Northern Virginia Roll Call
Discussion in 'Virginia' started by r6hokie, Nov 17, 2011.
  1. Jul 9, 2020 at 6:16 AM
    Superman910
    Superman910 Epic Dirty
    Eric
    Northern Virginia
    2009 Tacoma TRD Sport DCLB 4x4
    Stock as Fuck or Not Fucking Stock
    slowly morphing into randyfab
  2. Jul 9, 2020 at 6:18 AM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    #fakenews. On a completely unrelated note I'll be bobbing 7" out of my bed.
  3. Jul 9, 2020 at 6:19 AM
    bbq4133
    bbq4133 Well-Known Member
    Dylan
    Leesburg, VA
    2020 JLU Rubicon 6MT
    Haven't really been into the concept of a bed cap or topper but I do like the look of that soft one.
    boogie3478 likes this.
  4. Jul 9, 2020 at 6:23 AM
    Superman910
    Eric
    Northern Virginia
    When did you get this. I was looking at the ones with the steering wheel. Overcomplicating it for my son haha
    and building your own bumpers?
  5. Jul 9, 2020 at 6:24 AM
    Cody23
    Cody23 Well-Known Member
    Cody
    probably hunting or camping
    2022 TRDOR 6MT
    6112/5160 SCS 285s GFC
    @Superman910 hey u still
    Interest in the airbags and day star cradles?
    Superman910 likes this.
  6. Jul 9, 2020 at 6:24 AM
    2016Taco4Me
    2016Taco4Me Well-Known Member
    NOVA
    2016 Tacoma TRD OR DCSB AT SuperWhite
    Billstein 5100's Wheelers 2" AAL BFG KO2 295/75/16 on FJ Trail Wheels Tires and stock wheels sold 03Jan21 Toytek 1" Lift Block WT Floor Liners and Vents HID Headlight Upgrade Redline Hood Struts White Knuckle Sliders MESO Ultimate Turn Signals MESO Dome and Map Lights MESO Chrome Delete Interior Mobtown Front and Mid Skids - awaiting transfer case skid (08Jan21) Warn Rear Bumper (08Jun20) Tailgate Pop and Lock - Install TBD Mobtown Low Profile Front Bumper - Installed by @ilubtimmyhos SPC UCAs - Installed by Adam @ilubtimmyhos OME 888 front coils - Installed by Adam @ilubtimmyhos Smittybilt XRC Gen 3 Winch Synthetic - Installed by Adam @ilubtimmyhos Overland Equipped Power Auxiliary Box with Blue Sea Systems ST Blade Fuse Block Installed by Adam @ilubtimmyhos Nitto Ridge Grappler 285/75/16 - Installed Oct 2020 Awaiting DS Grab Handle Mod arrival from KTJO 4X4 - Installed 05Jan21 after much asspain! Inner fender mud guard upgrade. LCA replacement - All work done by Justin: @TacoFMS
    Nice Snatch!
  7. Jul 9, 2020 at 6:26 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    She's served me well and lived a good life. I think it's time to retire ol girl soon and buy a new one.
    ready6delta likes this.
  8. Jul 9, 2020 at 6:26 AM
    2016Taco4Me
    NOVA
    Old snatches die hard!
  9. Jul 9, 2020 at 6:28 AM
    2016Taco4Me
    NOVA
    My truck was also eaten on this same day I believe. Nick said I'd be ok with my steps on. NOT!
    Edit: Nick = @Darkgoatracer as I forgot we’re talking two Nicks here!
  10. Jul 9, 2020 at 6:31 AM
    Superman910
    Eric
    Northern Virginia
    Not right now. Just moved and kinda have all side projects on hold.
  11. Jul 9, 2020 at 7:27 AM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    A lot of factors need to be considered.
    Cost, terrain, secondary use, ease of use, maintenance.
    There are two types of riding lawn mowers aka "tractors" for residential use. Lawn & Garden.
    Lawn Tractors are very basic, lower cost and cut grass perfectly, but you're limiting yourself to doing just that, and using basic accessories, like a snow plow, aerator or cart, for example. The engine will be more than adequate for cutting your grass but not designed for any heavy duty use.
    Garden Tractors are all of this on steroids. Heavier frame, better engine, more power, more advanced features.
    The brake-over is when you up the ante and switch to a "Sub-Compact Tractor". Price will go up considerably but you're basically getting a garden tractor sized machine with a lot more capability. If you have a decent amount of property and can benefit from things like a PTO driven tiller, a front end loader, a PTO driven snow blower, etc, and have the room to store all these implements it could be beneficial to skip the lawn and garden tractor series and jump into a sub-compact. Again, this is not a inexpensive choice. You should "have" to need this.
    Depending on what you're going to use it for, there are other options. If all you want to do is cut grass and do it quickly, and don't have a lot of steep slopes, and do have a lot of obstacles, then you might want to consider a Zero Turn. They may look hard to drive but actually after 5 minutes you can be a pro. The disadvantage, even though they have the lowest center of gravity is that I've heard they suck on steep slopes. And honestly, the only thing that doesn't is AWD or something with a locking rear.
    There's also a type of mower similar to a zero turn called a "stander" and it's literally that. You stand up on it and control it like a zero turn, like a tank. The difference is, these are the most nimble and manoeuvrable of all commercial mowers. They are also not cheap.
    I often wonder if I made the right choice a long time ago not getting an ATV, to use with a front mounted finish mower. Anything with a front mounted will cut grass closer to and easier than a belly mounted deck, especially up to and under bushes. You can also add a plow, snow blower, a front end loader, and basically pull anything a sub-compact, or riding mower can pull. The biggest benefit.......it's a big boy toy if you want it to be. Yes, now you're looking at prices equivalent to a sub-compact but again, the versatility can't be beat. Or the fun.
    Cub Cadet is great, Kubota, Deere are also very nice. When we moved up here 20 years ago (2.5 acres with about 30% to cut) all I could afford was a 22" walk behind. I bought a JD with a aluminum deck and a pressurized, spin off oil filter because of our grades which are severe in areas. Then I bought a used Scag 42" with a sulkie. That was dangerous and as I got older my knees said no. I bought a Deere Riding mower. It also had a 42" deck. It was nice. It worked well. I flipped it over. It was useless on the bad slopes. I upgraded to a Deere garden tractor. It had a locking rear diff. It also had a 48" deck. It was used and older and all I could afford at the time. I flipped that one over too.
    I ultimately traded that, a nice walk behind snow blower and that Deere 22" walk behind for a Kubota BX1860 sub-compact, 4wd (locking), diesel tractor with a 54" deck, a 54" blower and a front end loader. All told it cost as much as a compact car but I should have it forever. I can take the deck off and go up in the woods (14" clearance) but without any suspension it's no fun on the woop-di-doos. So that's why I wonder if I shouldn't have gotten an ATV........
    If you just need a riding mower to save time cutting your grass and don't have the need for awd, or accessories, then go to HD or Lowes and buy the nicest machine they have that you can afford. But the extended warr and never look back. If there's a Sears still open near you selling out, go get a Craftsman.
  12. Jul 9, 2020 at 7:40 AM
    the.sight.picture
    the.sight.picture Wishes he was in the woods.
    Nick
    Blue Ridge
    2018 QuickSand
    Check out my build thread (Beginning of Money Pit)
    I actually told you that you would have problems.
    Chaotic Evil Nick is me.
    True evil is Goat Racer Nick
  13. Jul 9, 2020 at 7:43 AM
    Greg.Brakes.Tacos
    Greg.Brakes.Tacos Don't Feed the Animals
    Greg
    Between Richmond and Virginia Beach
    2017 Taco DCSB TRD off road
    wanna be mods
    And here I thought it was challenging keeping track of all the "Daves" in here!!!!
  14. Jul 9, 2020 at 8:22 AM
    PyritePirateBill
    PyritePirateBill Well-Known Member
    Bill
    North Myrtle Beach, SC
    2014 pyrite mica TRD Sport 4x4 AC
    OME 886 Nitrocharger lift, Dakar HD leaf pack, u-bolt flip kit, Bilstein b110 rear shocks, Wheeler's super bumps,18x9 Worx Havoc, 35/12.50/18 Nitto Ridge Grapplers, ENVE Grille with LED lightbar & raptor leds, ditch lights, 6k hid, tinted tails, AtTheHelm bed stiffeners, SOS Concepts rear bumper, Demello baja front bumper, Smittybuilt 9.5k winch, Mobtown weld-on sliders, AllPro IFS & transm. skid, Mobtown transfer case skid, led fogs, led lights in rear bumper, 54" Bulldog hi-lift jack, Razorback shovel & axe on Quickfist mounts, Cobra CB w/Firestik antenna, Yellow wire mod for 4Lo, URD y-pipe, 2.5" custom exhaust w/ Borla muffler, Viair portable air compressor, Kryptek Typhon seat covers, AJT dash knobs
    Snorkel, check
    Speakers, check
    Sound deadener, delivery this afternoon at the house
    Tomorrow's a mod day for me!:taco::woot:
  15. Jul 9, 2020 at 8:23 AM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    :thumbsup:
  16. Jul 9, 2020 at 8:35 AM
    ilubtimmyhos
    ilubtimmyhos Brewer
    Adam
    Haymarket, VA
    2012 Blue Tacoma 4x4 Pre-Runner
    4x4 Conversion w/ FJ T-Case, King 2.5 Extended Travel Coilovers w/ JBA UCAs, King 12" 2.0 Smoothies w/ BAMF relocate in the rear, OME Dakar leaf pack, 4.56 gears w/ ARB air locker, Archive Hammer Hangers w/ crossbar brace, ARB Snorkel, Custom Bed cap w/ Roofnest Sparrow XL, Retrofit Headlights, Wrapped in 3M Satin Perfect Blue
    anyone want a bed mat? Installing the decked system kind of negates me having one
  17. Jul 9, 2020 at 8:36 AM
    crashdb
    crashdb I break chainsaws
    Dave
    Manassas, VA
    2008 Toyota Matrix
    Rollin' hydrocarbons!
    In case you weren't aware: the template for the snorkel is a little off. At least it was when I did mine not that long ago. I put the studs in the snorkel and held them against the template while it was on the truck to adjust. Did you get the hole saw? And I'm sure you have a body saw. Goes through the fender like crazy! My favorite new air tool.
    Greg.Brakes.Tacos likes this.
  18. Jul 9, 2020 at 8:48 AM
    Greg.Brakes.Tacos
    Greg
    wanna be mods
    Awwwww snap, Friday mod day for the win!!!!!
    My wife saw my phone screen when I was looking at their Snorkel thread and immediately said, Wooooohhhhh that is certainly ugly. You won't be doing that, right?
    So it's looking like a cowl snorkel wanna be or just wait for another big water crossing.
    Considering she freaked out the first day I owned it crossing this flooded road/overflowing River on our way to our friends kids 1st birthday...I figured that once the function was explained she'd be all for it. Looking like it won't be on the mod list for a while![​IMG]
  19. Jul 9, 2020 at 9:22 AM
    mtb_taco
    mtb_taco Well-Known Member
    2001 Tacoma
    I'd be interested in the mat. I'm close by
    RobP62 and ilubtimmyhos[QUOTED] like this.
  20. Jul 9, 2020 at 9:46 AM
    PyritePirateBill
    Bill
    Yeah, my wife thinks they are ugly also...do I care? Nope!:rofl:
