Northern Virginia Roll Call
Discussion in 'Virginia' started by r6hokie, Nov 17, 2011.
  1. Jun 22, 2020 at 6:38 PM
    JoeT4R
    JoeT4R I don't have a Taco
    Joe
    NOVA
    '01 4R, SR5 4WD
    P0420. It’s been on ever since I’ve owned the truck. Replaced my downstream o2 sensor few years ago and no change. I can always monitor and clear it with my ScanGauge though, so I’m hoping if I clear it before having it tested I could be good? I’m definitely nervous about this.
    Also yes, my cat is installed
  2. Jun 22, 2020 at 6:40 PM
    crashdb
    crashdb I break chainsaws
    Dave
    Manassas, VA
    2008 Toyota Matrix
    Rollin' hydrocarbons!
    Probably won't work. The truck also has to pass readiness for the test. Once it passes readiness the light will probably come back on.
  3. Jun 22, 2020 at 6:41 PM
    JoeT4R
    Joe
    NOVA
    '01 4R, SR5 4WD
    Do you have any go-to places in mind?
  4. Jun 22, 2020 at 6:44 PM
    crashdb
    Dave
    Manassas, VA
    2008 Toyota Matrix
    No. They're all pretty much the same. They hook up to your OBD II port and check for readiness, hard and soft codes. They're also supposed to do a visual check of emissions equipment. That part doesn't always happen.
  5. Jun 22, 2020 at 6:47 PM
    ilubtimmyhos
    ilubtimmyhos Brewer
    Adam
    Haymarket, VA
    2012 Blue Tacoma 4x4 Pre-Runner
    4x4 Conversion w/ FJ T-Case, King 2.5 Extended Travel Coilovers w/ JBA UCAs, King 12" 2.0 Smoothies w/ BAMF relocate in the rear, OME Dakar leaf pack, 4.56 gears w/ ARB air locker, Archive Hammer Hangers w/ crossbar brace, ARB Snorkel, Custom Bed cap w/ Roofnest Sparrow XL, Retrofit Headlights, Wrapped in 3M Satin Perfect Blue
    They won't do emissions if the system says you don't need it so if you can manage to drive by one of the mobile screeners they put on offramps
    LocoLocal likes this.
  6. Jun 22, 2020 at 6:48 PM
    crashdb
    Dave
    Manassas, VA
    2008 Toyota Matrix
    You can try this, but I think you have to do it twice in two weeks.
  7. Jun 22, 2020 at 6:48 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Did you have an emissions test in your previous state of registration?
  8. Jun 22, 2020 at 6:48 PM
    JoeT4R
    Joe
    NOVA
    '01 4R, SR5 4WD
    I briefly read into that. I see there’s one in Chantilly on 28 near Sully Rd... I’d much rather do that. But how do I get the results from it?
  9. Jun 22, 2020 at 6:49 PM
    crashdb
    Dave
    Manassas, VA
    2008 Toyota Matrix
    You don't. It's automated-ish.
    ilubtimmyhos likes this.
  10. Jun 22, 2020 at 6:49 PM
    JoeT4R
    Joe
    NOVA
    '01 4R, SR5 4WD
    I’m from VB, and I see you’re from Hampton Roads area too. So I’ve never done it before moving up here
  11. Jun 22, 2020 at 6:50 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Gotcha, nevermind then. That was one of the exemptions so I was curious to buy you some time to figure it out. No dice though. Could just try and Keep it registered down here.
  12. Jun 22, 2020 at 6:51 PM
    crashdb
    Dave
    Manassas, VA
    2008 Toyota Matrix
    If you've got no other codes replace the other O2 sensor. If that doesn't fix it then the cat. Rock Auto is your friend.
    JoeT4R[QUOTED] likes this.
  13. Jun 22, 2020 at 6:52 PM
    JoeT4R
    Joe
    NOVA
    '01 4R, SR5 4WD
    Thing is, I moved up here last spring but I wasn’t required to do emissions before my registration went out in July. So idk why now all of a sudden I have to do it.
  14. Jun 22, 2020 at 6:54 PM
    crashdb
    Dave
    Manassas, VA
    2008 Toyota Matrix
    There's sort of a workaround kind of like Randy was saying. You don't need to change your registration back to the Hampton Roads area, but you can say the vehicle is garaged there. They only ask for the county and no proof.
  15. Jun 22, 2020 at 6:58 PM
    velogeek
    velogeek Well-Known Member
    Andrew
    Gilbert, AZ
    2024 4Runner
    P0420 is downstream O2 or a bad catalyst 99% of the time. 95% of the time it's a slow-switching O2 sensor.
    I'm fairly certain bank 1 is passenger on the 4.0L and driver on the 4.7L (assuming this is the T4R) so make sure you did the right downstream sensor. A lot of people assume its always driver and do the wrong one when it's not.
    edit: Just realized 2001 was still the third gen 3.4L I think... passenger side on that one.
    EatSleepTacos and JoeT4R like this.
  16. Jun 22, 2020 at 6:59 PM
    JoeT4R
    Joe
    NOVA
    '01 4R, SR5 4WD
    Well somehow Manassas Park got ahold of my info and made me register it with the city. So I have that silly red decal in my window. As much as all of these options sound perfect, I feel like I’m gonna get screwed on this one. But hey who knows. Hopefully it’ll pass and none of this will even matter. I’m gonna aim for getting it done either tomorrow or Friday.
  17. Jun 22, 2020 at 7:03 PM
    JoeT4R
    Joe
    NOVA
    '01 4R, SR5 4WD
    I’ve got an ‘01. I just hope it’ll pass and then none of this will even matter. But I have a certain gut feeling about this. And yep it was passenger side that I replaced a few years back. Used OEM, too
  18. Jun 22, 2020 at 7:07 PM
    velogeek
    Andrew
    Gilbert, AZ
    2024 4Runner
    Yeah realized that and edited because it didn't click that was still best gen 4Runner. Trying to remember and I think there's two under there but that might have been a CA thing. If it's just the one it's probably a universal part any exhaust shop could weld on to get you to pass.
  19. Jun 22, 2020 at 7:07 PM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    emissions is every other year
  20. Jun 22, 2020 at 7:13 PM
    PyritePirateBill
    PyritePirateBill Well-Known Member
    Bill
    North Myrtle Beach, SC
    2014 pyrite mica TRD Sport 4x4 AC
    OME 886 Nitrocharger lift, Dakar HD leaf pack, u-bolt flip kit, Bilstein b110 rear shocks, Wheeler's super bumps,18x9 Worx Havoc, 35/12.50/18 Nitto Ridge Grapplers, ENVE Grille with LED lightbar & raptor leds, ditch lights, 6k hid, tinted tails, AtTheHelm bed stiffeners, SOS Concepts rear bumper, Demello baja front bumper, Smittybuilt 9.5k winch, Mobtown weld-on sliders, AllPro IFS & transm. skid, Mobtown transfer case skid, led fogs, led lights in rear bumper, 54" Bulldog hi-lift jack, Razorback shovel & axe on Quickfist mounts, Cobra CB w/Firestik antenna, Yellow wire mod for 4Lo, URD y-pipe, 2.5" custom exhaust w/ Borla muffler, Viair portable air compressor, Kryptek Typhon seat covers, AJT dash knobs
    No never saw that thread. But a guy in the 50+ thread that is a 45 year master toyota mechanic told me it's an evap check that the truck performs 6 hrs after shutdown. So his advice is to not tap into anything engine related. So I'm gonna run the wire inside to the other fuse block tomorrow at work. I've never noticed any sounds of any pumps running when it does the check tho.
