Northern Virginia Roll Call
Discussion in 'Virginia' started by r6hokie, Nov 17, 2011.
  1. May 19, 2021 at 3:50 PM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    I went hiking there last weekend
  2. May 19, 2021 at 7:24 PM
    BigMacMcCoy
    BigMacMcCoy Cajun In Vienna
    Braedon
    Vienna, VA
    Silver 2010 Tacoma Access Cab
    All the dumb choices in one vehicle
    A little research had me thinking I'd need to swap my fog lights for something DOT approved, fix that one tire that's rubbing on what's left of my cab mount, and do something about the TPMS light.
    Thanks man! We've got a place and reserved movers for early June. Now I've just got to get the truck there
  3. May 19, 2021 at 7:28 PM
    BigMacMcCoy
    Braedon
    Vienna, VA
    If it makes you feel better, I just bought some Hutchinson Rock Monsters and threw those on the truck. They retail for $500 each. Thankfully I got them used.
    Might have saved a few, but the extra work to replace two of the gaskets in them sucked.
  4. May 19, 2021 at 7:29 PM
    fatfurious2
    David
    Ashburn, VA
    I do not have DOT fogs and I have the anytime fog light mod/use my Baja Design Sports as DRL, the TPMS light has been on on my truck for at least 2 years. Might need to do something with the rubbing. Also probably depends on where you go for the inspection. Dont go to a dealership.
    I go here:
    1098 Elden St, Herndon, VA 20170
    BigMacMcCoy[QUOTED] likes this.
  5. May 19, 2021 at 7:31 PM
    fatfurious2
    David
    Ashburn, VA
    We have the same truck
  6. May 19, 2021 at 7:32 PM
    BigMacMcCoy
    Braedon
    Vienna, VA
    Thanks for the help! My last inspections were in MA before I did anything fun with the truck and it seems like VA is much less strict.
    This house we are renting will have a garage so I think it's time to do all the things I haven't done yet, like get a welder.
    fatfurious2[QUOTED] likes this.
  7. May 19, 2021 at 7:33 PM
    BigMacMcCoy
    Braedon
    Vienna, VA
    I should probably install my winch then they will really be twins!
  8. May 19, 2021 at 7:34 PM
    fatfurious2
    David
    Ashburn, VA
    Hopefully the truck fits in the garage. I have a 1 car garage, but no way my truck fits with my motorcycle and tools and other junk haha
  9. May 19, 2021 at 7:36 PM
    BigMacMcCoy
    Braedon
    Vienna, VA
    We've never seen the place so it likely won't fit. Big driveway though. It's in Vienna right outside the beltway.
    It'll be a huge step up from my current apartment and I'll be able to store tools somewhere besides in the truck.
  10. May 20, 2021 at 12:31 AM
    BTHawk
    BTHawk OFP
    Will
    Warrenton, VA
    2025 J250 LC Prado
    Randy, picked up the RXT locally here today. Was actually surprised they were in stock. Any tidbits of info for install that aren't in the online instructions? Is the downward facing clamp to the back or front? I am installing them at the Option 1 setting, so thankfully no tearing apart the leaf pack (yet). Pretty stoked...doing the install this weekend. Thanks again for the recommendation!
  11. May 20, 2021 at 3:32 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    The downward clamp is at the rear, front is the double wrap around the front bushing. As far as tips, torque all 3 bushings (2 leaf, 1 shackle) with the truck on the ground because of the rubber bushings. Bounce on the tailgate a couple of times before torquing as well.
    If you want an accurate way to measure before and after lift, measure from the top of the axle tube to the bottom of the frame rail. Stock is 8.25”
    Other than that, it’s pretty straight forward! Like any other leaf install.
  12. May 20, 2021 at 6:58 AM
    plamore
    plamore Well-Known Member
    Dave
    Fairfax, Virginia
    '18 TRD Offroad
    D-ring tow hitch insert (red)
    450 that's pretty reasonable! I will be asking you how it turns out..
    BTHawk[QUOTED] likes this.
  13. May 20, 2021 at 7:29 AM
    plamore
    Dave
    Fairfax, Virginia
    '18 TRD Offroad
    Ooooh what trail?!
  14. May 20, 2021 at 7:35 AM
    fatfurious2
    David
    Ashburn, VA
    Weverton Cliffs. Was short, and Im out of shape. But definitely fun
  15. May 20, 2021 at 7:52 AM
    plamore
    Dave
    Fairfax, Virginia
    '18 TRD Offroad
    thanks, I'll look it up!
    fatfurious2 likes this.
  16. May 20, 2021 at 10:26 AM
    Tiny's Taco
    Tiny's Taco The Wanderer
    Shenandoah Valley
    2018 Inferno TRD Sport
    That's a horrible idea. What time?
    :annoyed::annoyed::annoyed::annoyed::annoyed::annoyed::annoyed::annoyed:
    Rant over.
    We will now return you to your regularly scheduled programing.
  17. May 20, 2021 at 11:27 AM
    BTHawk
    BTHawk OFP
    Will
    Warrenton, VA
    2025 J250 LC Prado
    Thanks! I think I will actually be dropping a bit in height since I am removing the HD Dakars. I am running a 3 degree shim currently with the Dakars, hopefully I won't need it with the new pack. Did you run the stock mini shim that comes with the OEM pack with your RXTs?
    Haha, hopefully I don't screw it up! :D It will be a while, though. I'd rather have a better suspension setup right now than the tune, and unfortunately there is only so much money to go around.
    Well, we're waiting! :popcorn:
  18. May 20, 2021 at 11:53 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Nope! No shims for this guy.
  19. May 20, 2021 at 1:35 PM
    Darkgoatracer
    Darkgoatracer Well-Known Member
    Nick
    Northern VA
    2012 trd sport tacoma
    Stock
  20. May 20, 2021 at 2:06 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I like that a lot more than your previous bumper. Fits the new build perfectly.
    Darkgoatracer[QUOTED] likes this.
