Northern Virginia Roll Call
Discussion in 'Virginia' started by r6hokie, Nov 17, 2011.
  1. Jun 6, 2019 at 6:36 PM
    crashdb
    crashdb I break chainsaws
    Dave
    Manassas, VA
    2008 Toyota Matrix
    Rollin' hydrocarbons!
    Next you'll be handing out business cards.
  2. Jun 6, 2019 at 6:40 PM
    113tac
    113tac Well-Known Member
    Stephen
    Northern Virginia
    2017 Magnetic Gray Tacoma
    Mostly Stock for now, 265 75 16 Falken AT3W, Tinted fronts...
    With a made up title that doesn’t have anything to do with your job....or is that just me?
  3. Jun 6, 2019 at 6:42 PM
    crashdb
    Dave
    Manassas, VA
    2008 Toyota Matrix
    Vicar of Pen Coordination isn't a title?
  4. Jun 6, 2019 at 6:49 PM
    Truggin
    Truggin What a long, strange trip it's been
    Don
    39.15737720308645, -77.92212986904099
    Black 2016 TRD Sport V6 4x4 Access Cab
    It's a work in progress. See my build thread.
    You really want the fuse to blow before the cable catches fire. That's the whole point. If the cable is 175 amps, you need to fuse at LESS that that.
    GoGoGadget likes this.
  5. Jun 6, 2019 at 6:51 PM
    Cody23
    Cody23 Well-Known Member
    Cody
    probably hunting or camping
    2022 TRDOR 6MT
    6112/5160 SCS 285s GFC
    would u guys pay 750 for a icon stage one with 12k miles? need to buy bolts for the top hat and a sway bar relocate
  6. Jun 6, 2019 at 7:02 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Most limit straps I found when researching stretch 1” for every 12” of strap. If yours didn’t advertise stretch specs I’d be leery
    ready6delta and buyobuyo like this.
  7. Jun 6, 2019 at 7:05 PM
    Rome604
    Rome604 I am the Captain now
    Dave
    Alexandria, VA
    2023 TRD Pro Sequoia
    Warn does make a winch relay. They just don't say how many amps it can withstand. It won't protect against the wire catching fire if you've activated the relay but it'll keep your hot wire shorter in case of an accident.
    EagleUSMCRet likes this.
  8. Jun 6, 2019 at 7:30 PM
    the.sight.picture
    the.sight.picture Wishes he was in the woods.
    Nick
    Blue Ridge
    2018 QuickSand
    Check out my build thread (Beginning of Money Pit)
    I will never pay the government to allow me to say dont tread on me, especially on a plate.
    quis23, BTHawk, ready6delta and 3 others like this.
  9. Jun 6, 2019 at 7:30 PM
    113tac
    Stephen
    Northern Virginia
    That’s completely realistic
    ready6delta likes this.
  10. Jun 6, 2019 at 7:30 PM
    113tac
    Stephen
    Northern Virginia
    Fair enough haha
  11. Jun 6, 2019 at 7:51 PM
    Usroadscholar
    Usroadscholar Well-Known Member
    Bill
    Aldie, VA
    2019 OR
    The winch is going to draw 420 amps on startup and that will drop as pull continues. Graphs give the over rated amps the fuse will allow to pass for a set time say 200% for 5 min. But a short will cause fuse to blow in 0.1 min provided it exceeds the amperage of the fuse by 500% or more. Problem, the CCA of battery is 600 amps. So if you fuse for cable the winch will blow fuse and if you fuse for winch the cable will melt or worse before fuse blows. Is this the reason winch manufactures don’t suggest fusing?
  12. Jun 6, 2019 at 8:10 PM
    Usroadscholar
    Bill
    Aldie, VA
    2019 OR
    It is rated at 500 amps. So you are thinking that solenoid switch will fail if >500 amps are drawn thus serving as a amp limiter.
    Rome604[QUOTED] likes this.
  13. Jun 6, 2019 at 8:21 PM
    Rome604
    Dave
    Alexandria, VA
    No that's not what I was thinking. Though that'd be cool if it works that way. I'm saying that you can put the relay near your battery and leave it off unless you are using your winch. My fear of winch cables is getting into an accident and having the body cut into the hot wire. A relay can help mitigate that risk.
  14. Jun 6, 2019 at 9:28 PM
    buyobuyo
    buyobuyo Read The Fucking Manual
    Jeremy
    Camden, AR
    08 PreRunner SR5, I4, Manual, Silver
    A thing or two...
    I have a nice pen that I was given at work. It's heavy, fits well in the hand, and writes really nice. I think I've replaced the cartridge in it once already. It looks like hell now with the black finish rubbing off and revealing the brass base material. I carried it daily for awhile. I'm paranoid of losing it now, so I don't anymore.
    I also had a space pen for awhile. I lost that one. It was a great pen, too.
    This ^
    It's more likely that the solenoid contacts would weld/fuse together if you pulled more than the rated current through it.
  15. Jun 6, 2019 at 10:53 PM
    chiefcrunchy
    chiefcrunchy Well-Known Member
    Brian
    Between North and South Virginia
    '15 DC MGM TRD Sport 4x4 6spd 4.0
    5100s, 885s, deaver AAL, Waiting impatiently to install Demello front bumper, Mobtown sliders & skids, and safari snorkel.
  16. Jun 7, 2019 at 3:39 AM
    chiefcrunchy
    Brian
    Good Morning everyone,
    :yay:happy friday!!!
    3pooches, Truggin and buyobuyo like this.
  17. Jun 7, 2019 at 3:41 AM
    EagleUSMCRet
    EagleUSMCRet Well-Known Member
    Gettysburg, PA
    2017 MGM 4x4 Tacoma DC Limited
    ESR Magnetic Mount MAGSafe charger for iPhone; AVS Vent Visors; Replaced Entune system with Kenwood Excelon Head unit, The Taco Garage DMM for Qi charger, Owl Dash Cam and Motorola GMRS; LED interior light upgrades, ARE Z Cap w/ Yakima Rack, Front Bed Rail, Bed Rug, Tuffy Bed Lock Box, Add a leaf, Pop and Lock, Blendmount and mirror tap for radar detector, AVS Hoodflector, Redline Hood Gas Spring mod. A/C drain mod, X2 Power Premium 27M battery, Debadged the tailgate, Compustar remote start, USB charger for the rear seats, Husky Mats, Lexus Credit Card Transponder Fob, MAG Light mount, twin Hella Sharptone horns, Bedslide, Gasshole, Meso Fuze cover, TRD Gas cap cover, Passenger side locking door handle, Mr. Produxn license place mount, Total Chaos Bed Stiffeners, Valley Runner Tune....help me I can't stop!!!
    Yeah buddy! TGIF!!! :bananadance:
    chiefcrunchy[QUOTED] and Rome604 like this.
  18. Jun 7, 2019 at 4:30 AM
    pabstsmeared
    pabstsmeared Simulated Weight
    Tappahannock, Va
    '13 Super White DCSB TX Baja
    Mud Tars & Shit
    Drove the Taco to work today with intentions of getting the lift on. We'll see how that pans out. Have some wrenching to do on a bulldozer and have to replace our building tenant's water heater. Hopefully that goes smoothly...:fingerscrossed:
  19. Jun 7, 2019 at 5:18 AM
    ready6delta
    ready6delta REGULAR GUY
    JACOB
    Still in PNW but moved to Boise.
    Black pinstriped 2014 DCSB 4x4
    IT NEVER ENDS..........
    Im down and we need to get a ride together soon and grab beers after!
    chiefcrunchy likes this.
  20. Jun 7, 2019 at 5:18 AM
    ready6delta
    JACOB
    When we drinking bears?
