Northern Virginia Roll Call
Discussion in 'Virginia' started by r6hokie, Nov 17, 2011.
  1. Aug 19, 2016 at 10:02 AM
    #9061
    Coot83
    Coot83 DORKEL NATION
    Scottsdale, Az
    2012 Baja TX
    TC 3.5 LT, RCV axles, Demello sliders, BD light bar/fogs, LP6, DMZ rear, SOS skids, custom bumper, King 16" triples, Locked-on hydro rear bumps...
    So a cool thing I just learned about although Im sure many are familiar with on here is plasti-dip. Im thinking about blacking out my emblems and this seems like the right stuff for it! Looks pretty fun anyway to give it a shot. Im also up for wrenching as well as my rear will get swapped out eventually. Just got to figure out what exactly I want to do. Can anyone weld? Shock relocation keeps coming back to me...
    Coot
  2. Aug 19, 2016 at 10:05 AM
    #9062
    Choco_Taco
    Choco_Taco Sarcastic AF
    Tim
    Fredericksburg, VA
    2009 Black DCSB TRD OR
    I have a black taco and want to do some red plasti-dip on the emblems. Anyone ever seen a color other than black??
  3. Aug 19, 2016 at 10:14 AM
    #9063
    Coot83
    Scottsdale, Az
    2012 Baja TX
    That sucks man. I'm doing mine black because I got a red one. I will research and see if there is anything out there as it would be cool if they had other colors.
    Coot
  4. Aug 19, 2016 at 10:23 AM
    #9064
    Coot83
    Scottsdale, Az
    2012 Baja TX
    So apparently they have all sorts of colors! This is one from home depot, looks like walmart carries this too.
    ANNNNDDDDDD it looks like walmart has a smoked version for the plasti dip. I think that is the color I am going to get.
    http://www.homedepot.com/p/Plasti-Dip-11-oz-Red-Rubber-Coating-Spray-6-Pack-11201-6/203538946?cm_mmc=Shopping|THD|G|0|G-BASE-PLA-D24-Paint|&gclid=CJCEuOr-zc4CFQgcaQodkroMzQ&gclsrc=aw.ds
    Coot
  5. Aug 19, 2016 at 10:33 AM
    #9065
    Casper66
    Casper66 grumpy ass
    Culpeper, Va.
    '15 DCSB TRD Sport 4wd super white (sold) '13 access cab SR5 4wd
    piddly stuff
    they make a multitude od different colors i think durx has his emblems dipped red on his black truck
  6. Aug 19, 2016 at 10:39 AM
    #9066
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    You and @Lots2Learn58 have that in common
  7. Aug 19, 2016 at 11:39 AM
    #9067
    Choco_Taco
    Tim
    Fredericksburg, VA
    Yep just checked out his pixs and I like the look. Guess i will copy but in fairness i didn't know he had done it.
    Casper66[QUOTED] likes this.
  8. Aug 19, 2016 at 11:39 AM
    #9068
    HCJ
    HCJ Well-Known Member
    Virginia --> Texas
    '05 Taco with not enough miles
    I have a shock relocation I'm gonna be putting on soon so you could come and check it out, see if it's what you wanna do with your truck.
    Coot83[QUOTED] likes this.
  9. Aug 19, 2016 at 11:41 AM
    #9069
    Coot83
    Scottsdale, Az
    2012 Baja TX
    Shit I would love to help if you need another hand. Def let me know I need to learn all about that stuff!
    Coot
    HCJ[QUOTED] likes this.
  10. Aug 19, 2016 at 1:26 PM
    #9070
    HCJ
    Virginia --> Texas
    Absolutely! I'll give you a heads up when I plan on doing it. I'm just waitin on my u bolt flip kit from all pro
  11. Aug 19, 2016 at 1:44 PM
    #9071
    Casper66
    Casper66 grumpy ass
    Culpeper, Va.
    piddly stuff
    you guys do realize that the shock relocate is not just cutting stuff off and welding new on rt? your going to have to weld to your axel tube and if you don't get all your angles correct you'll end up with your tires hitting your shocks. it's not just a cut and dry thing.
    CanisLupus and 90yota like this.
  12. Aug 19, 2016 at 1:53 PM
    #9072
    90yota
    90yota Instagram: 90_yota
    Dixon, CA/Truckee,CA
    88 T4R / 15 F350
    Stock....ish
    Also I've read up on their install and if running stock wheels you'll most likely rub so have to run wheel spacers to clear the shock bodies
  13. Aug 19, 2016 at 1:58 PM
    #9073
    Casper66
    Casper66 grumpy ass
    Culpeper, Va.
    piddly stuff
    i have not done one and for those reasons it's apparently not that it can't be done but there are alot of different variables some hard to predict such as wheel loction at full tuck and even full droop and you go through all this for about 1" extra travel. there are plenty of trucks that have even had the shackle flip done which is more beneficial for articulation that have not done the shock relocate
  14. Aug 19, 2016 at 3:33 PM
    #9074
    Choco_Taco
    Tim
    Fredericksburg, VA
    Did anyone make it to Cap Ale House?
  15. Aug 19, 2016 at 6:54 PM
    #9075
    HCJ
    Virginia --> Texas
    Stock wheels with a 5.5 back spacing will rub *at full stuff* so I will most likely throw on spacers until I find a wheel with a back spacing of 4.5 or less.
    It is a decent amount of work but you get more than just an inch of extra travel, it's going to be more than 2 inches of usable travel. Plus you moving the upper shock mount above the frame with creates a more stable rear, better shock geometry, and you are trading up travel for down travel with a 12in shock body. You also have the ability to position the lower shock mounts in a manner that makes them less likely to get hit by rocks and objects on the trail because they hang so low. This is what my research has shown and with the deal I got on a relocation kit and shocks makes it worth while to me :cheers:
  16. Aug 19, 2016 at 7:11 PM
    #9076
    TacoFMS
    TacoFMS Bubble bubble bubble pop
    Justin
    Louisa County, VA
    Just a vehicle to take trash to the dump
    One or two things modded... Check out the build thread
    Not to start an argument, but I tend to disagree with several of these points. First if you plan to run a 285 or larger with the shock relocate and truly utilize the full travel you might want to look at wheels with around 3.5 bs so you don't rub the shock. Next, it may be 2" over a stock style rear, but if you compare to a shackle flipped rear it truly is only an inch (actually closer to 7/8 according to my measurements). I helped with one relocate and when finished we line two trucks up wirh identical setups minus the relocate and those were the measurements we got.
    I am not trying to kill dreams or even hurt feelings, just sharing my first hand experience. I chose a shackle flip and no relocate bc I just couldn't justify the amount of work and extra expense for an inch.
  17. Aug 19, 2016 at 7:13 PM
    #9077
    fatfurious2
    David
    Ashburn, VA
    you killed my dreams
    LocoLocal and TacoFMS[QUOTED] like this.
  18. Aug 19, 2016 at 7:16 PM
    #9078
    TacoFMS
    Justin
    Louisa County, VA
    Really, now? Should have been dead long ago.
  19. Aug 19, 2016 at 7:18 PM
    #9079
    TacoFMS
    Justin
    Louisa County, VA
    Just curious @Lots2Learn58 are you doing the prep and welding or are you outsourcing it? That can make another huge difference.
  20. Aug 19, 2016 at 7:22 PM
    #9080
    spithead051
    spithead051 Well-Known Member
    Patrick
    Fairfax, VA
    09 AC 4x4 OR S/C'ed!
    Supercharger, ICON 2.5VS w/ CDC, TRD T/X Pro Wheels, 255/85/R16 BFG MT KM2's, APEX three hoop bumper, Smittybilt X20 Comp Gen 2, Allpro IFS skid, All-Pro Sliders, Dynomax exhaust, aFe Stage 2 si, URD 2.85 stealth pulley, Oil pressure, oil temperature, boost, A/F ratio gauges, Devil horns, WO seat covers
    Apparently I've been gone too long and he's started dreaming again...
    TacoFMS[QUOTED] likes this.
