Northern Virginia Roll Call
Discussion in 'Virginia' started by r6hokie, Nov 17, 2011.
  1. Aug 31, 2021 at 12:38 PM
    Tiny's Taco
    Tiny's Taco The Wanderer
    Shenandoah Valley
    2018 Inferno TRD Sport
    That's a horrible idea. What time?
  2. Aug 31, 2021 at 12:40 PM
    y=mx+b
    y=mx+b Station Wagon
    Lafayette, IN
    '05 T4R SR5 v6 4wd
    In hindsight, they look easier than I was making it out to be in my head. I do like the minimum offset possible to keep scrub radius low
    EatSleepTacos[QUOTED] likes this.
  3. Aug 31, 2021 at 12:45 PM
    crashdb
    crashdb I break chainsaws
    Dave
    Manassas, VA
    2008 Toyota Matrix
    Rollin' hydrocarbons!
    There is no way that thing can spread anything beyond seed or fertilizer. I have the name brand version of that, and I don't think dirt would even fit through the slot or break it up if it was clumpy.
    Tractor Supply has manure spreaders. I would get one, but I can't find anyone that has successfully used it for compost or top soil. The one that TS sells got bead reviews, but I found its equivalent and it's $1700. Expensive risk. I can check Southern States, but I imagine it's about the same story.
    I checked Sunbelt again and no dice. United, etc.
  4. Aug 31, 2021 at 12:49 PM
    crashdb
    Dave
    Manassas, VA
    2008 Toyota Matrix
    y=mx+b[QUOTED] likes this.
  5. Aug 31, 2021 at 12:49 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    You can definitely handle it. You just smack the old one out with a hammer, slip the new one in, stack some washers over it, then a lugnut, and tighten it by hand. That pulls it into the hub. They also make tools you can use instead of a stack of washers.
    https://www.amazon.com/Lisle-22800-...keywords=stud+installer&qid=1630439341&sr=8-7
  6. Aug 31, 2021 at 12:50 PM
    crashdb
    Dave
    Manassas, VA
    2008 Toyota Matrix
  7. Aug 31, 2021 at 12:50 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    y=mx+b likes this.
  8. Aug 31, 2021 at 12:54 PM
    crashdb
    Dave
    Manassas, VA
    2008 Toyota Matrix
    And last a lifetime!
    y=mx+b likes this.
  9. Aug 31, 2021 at 1:24 PM
    y=mx+b
    Lafayette, IN
    '05 T4R SR5 v6 4wd
    Yeah I was thinking about the rear for some reason and having to deal with the hybrid disk/drum thats back there. The fronts hopefully they slip behind the wb without having to take them off, but I've also done that and its not bad.
    I have a whole set of 24 extra oem lug nuts that came with the 5th gen trail wheels, so I can use one and some washers. And if I screw one up, there are 23 more to mess up lol
  10. Aug 31, 2021 at 1:26 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    That’s exactly what I did, used some old oem style lug nuts I don’t need anymore. Worked well.
  11. Aug 31, 2021 at 1:31 PM
    crashdb
    Dave
    Manassas, VA
    2008 Toyota Matrix
    What ever method you choose, just be sure you use lots of grease. You can do a job on the threads otherwise. And if for some reason you can't feed the stud through the back of the hub grinding a flat into the seat works wonders.
  12. Aug 31, 2021 at 1:38 PM
    y=mx+b
    Lafayette, IN
    '05 T4R SR5 v6 4wd
    yep, will do!
    Fun fact: when you're torqing a bolt like lug nuts, around 60-90% of the force you're applying is lost to overcoming friction in the threads and head. Only the remaining small percentage goes toward stretching the stud/bolt, which is where the clamping force comes from.
    crashdb[QUOTED] likes this.
  13. Aug 31, 2021 at 3:31 PM
    Mr. Projekt
    Mr. Projekt Well-Known Member
    Caleb
    Harpers Ferry, WV
    2021 DCLB TRD-OR 4x4 Army Green
    if they have it, if you put me as the "pick-up person" I can pick it up (it's less than 10 min from my house) and I can meet you closer. I work in Reston/Herndon every day.... just tossing out the offer
    the.sight.picture likes this.
  14. Aug 31, 2021 at 3:52 PM
    03dumdum
    03dumdum Well-Known Member
    JT
    White 2018 TRD OR
    Fox 2.5 rr, RCI front/mid skid JBA uca RCI rack iKamper Xcover AAL Ray 10 17x9 -38 Maxzis Razr AT 285-75r17 20% front windows & 5% strip on windshield Tactilian magnetic flags Weird engine squeal Custom pin strips.
    ***Random stupid question I’m trying to solve without google. ***
    You have a 20 acre lot that is “flat”. Say it takes you 2 mins to drive across at a set MPH. Let’s say you then proceed to make a huge mountain (100 ft high, starts sloping upward at each end to the peak in the middle) on said 20 acres. My initial though is that going up and down hypothetical “mountain”, across 20 acres at the same speed would take longer than 2 mins. If that theory is correct, does it mean your acreage would also increase?
    nguyenpatrickt likes this.
  15. Aug 31, 2021 at 3:56 PM
    y=mx+b
    Lafayette, IN
    '05 T4R SR5 v6 4wd
    Would depend if acreage is measured by the footprint of land or the or the surface area.
    I'd think they would measure by the footprint, because measuring the true surface area would result in the same issue as the infinite coastline paradox
    EatSleepTacos likes this.
  16. Aug 31, 2021 at 4:09 PM
    Mr. Projekt
    Caleb
    Harpers Ferry, WV
    I'm too stupid to talk distance... but I assume as long as your speed remains the same and the distance remains the same you'd get there in the same amount of time.
    however, I know your acreage would not increase as the acres are measured by square feet (43,560 sq ft). so regardless of elevation changes, you'll still have the same square footage despite your volume of soil increasing.
  17. Aug 31, 2021 at 4:11 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I dislike that paradox because a coastline is finite in the truest sense
  18. Aug 31, 2021 at 4:52 PM
    buyobuyo
    buyobuyo Read The Fucking Manual
    Jeremy
    Camden, AR
    08 PreRunner SR5, I4, Manual, Silver
    A thing or two...
    Acreage stays the same because it is the area defined by the property corners. You're not changing the boundaries of the property.
    It will take longer to travel end to end because you're going up/down the hypotenuse of two triangles instead of across flat ground.
    Hafaday, y=mx+b and the.sight.picture like this.
  19. Aug 31, 2021 at 5:13 PM
    03dumdum
    JT
    White 2018 TRD OR
    So an acre = 43560 sq ft.
    Does this mean you can have more than 43650 sq ft within an acre?
    Thanks for the input everyone, I love trying to figure out useless things that pop into my head. If not I’d be up all night wondering. Also spotted another sweet taco today in Fburg.
    Hafaday, Greg.Brakes.Tacos and y=mx+b like this.
  20. Aug 31, 2021 at 5:14 PM
    Tiny's Taco
    Shenandoah Valley
    I wondered about the hole being big enough on that. I can look around tomorrow a bit more. We have some farmers at church, but I think there stuff would be way too big.
