Northern Virginia Roll Call
Discussion in 'Virginia' started by r6hokie, Nov 17, 2011.
  1. Jun 27, 2021 at 1:40 PM
    LocoLocal
    LocoLocal Aspiring Polymath
    39.081221472127545, -77.45538862919935
    Large American
    Im ditching the old switch for a smaller one to get some clutter off the bars. Putting on a momentary push button that’s smaller to flip between high and low beams. Only one gets power at a time with the headlight Im using (ETA: that may not be true, but at least only one is illuminated). Everything is all wired up and ready to go I just need the relay. It is a double pole (double throw?). I know that Drag Specialties one off of Dennis Kirk will work I’d just rather save $30 (I’m cheap) if there’s another alternative. I’m wondering if the difference in the way the terminals are labeled (56 vs 85, etc.) means anything.
  2. Jun 27, 2021 at 2:17 PM
    crashdb
    crashdb I break chainsaws
    Dave
    Manassas, VA
    2008 Toyota Matrix
    Rollin' hydrocarbons!
    @BTHawk got the Valley Tune in. There's step by step under resources on OV's site. Can't really comment on the tune yet. Charging voltage is higher so AGM batteries are getting what they need. And tip in is pretty strong. I've got a road trip on Tuesday. Will hopefully know more by then.
    Greg.Brakes.Tacos and Hafaday like this.
  3. Jun 27, 2021 at 2:23 PM
    Hafaday
    Hafaday Well-Known Member
    Bill
    Richmond, VA.
    19, DCSB, Off Road. 23 KLX300, 14JKU
    Thought so. I caught it out of the corner of my eye. Come to think of it… the one I saw may have been silver (sun glare off it). Wasn’t sure if you derp’d your wheels or anything.
  4. Jun 27, 2021 at 2:37 PM
    BTHawk
    BTHawk OFP
    Will
    Warrenton, VA
    2025 J250 LC Prado
    Did you go with standard or light? My cable doesn't get to me until Thursday this week, so I am doing the tune over the 4th of July weekend. I was going to go with standard initially. Hopefully the tip-in is less than what the kdmax one was...
  5. Jun 27, 2021 at 3:10 PM
    crashdb
    Dave
    Manassas, VA
    2008 Toyota Matrix
    Standard with regular gas.
  6. Jun 27, 2021 at 3:23 PM
    y=mx+b
    y=mx+b Station Wagon
    Lafayette, IN
    '05 T4R SR5 v6 4wd
    I was at the pleasants hardware on 301 this morning though so I was pretty close
  7. Jun 27, 2021 at 3:38 PM
    velogeek
    velogeek Well-Known Member
    Andrew
    Gilbert, AZ
    2024 4Runner
    Honestly, buy the DK relay. Looking at that diagram again it appears the splice and all is interior to the relay so that and the pin layout are totally proprietary and something you'll never find in a standard relay. That also means the two should actually both be on with the high beams with how the DK relay is designed. I would use a voltmeter and check for voltage at both headlight pins when you have the relay energized.
    Otherwise if you want to simplify with a standard ISO relay and the two really aren't on together, I can talk you through how to rewire it. It would actually be very straightforward if the two lights really aren't on together.
    LocoLocal[QUOTED] likes this.
  8. Jun 27, 2021 at 4:50 PM
    LocoLocal
    Large American
    I appreciate that! Let me get it wired up to the old switch without the relay and see how it lights up.
  9. Jun 27, 2021 at 7:44 PM
    y=mx+b
    Lafayette, IN
    '05 T4R SR5 v6 4wd
    changed rear pads on the 4runner this weekend and noticed they had Toyota logos on them. Last time this 4runner was at a dealer for maintenance was 108k miles, so at 230k now, that means we got a good 120k out of these lol
    Z8HXI8aa23pzQ1HeoLVs9Y3rMFpMLgjRuBZE1HwC_bdbb191478ed574ecbebcc50a7a86d616d5a0623.jpg
    Pretty much sucked all possibly life out of these. Still hadn't burned through the whole pad and rotor was in good shape
    2o8zO-9TOKLHoWYrtsN7BAxJADaSR4EOP4RFeajK_9f8888bdc65e6ccc34db14dea48dfee920549673.jpg
    Hafaday, 3pooches, 03dumdum and 6 others like this.
  10. Jun 28, 2021 at 7:10 AM
    CherokeeCajun
    CherokeeCajun Well-Known Member
    KJ
    Oklahoma City
    2017 - MGM - Sport - 4x4
    Glad I stumbled on this. Was thinking about pulling the trigger on the Mt Baker. I like that it doesn’t swing out to the side and looks legit for the price. What’s your review? Cheap for a reason?
  11. Jun 28, 2021 at 7:51 AM
    Greg.Brakes.Tacos
    Greg.Brakes.Tacos Don't Feed the Animals
    Greg
    Between Richmond and Virginia Beach
    2017 Taco DCSB TRD off road
    wanna be mods
    I thought it was more points for bumping a fellow racer into the fence post!?!?!:burnrubber:
    WTF Dave?!?!?! I thought it was bad loosing a one lug and 4 of the other 5 only having a few, at best, threads left on the lugs...you've set the bar and I'll never hope to best it!
    It would appear to be a wise investment!:anonymous: But I've also seen this bad larry on some tool you tube channels...
    Damn these incidents, glad you're ok!
  12. Jun 28, 2021 at 3:07 PM
    Tiny's Taco
    Tiny's Taco The Wanderer
    Shenandoah Valley
    2018 Inferno TRD Sport
    That's a horrible idea. What time?
    Well, it's here. And it's a beast.. Now to get it on the other end of the truck!
  13. Jun 28, 2021 at 3:18 PM
    TaKoToy
    TaKoToy Well-Known Member
    Robbie
    Prince George VA
    2013 4x4 OffRoad, 2020 cement DCLB OR
    Mostly stock
    I think they sold me the last run of a poorly designed abs shell. The new ones have a different shell. From what I can tell water was collecting in the four troughs and either magnifiying and melting or freezing and cracking the abs. If the new design holds water anywhere I wouldn't buy it. It also faded horribly. before I painted it I pulled the CVT sticker off in the bottom photo
    Greg.Brakes.Tacos likes this.
  14. Jun 28, 2021 at 3:23 PM
    TaKoToy
    Robbie
    Prince George VA
    Mostly stock
    Yup I just looked at CVTs website. The Mt Baker that is on it now is totally different. They knew they sold me a piece of shit ...... The shell, the sides, and the frame is totally redesigned.
    CherokeeCajun[QUOTED] likes this.
  15. Jun 28, 2021 at 4:30 PM
    y=mx+b
    Lafayette, IN
    '05 T4R SR5 v6 4wd
    Pro tip, clean your radiator fins lol
    Fronts weren't hung up like I thought. They did stick the pads to the rotors pretty good when I left it after not finishing my suspension, so I assumed pistons got stuck or something and that was stressing drivetrain. Turns out it was just a metric ton of mud lol.
    BnHlaDqf1apoOLfGUn4JjCksQrxvIcQEwO-swutJ_1b42c240f1a965e4f1d82eb3137558c858e05293.jpg 64zi2KlSzCRqnCEwydh8ecYhbWJM4NwgqzPu-_gz_46ad8a3b97792df7f4cd30883999a655a99caaa4.jpg
    CJEi3NICD_C3J0dq722mlFCDvdh84jd9sJCofm3z_f85bd87428e9e98a16010a3d93f3ff8ea6ace291.jpg
    Took shroud off and back flowed the water
    c7WTL9qib3RyNaSLUKSH7IfvHCLgOnRyHd6rMb4X_0455a6f307a330ccadc5b4032d3c6ba316240f4e.jpg
    All Clean!
    oisip7Ife0QTNzd3FGJcSoem6NQE8FEaMCu7B2tQ_d71d40960d60fc67375e0fc2b12eb1e6e608f83e.jpg
    rTHNhYqrpGga7fE-J74BAwwEAHPil_0e_kPcj0LE_fec42ca77060d045639d269345c1b7e09d0cefae.jpg
    Still have a trans cooler on the way too, but jeff bezos has managed to misplace that
  16. Jun 28, 2021 at 4:34 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    When I accidentally drilled a hole in my radiator and had to replace it, I was astounded at how dirty the old one was. I was also impressed how much cooler my truck ran after putting the new one in. A solid 20° cooler, unsurprisingly.
  17. Jun 28, 2021 at 4:38 PM
    y=mx+b
    Lafayette, IN
    '05 T4R SR5 v6 4wd
    Seems between the condenser and the front of the radiator is a good place for junk to hide. Radiator wasn't that dirty when I replaced the condenser in may, so I guess sleepy creek really did it in
  18. Jun 29, 2021 at 6:35 PM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    So you're telling me I don't need this fancy piece?
  19. Jun 29, 2021 at 6:40 PM
    y=mx+b
    Lafayette, IN
    '05 T4R SR5 v6 4wd
    ohh very fancy. My 4runner just needed a little help brushing its teeth
    fatfurious2[QUOTED] likes this.
  20. Jun 29, 2021 at 6:42 PM
    fatfurious2
    David
    Ashburn, VA
    Been dragging my feet doing stuff in this heat.
    Its been sitting in my pile of parts for a couple months. Along with these:
