Northern Virginia Roll Call
Discussion in 'Virginia' started by r6hokie, Nov 17, 2011.
  1. Sep 21, 2020 at 10:40 AM
    3pooches
    3pooches Well-Known Member
    VA & WV
    15 tacoma dcsb Sc Linked, 2014 reg cab locked
    I sitting in New York bored out of my mind. Anyone doing any fun or worth while today?
  2. Sep 21, 2020 at 10:48 AM
    crashdb
    crashdb I break chainsaws
    Dave
    Manassas, VA
    2008 Toyota Matrix
    Rollin' hydrocarbons!
    "Working." Does that count?
  3. Sep 21, 2020 at 10:51 AM
    velogeek
    velogeek Well-Known Member
    Andrew
    Gilbert, AZ
    2024 4Runner
    I can assure you my working today is neither fun nor worthwhile.
    chiefcrunchy and 2016Taco4Me like this.
  4. Sep 21, 2020 at 10:55 AM
    3pooches
    VA & WV
    Well that makes three of us. Unless Dave’s having the time of his life “working”
  5. Sep 21, 2020 at 11:01 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Once I'm done "working" I'm going to pull my rear 3rd member and mail it back to ECGS. I currently have a lunchbox locker in there and I'm putting in an ARB. The lunchbox is clunky and loud and effective, but in a manual transmission, it can be a little exhausting. In autos they're not too bad.
    Hafaday and 3pooches[QUOTED] like this.
  6. Sep 21, 2020 at 11:09 AM
    3pooches
    VA & WV
    I just put arb’s in Shannon’s truck last week and the compressor keeps blowing fuses. I think I have a bad switch. Arb told me it’s a ground issue but I grounded it to the battery negative and the body so I doubt that’s the issue.
    chiefcrunchy likes this.
  7. Sep 21, 2020 at 11:10 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    You could try a continuity test on the switch to see, or maybe swap switches around with a known good. I'm just hoping I don't have issues with the internal seals. It's a known issue that ARB keeps "fixing" and it keeps failing. At least ECGS will take care of me but it would be a hassle. One friend here has had it warrantied 4 times now.
    3pooches[QUOTED] likes this.
  8. Sep 21, 2020 at 11:13 AM
    3pooches
    VA & WV
    What’s the sign of a bad seal? Does it just leak and if so from where? Just so I know what to look for.
  9. Sep 21, 2020 at 11:15 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    For the ARB to lock and remain locked, it'll have a constant 90 psi against it. So the compressor will cycle for a split second to build up pressure and then cut off. If you have a leaky seal, your compressor will just continuously run and the locker won't engage.
  10. Sep 21, 2020 at 11:16 AM
    crashdb
    Dave
    Manassas, VA
    2008 Toyota Matrix
    Time of my life? Meh. I'm supposed to be doing things. Productive things. Like making sure y'all don't get 'sploded. It can wait.
    Randy, you need to make up your mind about that locker! Wait. Maybe I do. I've put it on my wish list four times and removed it. I just don't know that the clunking would drive me crazy. So whatchu doin' with the old lunchbox?
  11. Sep 21, 2020 at 11:17 AM
    3pooches
    VA & WV
    Gotcha, air seal. I was thinking an oil seal was affected by the copper line or something.
  12. Sep 21, 2020 at 11:19 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    From what I can tell talking to people, it's not nearly as bad in an auto. It's a little clunky but it's just a little noise. In the manual, the slack that's introduced into the driveline is very noticeable and also causes the truck to be lurchy as shit in parking lots. I have to be mindful of what I'm doing. I was going to ask for them to ship it back with the diff. You'd need a new spring kit for it but you can have it if you want, assuming the teeth aren't all worn out.
  13. Sep 21, 2020 at 11:19 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Ahhh, no nothing like that at all.
  14. Sep 21, 2020 at 11:23 AM
    crashdb
    Dave
    Manassas, VA
    2008 Toyota Matrix
    What ever is easiest for you. Even if I had a brand new one sitting in the garage it would be a bit before getting it in. Especially, since I just put $70 worth of gear oil in there.
  15. Sep 21, 2020 at 11:24 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    The fuck kind of oil are you putting in there?! The lucas 85w-140 ecgs recommends is like $7 a quart.
  16. Sep 21, 2020 at 11:25 AM
    3pooches
    VA & WV
  17. Sep 21, 2020 at 11:26 AM
    crashdb
    Dave
    Manassas, VA
    2008 Toyota Matrix
    Redline. I think it was more like $45 or something. In mind I was adding in the front differential. There were lots of fluids..
    3pooches likes this.
  18. Sep 21, 2020 at 11:27 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Those pumps are the literal worse. For the rear I just squeeze it in and for the front, I have a 12" hose I put on the tip of the nozzle to squeeze it in. Still a bitch but at least I'm not sitting there pumping forever.
  19. Sep 21, 2020 at 11:27 AM
    crashdb
    Dave
    Manassas, VA
    2008 Toyota Matrix
    Air power! I have an air-powered fluid-moving-type-thing. It made this weekend so much easier. Refill time was nap time.
  20. Sep 21, 2020 at 11:28 AM
    crashdb
    Dave
    Manassas, VA
    2008 Toyota Matrix
    Hafaday, Karminski and Rockslide like this.
