somewhere as well too. In Manassas at the one that was mentioned the other day or Powers Farm.
    GoGoGadget likes this.
  20. Feb 20, 2019 at 4:37 PM
    Large BajaBlast
    Large BajaBlast Squatchin Snorlax
    James
    Virginia
    17 Silver TRD OR DCLB
    SSO Slimline, MBRP OC Rear Bumper, Cooper AT/3 LT , Smittybilt x20 winch, Bilstein 5100s all around, OME 888s, TRD Pro Grille, Softopper
    If you're looking for a better steak in an arcade setting then youre shit out of luck!
    I am always down for some old D&Bs!
