Northern Virginia Roll Call
Discussion in 'Virginia' started by r6hokie, Nov 17, 2011.
  1. Sep 30, 2021 at 7:29 PM
    ilubtimmyhos
    ilubtimmyhos Brewer
    Adam
    Haymarket, VA
    2012 Blue Tacoma 4x4 Pre-Runner
    4x4 Conversion w/ FJ T-Case, King 2.5 Extended Travel Coilovers w/ JBA UCAs, King 12" 2.0 Smoothies w/ BAMF relocate in the rear, OME Dakar leaf pack, 4.56 gears w/ ARB air locker, Archive Hammer Hangers w/ crossbar brace, ARB Snorkel, Custom Bed cap w/ Roofnest Sparrow XL, Retrofit Headlights, Wrapped in 3M Satin Perfect Blue
    So the hubs work differently in the rear? Didn't know that. Learn something new. Figure it would be bad to roll it, but not just lower it.
  2. Sep 30, 2021 at 7:31 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Correct, our fronts would be similar to a full float axle. In a full float, you could simply slide the axle shaft out and be on your way if you were to break it off-road.
    Lowering nicks truck down on its weight, idk if that would damage anything. But knowing nicks track record as well as the cost to replace rear wheel bearings, he should play it safe.
  3. Sep 30, 2021 at 7:49 PM
    CTtoNoVa
    CTtoNoVa Well-Known Member
    2017 DCSB TRD OR Magnetic Gray
    Pop N Lock
    47592363-196E-4B14-9A85-725C157AE2A1.jpg Ugh, I was just under the hood and I noticed that the CAI cover wasn’t 100% sealed. Towards the back right it wasn’t pushed snug to the clips and you could see maybe 1/4 or 1/8 inch of the red filter trim. I had taken it to jiffy lube and they always take the damn filter out to try to up charge me and didn’t put it back properly. Any thoughts on if this could had done any damage or am I being paranoid? Since the oil change I have almost been exclusively on paved roads with little dirt. Here is a stock picture of the air intake properly seated for reference above.
    Don’t roast for going to jiffy lube or having the CAI :)
  4. Sep 30, 2021 at 9:07 PM
    crashdb
    crashdb I break chainsaws
    Dave
    Manassas, VA
    2008 Toyota Matrix
    Rollin' hydrocarbons!
    Yeah. Off the Silverado. Maybe I'll save them for the Tacoma.
    LocoLocal likes this.
  5. Oct 1, 2021 at 5:22 AM
    Mr. Projekt
    Mr. Projekt Well-Known Member
    Caleb
    Harpers Ferry, WV
    2021 DCLB TRD-OR 4x4 Army Green
    For me, personally, the T700 was too big to do dirt bike stuff.... it was a fantastic road bike though (although the OEM seat sucked).
    I drove 3 hours to Tyrone, PA to pick my T7 up for MSRP ($9995).... put 1,500 miles on it and sold it for $12,000 locally (granted I put about $1200 of accessories on it) so I call it a net break even.
    for me, I wanted a bike that was street legal, but was lightweight enough to do single track trails and flat track all w/ a pricepoint that I wasnt scared of thrashing it.... I've got 300 miles on the little Hawk 250 DLX and couldnt be happier with it
    However, if you want more of a "road orientated" dual sport bike.... for $5k, I think the CSC RX4 (450cc) is the best bang for your buck
    https://cscmotorcycles.com/2021-rx4-adventure/
    turn-key ADV bike that you can ride all day on the highway.
    3pooches and Hafaday[QUOTED] like this.
  6. Oct 1, 2021 at 12:03 PM
    Hafaday
    Hafaday Well-Known Member
    Bill
    Richmond, VA.
    19, DCSB, Off Road. 23 KLX300, 14JKU
    Thanks for the reply..
    an ADV bike for me will not see proper use as an ADV Bike, hence the more dirt oriented 300 series. I could go back to the DRZ but want to change up this time around. I have no problem trailering the scooter to the hills for an all day ride. Done it many a time before.
    3pooches likes this.
  7. Oct 1, 2021 at 12:55 PM
    Mr. Projekt
    Caleb
    Harpers Ferry, WV
    yep, I totally get that. same reason I got rid of the T7
    I may end up adding an Orion RXB 250 at some point just for fun.... but the thought of a carb scares me to death. haha I have no clue how to work on them since I didnt grow up riding
    Hafaday[QUOTED] and 3pooches like this.
  8. Oct 1, 2021 at 12:58 PM
    crashdb
    Dave
    Manassas, VA
    2008 Toyota Matrix
    They're not at all bad. And you shouldn't have to do any messing with it. Maybe adjust a mixture screw. And jet kits are super easy too.
    Hafaday likes this.
  9. Oct 1, 2021 at 1:20 PM
    3pooches
    3pooches Well-Known Member
    VA & WV
    15 tacoma dcsb Sc Linked, 2014 reg cab locked
    This post is full of lies
  10. Oct 1, 2021 at 1:39 PM
    Gen3TacomaOBX
    Gen3TacomaOBX Well-Known Member
    S
    2018 Tacoma DCSB SR 4x4
    Bilstein 6112 front / 5100 rear (extended) shocks, Headstrong AAL, Firestone airbags, 4.88 gears, OME Carrier bearing drop kit, Aluminum 1/4" skids (engine to transfer). Custom sliders (1.75" HREW tube w/ 3/16" base plates). Custom front bumper and high clearance rear bumper (1/4" steel plate, 1.75" tube.) Apex 5500 winch w/synthetic line (36lbs) and required accessories for an underpowered winch (snatch blocks and extra line.) Tekonsha P3 brake controller, remote start, any-time-backup camera w/ front facing camera, Leer 100R shell (w/e-track single slot tie-down mounts for removable Yakima EasyTop.) Cat shields by CaliRaised. Husky liners, window tint, heated seat (passenger only.) Relentless bed rail brackets with QuickFists (shovel/axe/fire extinguisher.) Hondo Garage Un-holey vent mount. Anytime rear with front facing camera. Billet front seat risers. Viair 88p. 265/75r16 Goodyear Ultra-terrain tires.
    Sucking a little unfiltered air through a 1/4" gap isn't going to do any damage to the cylinders unless you were hooning in the dunes.
    Jiffy Lube, damn. Do you play Russian roulette with barbers too? Fortunately a bad haircut only lasts a month or two. A shaitty maintenance job can last the rest of your truck ownership. I understand that there are some quick lube places with versed/skilled staff.. but I do not think it is the norm.
  11. Oct 1, 2021 at 1:49 PM
    CTtoNoVa
    Pop N Lock
    so I’ve been on the fence about changing it myself because I want the service record. I change the oil myself in my other cars but they’re old and have accidents on the title so I don’t really care. If you all change your oil, how do you best document it to prove you changed it? I’ve heard people ripping a piece of the filter box off and writing the mileage and date… seems compelling enough in a private sale at least…
    Edit: it was probably like that for a couple thousand miles too
  12. Oct 1, 2021 at 1:54 PM
    3pooches
    VA & WV
    I’ve never been to the dunes, but mine could probably suck a squirrel through a 1/4 gap.
  13. Oct 1, 2021 at 1:56 PM
    3pooches
    VA & WV
    I was told to keep my receipts showing oil and filter purchases since they are dated.
  14. Oct 1, 2021 at 2:13 PM
    CTtoNoVa
    Pop N Lock
    Oh that’s a good idea.
    3pooches[QUOTED] likes this.
  15. Oct 1, 2021 at 2:17 PM
    Mr. Projekt
    Caleb
    Harpers Ferry, WV
    dont you have to jet according to altitude? and tuning it sounds like a nightmare, changing out main jets vs pilot jets etc.. sounds like a chore. haha
    I do all of my own maintenance / repairs and I just use the "AUTOsist" app on my phone... allows for a photo upload (receipt) and a description of what you did for all service records so you can easily access it anytime.... never had a dealer complain (gotten quite a few compliments about organization and level of detail)
  16. Oct 1, 2021 at 2:37 PM
    crashdb
    Dave
    Manassas, VA
    2008 Toyota Matrix
    Yes and no. Hopefully there's a kit floating around where someone has already done all the work.
    Hafaday likes this.
  17. Oct 1, 2021 at 3:29 PM
    Mr. Projekt
    Caleb
    Harpers Ferry, WV
    that's the problem w/ chinese bikes.... they arent as common / popular as japanese bikes... so you'll have an idea where to start, but will have to fine-tune it yourself
    Hafaday likes this.
  18. Oct 1, 2021 at 4:15 PM
    Greg.Brakes.Tacos
    Greg.Brakes.Tacos Don't Feed the Animals
    Greg
    Between Richmond and Virginia Beach
    2017 Taco DCSB TRD off road
    wanna be mods
    Had some fun fixing the common gravel road today...the first few passes were rough and very slow, but the next few passes were much easier going.
    3pooches and Hafaday like this.
  19. Oct 1, 2021 at 4:49 PM
    Hafaday
    Bill
    Richmond, VA.
    :thumbsup: More bikes, = more better. and a carb is a carb.
  20. Oct 1, 2021 at 4:52 PM
    Mr. Projekt
    Caleb
    Harpers Ferry, WV
    I could not agree more with the first half of that statement.
