Northern Virginia Roll Call
Discussion in 'Virginia' started by r6hokie, Nov 17, 2011.
  1. Jan 10, 2021 at 10:07 AM
    crashdb
    crashdb I break chainsaws
    Dave
    Manassas, VA
    2008 Toyota Matrix
    Rollin' hydrocarbons!
    Do these horns make my tires look fat?
  2. Jan 10, 2021 at 10:08 AM
    crashdb
    Dave
    Manassas, VA
    2008 Toyota Matrix
    Little bit of water and good as new.
    2016Taco4Me, Mojo Jojo and 3pooches like this.
  3. Jan 10, 2021 at 10:15 AM
    IPNPULZ
    IPNPULZ Well-Known Member
    Deeper in the South…….
    2023 TRD Off Road Premium 4R
    going to be fun!
    Does the dash still light up like a xmas tree?
  4. Jan 10, 2021 at 11:07 AM
    03dumdum
    03dumdum Well-Known Member
    JT
    White 2018 TRD OR
    Fox 2.5 rr, RCI front/mid skid JBA uca RCI rack iKamper Xcover AAL Ray 10 17x9 -38 Maxzis Razr AT 285-75r17 20% front windows & 5% strip on windshield Tactilian magnetic flags Weird engine squeal Custom pin strips.
    I do need a pair... probably not a great idea to keep sleeping in the RTT without them. Why'd you decide to part ways with them?
  5. Jan 10, 2021 at 11:20 AM
    Darkgoatracer
    Darkgoatracer Well-Known Member
    Nick
    Northern VA
    2012 trd sport tacoma
    Stock
    Absolutely, it even flashes now!
    LocoLocal likes this.
  6. Jan 10, 2021 at 11:23 AM
    Tiny's Taco
    Tiny's Taco The Wanderer
    Shenandoah Valley
    2018 Inferno TRD Sport
    That's a horrible idea. What time?
    Those are the ones I have. I think you'd like them.
    03dumdum[QUOTED] likes this.
  7. Jan 10, 2021 at 11:36 AM
    Darkgoatracer
    Nick
    Northern VA
    Stock
    Wanna wash mine next?
  8. Jan 10, 2021 at 11:39 AM
    Jim=2015 TRD PRO
    Jim=2015 TRD PRO Well-Known Member
    Jim
    MD
    2015 TRD PRO
  9. Jan 10, 2021 at 11:40 AM
    Tiny's Taco
    Shenandoah Valley
    :D
    EagleUSMCRet and 3pooches like this.
  10. Jan 10, 2021 at 11:40 AM
    crashdb
    Dave
    Manassas, VA
    2008 Toyota Matrix
    I'll put in the quarters for you.
  11. Jan 10, 2021 at 11:59 AM
    Overland&UpMoutains
    Overland&UpMoutains Fully Built Overland Rig for Sale
    Parker
    Deleware
    2018 TRD Pro MT Blue
    Armor: Custom Fabricated Front Bumper (Victory 4x4 Blitz w/ full width tubing added after) Victory 4x4 Strike Steel Rock Sliders Coastal Overland Rear Bumper w/ Dual Swing Out Steel and reinforced Hitch Receiver RCI Full Aluminum Skid’s Wheels/Tires/Suspension 34” BFG KO2 (Full size spare on swing out) 17” KMC Impact (black) Fox 2.5” Front Coilovers w/ DSC Adjuster Upgraded Springs: 650 lb Eibach 14" Long 3.0" ID Coil Springs Total Chaos Upper Control Arm Fox 2.5" Remote Reservoir Shock Kit for Rear w/ DSC Adjuster ICON RXT Leaf Spring (Option 3/Heavy Setting) Wheeler Superbump Front + Rear Bumpstops ICON U-Bolt Flip Kit Body Mount Relocation ECGS 8” Clamshell Bushing (Eliminates Needle Bearing) **For Refrence: Suspension set up is equivalent to Stage 4a Acutune** Performance/Off-Road Stuff/Recovery Nitro 4.88 Regear installed by ECGS Dobson 4x4 Snorkel Differential Breather 10k lb winch (Smittybuilt) Extended rear brake lines Hi-Lift Jack w/ weatherproof cover included (mounted to roof rack, can also be mounted to swing out) Air Compressor and Air Hoses included 4 ton jack stand included Tree saver winch strap included D-Ring Shackle x 2 included Spare Parts Include: 1 Wheel Bearing, 1 Tie Rod End Interior Accessories Custom Rear Seat Delete Platform Dashtop Multi-Mount (DMM), Will include 3 RAM mounts, one radio mount and two phone mounts iPad Mount, attached to passenger seat bracket, used for navigation Headrest Velcro Pouch Kit (Blue Ridge Overland) Overhead Storage Attic (Blue Ridge Overland) Trash Can (Lusso Gear Spill-Proof Car Trash Can, 2.5 Gallon Hanging behind Passenger seat) Fire Extinguisher Mount Exterior Accessories/Storage Prinsu Cab Rack Rugged Case (47” weatherproof rifle case mounted on Prinsu roof rack) Custom Roof Rack on Camper (designed to fit traction boards perfectly with space on either side for bikes or storage cases) Tailgate Storage, custom design using deck hatch that utilizes the interior space of the tailgate where I store recovery gear. Overland/Camping: Camper Custom (see details below) Bed light Bed lighting Domestic Fan Swing Up Rear/Side Panels with Locks Roof Rack 200 watt solar panel LED Third Brake Light Rear View Camera (connects to video rear view mirror in cab) Hurricane Hinges (not in the first few pictured as it was recently installed, you can see them in the later pictures but they are now painted black not silver to match the camper, totally waterproof no leaks!) Bed Buildout/Living System Baseboard/Mounting Plate (1/2” Birch, Bed Liner Coating) Trunk Cabinet Shelf Cabinet (fits 2 Sidio crates plus top storage box w/ organizing dividers) Elevate Fridge Cabinet w/ under storage for stove/cooking gear Custom 8020 build - strong enough to sit/stand on Water: 10 Gallon Water tank with pump, two spouts, one in back seat one in the bed 5 lb Propane Tank w/ mount attached to Swing Out (likely included, final tbd) Drop down table (attached to swing out) Rear Seat Delete (custom) Lighting: Rigid Adapt 30” Light Bar Rigid Ditch Lights Quad LED Headlights Meso Dual Red/White Interior Lights (Map + Dome) Camper interior lighting Electric Dual Battery System RedArc BCDC 25a Controller 90 Ah AGM Secondary/House Battery 200 watt solar panel 2 Blue Sea Fuse Boxes to manage accessories (one under hood, one in bed) Extra fuses included Comms: Midland Micromobile GMRS WeBoost w/ extended antenna on a RAM pivoting mount Other Fumoto Oil Change Valve Bike Rack (Tire Mounted)
    Putting in some drawers, wanted to maximize the width of the drawers and the bed stiffner got in the way. I don’t have a roof top tent so no big deal for me
  12. Jan 10, 2021 at 12:10 PM
    BTHawk
    BTHawk OFP
    Will
    Warrenton, VA
    2025 J250 LC Prado
    ilubtimmyhos likes this.
  13. Jan 10, 2021 at 3:22 PM
    pathfinder27
    pathfinder27 Well-Known Member
    Douglas
    Mesa, AZ
    2017 TRD PRO
  14. Jan 10, 2021 at 3:26 PM
    PyritePirateBill
    PyritePirateBill Well-Known Member
    Bill
    North Myrtle Beach, SC
    2014 pyrite mica TRD Sport 4x4 AC
    OME 886 Nitrocharger lift, Dakar HD leaf pack, u-bolt flip kit, Bilstein b110 rear shocks, Wheeler's super bumps,18x9 Worx Havoc, 35/12.50/18 Nitto Ridge Grapplers, ENVE Grille with LED lightbar & raptor leds, ditch lights, 6k hid, tinted tails, AtTheHelm bed stiffeners, SOS Concepts rear bumper, Demello baja front bumper, Smittybuilt 9.5k winch, Mobtown weld-on sliders, AllPro IFS & transm. skid, Mobtown transfer case skid, led fogs, led lights in rear bumper, 54" Bulldog hi-lift jack, Razorback shovel & axe on Quickfist mounts, Cobra CB w/Firestik antenna, Yellow wire mod for 4Lo, URD y-pipe, 2.5" custom exhaust w/ Borla muffler, Viair portable air compressor, Kryptek Typhon seat covers, AJT dash knobs
    Took a drive in the mountains to clear my head
  15. Jan 10, 2021 at 3:46 PM
    IPNPULZ
    going to be fun!
    :thumbsup:
    Darkgoatracer[QUOTED] likes this.
  16. Jan 10, 2021 at 5:31 PM
    ilubtimmyhos
    ilubtimmyhos Brewer
    Adam
    Haymarket, VA
    2012 Blue Tacoma 4x4 Pre-Runner
    4x4 Conversion w/ FJ T-Case, King 2.5 Extended Travel Coilovers w/ JBA UCAs, King 12" 2.0 Smoothies w/ BAMF relocate in the rear, OME Dakar leaf pack, 4.56 gears w/ ARB air locker, Archive Hammer Hangers w/ crossbar brace, ARB Snorkel, Custom Bed cap w/ Roofnest Sparrow XL, Retrofit Headlights, Wrapped in 3M Satin Perfect Blue
    Man I have $1000 of UCAs to get selling!
  17. Jan 10, 2021 at 6:13 PM
    PyritePirateBill
    Bill
    Got to see my dad in the hospital for just a few minutes yesterday. Not gonna lie...it is hard to see the man, who has always been physically, emotionally, and spiritually strong and the backbone of your family all of his life, in that condition. But I held it in and kept telling him how good he's doing to recover and encouraging him to keep fighting. Doctors and therapists are still impressed with his improvement...just hard for me to see it since I hadn't been able to see him from the beginning of this.
    I'll be seeing him again tomorrow. Thanks again everyone for your thoughts & prayers!
    Y'all stay safe
  18. Jan 10, 2021 at 7:10 PM
    BTHawk
    BTHawk OFP
    Will
    Warrenton, VA
    2025 J250 LC Prado
    :rofl:
  19. Jan 10, 2021 at 8:17 PM
    LocoLocal
    LocoLocal Aspiring Polymath
    39.081221472127545, -77.45538862919935
    Large American
    Glad to read he is recovering. I’m just a text, call or message away if you all need anything.
  20. Jan 11, 2021 at 4:27 AM
    Tiny's Taco
    Shenandoah Valley
    He probably works for the people who named a bank 5/3rds.
