Northern Virginia Roll Call
Discussion in 'Virginia' started by r6hokie, Nov 17, 2011.
  1. Aug 27, 2020 at 7:37 PM
    EagleUSMCRet
    EagleUSMCRet Well-Known Member
    Gettysburg, PA
    2017 MGM 4x4 Tacoma DC Limited
    ESR Magnetic Mount MAGSafe charger for iPhone; AVS Vent Visors; Replaced Entune system with Kenwood Excelon Head unit, The Taco Garage DMM for Qi charger, Owl Dash Cam and Motorola GMRS; LED interior light upgrades, ARE Z Cap w/ Yakima Rack, Front Bed Rail, Bed Rug, Tuffy Bed Lock Box, Add a leaf, Pop and Lock, Blendmount and mirror tap for radar detector, AVS Hoodflector, Redline Hood Gas Spring mod. A/C drain mod, X2 Power Premium 27M battery, Debadged the tailgate, Compustar remote start, USB charger for the rear seats, Husky Mats, Lexus Credit Card Transponder Fob, MAG Light mount, twin Hella Sharptone horns, Bedslide, Gasshole, Meso Fuze cover, TRD Gas cap cover, Passenger side locking door handle, Mr. Produxn license place mount, Total Chaos Bed Stiffeners, Valley Runner Tune....help me I can't stop!!!
    forgive if this a repeat... it cracked me up...
    chiefcrunchy, BTHawk, quis23 and 8 others like this.
  2. Aug 27, 2020 at 8:24 PM
    the.sight.picture
    the.sight.picture Wishes he was in the woods.
    Nick
    Blue Ridge
    2018 QuickSand
    Check out my build thread (Beginning of Money Pit)
    The only reason I was able to find out was after driving all the way home from flagpole (after filling up the tires to 32psi) the next morning I had 25psi. Then the next was 18psi.
    I couldnt find the damn leak until I pulled the tire off and sprayed the rim seal.
    Imagine after driving that distance and 2 days later you find out you been driving on a tire off its bead on the inside
  3. Aug 27, 2020 at 8:30 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    It sounds like you just got some gunk in the bead and introduced a slow leak. I’ve had that happen a couple times. I’ll take it to the tire shop where they’ll unmount it, clean it up and remount/balance it.
    I thought you meant like blew a bead. Where it’s all the way off.
  4. Aug 27, 2020 at 8:43 PM
    the.sight.picture
    Nick
    Blue Ridge
    2018 QuickSand
    See, that's the funny thing. When I took it to the tire shop, there was nothing inside the tire on the wheel. Nothing. But it also came off on the outside a bit (not as large as the back tho)
    Dude if my tire looked like that (tire not on the wheel at all) from flag pole I've got bigger issues go fix than just the wheel.
    Like learning how to air down, because that the only way that shit is happening at flagpole with the proper sized wheels and tires imo
  5. Aug 28, 2020 at 4:45 AM
    velogeek
    velogeek Well-Known Member
    Andrew
    Gilbert, AZ
    2024 4Runner
    These are freakin' great as a concept but no experience with that company. I had a customer who worked in a machine shop who made a set of these back in the day because I was aligning his truck every two months. Only downside is your camber/caster gets incremented a few tenths at a time but paired with some adjustable uppers it's no different than literally everyone else who does adjustment on the upper except that you can zero the bottom where you want.
    At $50 all-in, that's probably less than you'd pay for actual Toyota parts.
    Hafaday[QUOTED] likes this.
  6. Aug 28, 2020 at 6:33 AM
    2016Taco4Me
    2016Taco4Me Well-Known Member
    NOVA
    2016 Tacoma TRD OR DCSB AT SuperWhite
    Billstein 5100's Wheelers 2" AAL BFG KO2 295/75/16 on FJ Trail Wheels Tires and stock wheels sold 03Jan21 Toytek 1" Lift Block WT Floor Liners and Vents HID Headlight Upgrade Redline Hood Struts White Knuckle Sliders MESO Ultimate Turn Signals MESO Dome and Map Lights MESO Chrome Delete Interior Mobtown Front and Mid Skids - awaiting transfer case skid (08Jan21) Warn Rear Bumper (08Jun20) Tailgate Pop and Lock - Install TBD Mobtown Low Profile Front Bumper - Installed by @ilubtimmyhos SPC UCAs - Installed by Adam @ilubtimmyhos OME 888 front coils - Installed by Adam @ilubtimmyhos Smittybilt XRC Gen 3 Winch Synthetic - Installed by Adam @ilubtimmyhos Overland Equipped Power Auxiliary Box with Blue Sea Systems ST Blade Fuse Block Installed by Adam @ilubtimmyhos Nitto Ridge Grappler 285/75/16 - Installed Oct 2020 Awaiting DS Grab Handle Mod arrival from KTJO 4X4 - Installed 05Jan21 after much asspain! Inner fender mud guard upgrade. LCA replacement - All work done by Justin: @TacoFMS
    I would get some of the engineered gas and run it through the carb prior to sitting, I do this with my small engines and snowblower without issue, there's no ethanol in it so it won't corrode the carb and is safe.
  7. Aug 28, 2020 at 8:14 AM
    Hafaday
    Hafaday Well-Known Member
    Bill
    Richmond, VA.
    19, DCSB, Off Road. 23 KLX300, 14JKU
    I do the same..
    Another thing I've always been told from a guy that repairs them, was to put some kinda load on the generator (plug something in to it). supposedly the gen/invert can go bad if just running the gen. and not having a load on it. How true this is.. dunno.
  8. Aug 28, 2020 at 8:18 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    While breaking it in, I put a space heater on it in the backyard. Worked great for a constant, decent load.
  9. Aug 28, 2020 at 8:20 AM
    2016Taco4Me
    NOVA
    Nothing like adding more heat to the fire...
  10. Aug 28, 2020 at 8:21 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I was singlehandedly contributing to global warming that day in the most literal sense.
  11. Aug 28, 2020 at 8:39 AM
    Greg.Brakes.Tacos
    Greg.Brakes.Tacos Don't Feed the Animals
    Greg
    Between Richmond and Virginia Beach
    2017 Taco DCSB TRD off road
    wanna be mods
    It wasn't over 105 heat index, so he felt compelled to make it right...I mean it is summer down in Coastal VA!
    RobP62 and Hafaday like this.
  12. Aug 28, 2020 at 8:41 AM
    2016Taco4Me
    NOVA
    Probably should have added a little mist into the mix to increase the humidity!
  13. Aug 28, 2020 at 8:42 AM
    Hafaday
    Bill
    Richmond, VA.
    and a fan to blow it around.
    2016Taco4Me[QUOTED] and RobP62 like this.
  14. Aug 28, 2020 at 9:07 AM
    Hafaday
    Bill
    Richmond, VA.
    Lemme git.. Gots to dig out my golf shit to go play around. Sounds like my Daughter is not playing. Just her BF an I. Apparently She's gonna be fetching our drinks, as she said.
    Later dudes.
    PyritePirateBill and RobP62 like this.
  15. Aug 28, 2020 at 10:08 AM
    buyobuyo
    buyobuyo Read The Fucking Manual
    Jeremy
    Camden, AR
    08 PreRunner SR5, I4, Manual, Silver
    A thing or two...
    No need for engineered gas if there is a station near you that has ethanol-free gas.
    There's a station up the road from me here with e-free 91 octane, so that's what I run in all my small engines with stabilizer. I use it to mix up my 2-stroke gas, as well.
  16. Aug 28, 2020 at 10:17 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I wish I had that readily available. That would be really nice.
    RobP62 likes this.
  17. Aug 28, 2020 at 10:31 AM
    crashdb
    crashdb I break chainsaws
    Dave
    Manassas, VA
    2008 Toyota Matrix
    Rollin' hydrocarbons!
    And the engineered ain't cheap. I use it in my two-stroke stuff and it's around $25 a gallon. For everything else I just get the gas from the station and add Sta-bil 360. Everything is around 5 years old and not had a single issue starting stuff.
    buyobuyo[QUOTED], Hafaday and BTHawk like this.
  18. Aug 28, 2020 at 10:39 AM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    You can buy engineered at Home Depot, Pre-Mixed too.
  19. Aug 28, 2020 at 12:00 PM
    Greg.Brakes.Tacos
    Greg
    wanna be mods
    Look into gas stations near Marinas or inland boat ramps.
    I have 2 that have 90 efree and the other is 89 efree pumps within 4 miles of my house/on the DD, so just holler if you want a few 5 gal. Jerry's filled!
    EatSleepTacos[QUOTED] likes this.
  20. Aug 28, 2020 at 12:01 PM
    Demo man
    Demo man Well-Known Member
    Dave
    Fredericksburg, Va
    2020 OR
    Anyone with lane departure on their truck be prepared for a $400 recalibration if you need a new windshield. Month and a half old and I’m already having to get a new windshield :annoyed::annoyed::annoyed::annoyed::annoyed:
