Northern Virginia Roll Call
Discussion in 'Virginia' started by r6hokie, Nov 17, 2011.
  1. Jun 30, 2019 at 9:12 PM
    steiner9er
    steiner9er Well-Known Member
    Ethan
    DC area (home), Cincinnati area (school)
    2018 Cement Tacoma off-road
    Prinsu Cabrack ALLPRO bed rack Tepui Kukenam 3 Wrangler Duratrac
    @Arcticelf Adam told me to hit you up about this question
  2. Jul 1, 2019 at 2:40 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Yes adding more nitrogen is a thing. It stiffens up the shocks, effectively stiffening up the coil rate. What coils are on now and what pressure did he put them to?
    Don’t attempt to let pressure out yourself. There’s such a tiny amount of gas in them that you’re guaranteed to fuck it up without the right tool.
    ready6delta, 3pooches and buyobuyo like this.
  3. Jul 1, 2019 at 3:38 AM
    buyobuyo
    buyobuyo Read The Fucking Manual
    Jeremy
    Camden, AR
    08 PreRunner SR5, I4, Manual, Silver
    A thing or two...
    Like @EatSleepTacos just said, adjusting pressure to fine tune ride is a thing and you need the right tools to do it. However, tuning the shim stack on the piston is the right way to tune the shock.
    Max pressure is 150 psi, and you run the risk of blowing out the seals above that. Most people just run 150 psi and tune the piston shim stack.
    ready6delta, ovrlndkull and 3pooches like this.
  4. Jul 1, 2019 at 4:05 AM
    ovrlndkull
    ovrlndkull STUKASFK - HC4LIFE
    Skip
    Burlington, NC
    2005 DCLB Silver
    63s, XD Machete, Beat not Babied
    They are decent. Ride is ok they hold my heavy ass truck up. A beefier version of the 5100s have taken a lot of abuse and done me well.
    Yes that is a thing. Usually people start at 150psi (which I believe may be the max) then adjust from there. Now this part of shock tuning is the final stage after all other adjustments and tuning. Valving and stuff should be done first to get that set up right for your truck and the springs, weight you carry, etc. This is just a very simplified answer once you go down the rabbit hole of shocks, tuning, and suspension stuff it can get really confusing. If you are having ride issues with them or feel they aren't suiting you well, I would suggest sending them off to Accutune or Filthy motorsports and have them tune the shock to your truck. Then go from there. There are other companies that tune shocks those are just 2 that I have worked with/am working with and have done a really good job for me.
  5. Jul 1, 2019 at 4:12 AM
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    Yep tune the shock itself first then start at 150 and work down after all other adjustments have been made. Its just the last adjustment. If you get into IBT, bypasses, or clickers there is just a lot more you can do before messing with the nitrogen pressure. I will say that tuning and adjusting nitrogen press. is part of the right way to tune it's just your final thing to mess with after everything else has been exhausted.
    I agree just tuning by adjusting the nitrogen pressure and not messing with anything else is a band-aid for a poorly set up shock.
  6. Jul 1, 2019 at 5:25 AM
    3pooches
    3pooches Well-Known Member
    VA & WV
    15 tacoma dcsb Sc Linked, 2014 reg cab locked
    Well I need a new door.....
  7. Jul 1, 2019 at 5:28 AM
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    Ouch the big dent in the middle doesn't look to bad. Then I saw the one at the body line and bottom that looks pretty bad.
    ready6delta and 3pooches[QUOTED] like this.
  8. Jul 1, 2019 at 6:00 AM
    3pooches
    VA & WV
    The intrusion beam is bent and the shell is wrinkled, so the door is junk.
    buyobuyo and ovrlndkull[QUOTED] like this.
  9. Jul 1, 2019 at 6:02 AM
    quis23
    quis23 Well-Known Member
    Duan
    good ole' Manassas VA
    Manassas has a damn good fireworks show. We usually hang out downtown with kids a bit and tailgate nearby and watch the show.
  10. Jul 1, 2019 at 6:05 AM
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    Damn man that sucks
    3pooches[QUOTED] likes this.
  11. Jul 1, 2019 at 6:10 AM
    3pooches
    VA & WV
    Happens to the best of us I guess. I thought it ironic since I was just talking to Tyler about his dent and I did this 24 hours later.
  12. Jul 1, 2019 at 6:13 AM
    quis23
    Duan
  13. Jul 1, 2019 at 6:16 AM
    apy_camper
    apy_camper APY CMPR
    Christian
    Fredericksburg, VA
    2015 MGM DCLB SR5
    SR5 package Tow package A.R.E. midrise camper shell with roof rack
    I'm avoiding DC this year, metro shutdowns, secondary events on the mall, and self preservation are keeping me away LoL
    We usually stick around Fredericksburg and check a few events locally, but taking it to the country this year and camping at the cabin, with our own arsenal. My buddy is shooting a show in Elkton, VA for the fourth and Rick's on the River in Fairview Beach on the 6th.
  14. Jul 1, 2019 at 6:18 AM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    This is from bombing down your trails?
  15. Jul 1, 2019 at 6:21 AM
    3pooches
    VA & WV
    Yea, seems I got a little over zealous
    fatfurious2[QUOTED] likes this.
  16. Jul 1, 2019 at 6:25 AM
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    ready6delta and 3pooches like this.
  17. Jul 1, 2019 at 6:53 AM
    steiner9er
    Ethan
    He had essentially the same weight that I do, and he ripped them up to 140 I believe, but he’s not totally sure. The springs are #700, which I know may be a bit heavy for my 3rd gen with little weight, but I am going to try em out. Also going to get skids and maybe a front bumper this summer.
    Thanks for the input everyone
  18. Jul 1, 2019 at 6:55 AM
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    Take the preload off the springs and go from there. 140 is good.
    ready6delta likes this.
  19. Jul 1, 2019 at 7:30 AM
    intheblue25
    intheblue25 Well-Known Member
    2010 DCSB TRD Off Road
    Anybody have their frame inspected in NOVA and get it replaced?
    wtflint likes this.
  20. Jul 1, 2019 at 7:39 AM
    wtflint
    wtflint Well-Known Member
    Peter
    2018 TRD Sport
    I had mine inspected and replaced a year ago by Chantilly Toyota. They did a great job and were quick
