Northern Virginia Roll Call
Discussion in 'Virginia' started by r6hokie, Nov 17, 2011.
  1. Jul 20, 2020 at 12:29 PM
    GoGoGadget
    GoGoGadget Well-Known Member
    2017 DCLB OR
    Pin it to your shirt for the paramedics.
  2. Jul 20, 2020 at 12:30 PM
    crashdb
    crashdb I break chainsaws
    Dave
    Manassas, VA
    2008 Toyota Matrix
    Rollin' hydrocarbons!
    You should consider a barn fan. Or swamp cooler. Or something.
  3. Jul 20, 2020 at 12:37 PM
    GoGoGadget
    2017 DCLB OR
    When I used to teach motorcycle classes, on days like this standing on black asphalt for 12hrs a day in the sun, I would take a neck gaiter/buff and fill it with ice and keep that around my neck. Works like a charm as long as you don't mind your shirt being soaking wet.
    RobP62 likes this.
  4. Jul 20, 2020 at 12:40 PM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    Id look into Taco Tabs from Poly Performance. No more alignments after that!
    3pooches likes this.
  5. Jul 20, 2020 at 12:41 PM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    I was done by about noon and in the shade but still hot as balls.
  6. Jul 20, 2020 at 12:44 PM
    fatfurious2
    David
    Ashburn, VA
    I was down in Fredericksburg at 8am yesterday working on my truck in the Walmart parking lot, and I was dead AF :rofl:
    EatSleepTacos[QUOTED] likes this.
  7. Jul 20, 2020 at 1:54 PM
    3pooches
    3pooches Well-Known Member
    VA & WV
    15 tacoma dcsb Sc Linked, 2014 reg cab locked
    I want to see said cuts!
  8. Jul 20, 2020 at 1:58 PM
    Greg.Brakes.Tacos
    Greg.Brakes.Tacos Don't Feed the Animals
    Greg
    Between Richmond and Virginia Beach
    2017 Taco DCSB TRD off road
    wanna be mods
    Man I hope mine aren't seized...guess I'll just go mark them and then see if they can be loosened for my suspension install and putting in those HOPEFULLY Saturday, might mark and check them Friday when I get home! Otherwise sounds like replacement parts would be needed!
    I might throw on the rears ahead of the weekend since I know they come off since I did the leafs twice (upgrade and then shimming)!
  9. Jul 20, 2020 at 2:05 PM
    3pooches
    VA & WV
    My truck had 40k miles when I tried to remove my lca’s and they were seized. Had to cut through the bushings. I think this is the norm. I think you are lucky if they spin. If they do move freely, and you are keeping that setup, lube the bolt and sleeve with anti sieze like I think nick said. If you do have to cut the bushings, you will have options ranging from sas to replacement bushings and bolts to contemplate.
  10. Jul 20, 2020 at 2:09 PM
    boogie3478
    14 TRD Off-Road V6
    All the mods
    Took a pic earlier but they sort of blend in.
    RobP62, 113tac and 3pooches[QUOTED] like this.
  11. Jul 20, 2020 at 2:32 PM
    Greg.Brakes.Tacos
    Greg
    wanna be mods
    Hmmmm, too hot to gamble being stuck with the no AC civic. Definitely checking before diving in.
    3pooches[QUOTED] likes this.
  12. Jul 20, 2020 at 2:35 PM
    crashdb
    Dave
    Manassas, VA
    2008 Toyota Matrix
    I'm willing to bet you'll be okay. I've done the suspension up front twice and both times they were a-okay. Of course, I could be wrong and you'll be cussing my name the entire time. I'm okay with either.
  13. Jul 20, 2020 at 2:48 PM
    Greg.Brakes.Tacos
    Greg
    wanna be mods
    Come on Dave, you know no two trucks will mod the same way for the most part!!
    It looks like the heat wave will break this Friday down my way, only hitting 90 on the mecury and 89 Saturday. Hopefully I can get to my in-laws to do some wrenching...not sure about aligent shops, but I imagine something is better than nothing for tire/steering/general safety post uca and shock/coilover install.
    The real million dollar bet is what this will do to my driveline/rear pinion shim fix!?!?
  14. Jul 20, 2020 at 2:54 PM
    crashdb
    Dave
    Manassas, VA
    2008 Toyota Matrix
    It's not exact, but you can mark the tabs on the alignment bolts. You'll be close enough for government work. Or at least until you get to the alignment rack.
    I had truck projects for last weekend. I said nope. May say nope again this weekend. I don't do well with the humid.
  15. Jul 20, 2020 at 2:57 PM
    Greg.Brakes.Tacos
    Greg
    wanna be mods
    If all I need to do is remove the strut bolt from the LCA, and the lower ball joint attachment to drop if free, right?
    I wasn't thinking of pulling off the LCAs...but never having done any of this up in the front am all ears/eyes!
    the ball joint from the
  16. Jul 20, 2020 at 3:01 PM
    3pooches
    VA & WV
    You will NOT need to remove the control arm. It will require a little force to flex the control arm down.
  17. Jul 20, 2020 at 3:13 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I have a big box fan that blows on me for anytime I’m not welding. Makes a huge difference. I already told the wife that if our next garage is large enough to work on the truck with the door closed, I’m getting a portable ac unit in there.
  18. Jul 20, 2020 at 3:13 PM
    Greg.Brakes.Tacos
    Greg
    wanna be mods
    Yeah. I am moving wood rounds and split stacks for tree clearing on the 31st...I got three trailer loads of rounds moved, trash/recycle center run, and did the weedeating and mowing between Saturday and Sunday mornings and evenings.
    I too tend to avoid this type misery weather...but the 31st is almost here, and I've got about a chord of split wood to move and a few more pallets of smaller rounds to move.
  19. Jul 20, 2020 at 3:15 PM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    :rofl::rofl::rofl::rofl::rofl::rofl::rofl:
    I won't even look out the windows. Fuk Dat!
  20. Jul 20, 2020 at 3:46 PM
    Darkgoatracer
    Darkgoatracer Well-Known Member
    Nick
    Northern VA
    2012 trd sport tacoma
    Stock
    So i have a stupid question. Is a tacoma limited a thing?
    3pooches and TaKoToy like this.
