Northern Virginia Roll Call
Discussion in 'Virginia' started by r6hokie, Nov 17, 2011.
  1. Feb 18, 2021 at 4:54 AM
    Greg.Brakes.Tacos
    Greg.Brakes.Tacos Don't Feed the Animals
    Greg
    Between Richmond and Virginia Beach
    2017 Taco DCSB TRD off road
    wanna be mods
    The stock tinfoil plate? I think it was 12 and 14mm?
    I know many aftermarkets use stock 17mm up front and mid then the rear are 12mm.
    3pooches likes this.
  2. Feb 18, 2021 at 5:01 AM
    Darkgoatracer
    Darkgoatracer Well-Known Member
    Nick
    Northern VA
    2012 trd sport tacoma
    Stock
    I need the thread pitch for the two front ones i think. There a big bolt that goes in the bottom of the core support and a smaller bolt behind that.
  3. Feb 18, 2021 at 5:02 AM
    virginiamarine
    virginiamarine Well-Known Member
    Northern Virginia
    FJCruiser/Double cab Tacoma
    No more excuses, but I did email my office that due to icy conditions, I was delayed in getting from the bedroom to the home office!
    2016Taco4Me and Mojo Jojo like this.
  4. Feb 18, 2021 at 5:07 AM
    Greg.Brakes.Tacos
    Greg
    wanna be mods
    I think it's this (these are what I bought)
    JIS High-Strength Steel Flanged Hex Head Screw, M12 x 1.25 mm Thread, 35 mm Long
    https://www.mcmaster.com/95735A117
    EDIT: @Darkgoatracer the link is what I bought after breaking the factory one, but went shorter to work with the then SOS recovery point. The factory bolt was too long. M12x1.25 should work, just take the factory length into account.
  5. Feb 18, 2021 at 5:55 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    The four big ones up front are all the same size. Dunno the size of the top of my head but I know they’re the same.
    Greg.Brakes.Tacos likes this.
  6. Feb 18, 2021 at 7:10 AM
    virginiamarine
    Northern Virginia
    I have my factory skid and bolts in the bed of my truck.....will have to take a look later.
    EatSleepTacos[QUOTED] likes this.
  7. Feb 18, 2021 at 7:42 AM
    Hafaday
    Hafaday Well-Known Member
    Bill
    Richmond, VA.
    19, DCSB, Off Road. 23 KLX300, 14JKU
    Do it! I gots to know.
  8. Feb 18, 2021 at 7:59 AM
    PyritePirateBill
    PyritePirateBill Well-Known Member
    Bill
    North Myrtle Beach, SC
    2014 pyrite mica TRD Sport 4x4 AC
    OME 886 Nitrocharger lift, Dakar HD leaf pack, u-bolt flip kit, Bilstein b110 rear shocks, Wheeler's super bumps,18x9 Worx Havoc, 35/12.50/18 Nitto Ridge Grapplers, ENVE Grille with LED lightbar & raptor leds, ditch lights, 6k hid, tinted tails, AtTheHelm bed stiffeners, SOS Concepts rear bumper, Demello baja front bumper, Smittybuilt 9.5k winch, Mobtown weld-on sliders, AllPro IFS & transm. skid, Mobtown transfer case skid, led fogs, led lights in rear bumper, 54" Bulldog hi-lift jack, Razorback shovel & axe on Quickfist mounts, Cobra CB w/Firestik antenna, Yellow wire mod for 4Lo, URD y-pipe, 2.5" custom exhaust w/ Borla muffler, Viair portable air compressor, Kryptek Typhon seat covers, AJT dash knobs
    Wrap looks good! So they ceramic coat on top of the vinyl? Interesting. Does that make it last longer by protecting the vinyl like it does for paint?
    ...and front skid bolts are M12x1.25(with 17mm head) and M8x1.25(with 12mm head)
  9. Feb 18, 2021 at 8:18 AM
    Darkgoatracer
    Nick
    Northern VA
    Stock
    Thanks bill. Thats correct, its a ceramic pro vinyl base with a top coat. It works just like it would for paint. In my case i'm not worried about scratch resistance, just want it to be hydrophobic for easier cleaning.
  10. Feb 18, 2021 at 8:19 AM
    03dumdum
    03dumdum Well-Known Member
    JT
    White 2018 TRD OR
    Fox 2.5 rr, RCI front/mid skid JBA uca RCI rack iKamper Xcover AAL Ray 10 17x9 -38 Maxzis Razr AT 285-75r17 20% front windows & 5% strip on windshield Tactilian magnetic flags Weird engine squeal Custom pin strips.
    “35” (less than 3k miles)= 34
    275/70r17 (with less than 5k miles) = 31-ish
    285/70r17 (20k miles) = 32+ish
  11. Feb 18, 2021 at 8:21 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    In my experience, tires will measure about 1” shorter when mounted on the vehicle and under its own weight.
  12. Feb 18, 2021 at 8:25 AM
    ilubtimmyhos
    ilubtimmyhos Brewer
    Adam
    Haymarket, VA
    2012 Blue Tacoma 4x4 Pre-Runner
    4x4 Conversion w/ FJ T-Case, King 2.5 Extended Travel Coilovers w/ JBA UCAs, King 12" 2.0 Smoothies w/ BAMF relocate in the rear, OME Dakar leaf pack, 4.56 gears w/ ARB air locker, Archive Hammer Hangers w/ crossbar brace, ARB Snorkel, Custom Bed cap w/ Roofnest Sparrow XL, Retrofit Headlights, Wrapped in 3M Satin Perfect Blue
    Also depends if they are mounted on skinnier or wider wheels. Since we are usually use towards the wider side, they are usually shorter
    3pooches, Hafaday and 03dumdum like this.
  13. Feb 18, 2021 at 8:26 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Maybe. I went from a 7.5” wide to a 9” wide wheel and they measured the same on both wheels.
  14. Feb 18, 2021 at 8:32 AM
    Hafaday
    Bill
    Richmond, VA.
    Niiiiice.
    What they said. You could always measure them in a static state (not on vehicle) to see the difference as well.
    03dumdum[QUOTED] likes this.
  15. Feb 18, 2021 at 8:40 AM
    Mojo Jojo
    Mojo Jojo Well-Known Member
    Mark
    Harpers Ferry, WV
    2020 Pro AG MT, 1997 Land Cruiser
    Tacoma: mid-travel on 33s LC: 3.5” lift on 35s
    Interesting, I didn't know that. Just to add another data point, Wildpeak AT3 265/75/16: 31.6 calculated diameter vs 30.5" measured (just ran out to the garage to check)
    upload_2021-2-18_11-39-52.jpg.
  16. Feb 18, 2021 at 8:44 AM
    Hafaday
    Bill
    Richmond, VA.
    To keep this going. Air pressure will make a difference as well.
    hell, put a level across the top of the tire for the technical side of it. Then measure. Hehe.
  17. Feb 18, 2021 at 8:45 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Don’t mind us, just dropping knowledge bombs over here.
  18. Feb 18, 2021 at 8:48 AM
    Mojo Jojo
    Mark
    Harpers Ferry, WV
    Every once in a while I accidentally learn something!
    Stopped by on the way home this morning from dropping off my wife at the airport and made some donuts in the Food Lion parking lot. That shit never gets old.
  19. Feb 18, 2021 at 8:48 AM
    Hafaday
    Bill
    Richmond, VA.
    Hah ha. That, and setting in the work truck in the rain BORED off my ass.
  20. Feb 18, 2021 at 8:50 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Dude I feel you. I have a mildly sick baby passed out on my lap and I’m running out of ways to entertain myself. He’s a bit congested so he sounds like a pug right now.
