Northern Virginia Roll Call
Discussion in 'Virginia' started by r6hokie, Nov 17, 2011.
  1. Feb 27, 2017 at 5:37 AM
    Coot83
    Coot83 DORKEL NATION
    Scottsdale, Az
    2012 Baja TX
    TC 3.5 LT, RCV axles, Demello sliders, BD light bar/fogs, LP6, DMZ rear, SOS skids, custom bumper, King 16" triples, Locked-on hydro rear bumps...
    I think the 285s are also a heavier tire on the pavement so they will likely take a bigger hit to mileage if that is a factor outside of the needed cab chopping. @Lots2Learn58 has the 255 BFG MTs so he can chime in better here.
    Coot
  2. Feb 27, 2017 at 5:41 AM
    jschona1
    jschona1 Well-Known Member
    Jeff
    Loudoun County
    A Corolla...
    Whenever I get around to a lift, I'd like to avoid chopping anything. Are the 255s going to be the only way to go? Are there any big advantages or disadvantages between the 255s and 285s?
  3. Feb 27, 2017 at 5:42 AM
    TacoFMS
    TacoFMS Bubble bubble bubble pop
    Justin
    Louisa County, VA
    Just a vehicle to take trash to the dump
    One or two things modded... Check out the build thread
    You are guessing quite low.
    Coot83[QUOTED] likes this.
  4. Feb 27, 2017 at 5:43 AM
    Coot83
    Scottsdale, Az
    2012 Baja TX
    SHEEEEEEET.
    Coot
  5. Feb 27, 2017 at 5:45 AM
    TacoFMS
    Justin
    Louisa County, VA
    Imho a regear for 33's (or 32.5's which is more along what most 285's run) is a complete waste of funds. Sure it gives more bottom end, but honestly it's way overkill. It's like buying full lt to cruise the mall with...
  6. Feb 27, 2017 at 5:45 AM
    Coot83
    Scottsdale, Az
    2012 Baja TX
    If you don't want to chop, then go 255's. They are a skinnier tire and are 33.1 inches vs the 285s are wider which is why you need to trim the cab mounts and are 32.8 inches in height. Its up to you...I went LT so I had to chop regardless to not blow up.
    Coot
  7. Feb 27, 2017 at 5:55 AM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    I'm leaning toward 255 and have noticed that the choices are severely limited vs 285s.
    ready6delta and Coot83 like this.
  8. Feb 27, 2017 at 5:57 AM
    Coot83
    Scottsdale, Az
    2012 Baja TX
    ready6delta and TacoCat like this.
  9. Feb 27, 2017 at 6:00 AM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    I have a quote email out to ECGS right now. Just for gears and no air lockers. I have seen others done for $1900. So thats what I am aiming for.
    Sure, ill help! I just did my pads a couple weeks ago. My rotors were still in good condition.
    How..? With no lockers, that seems about right. Probably not 1600, but closer to 2000.
  10. Feb 27, 2017 at 6:56 AM
    TacoFMS
    Justin
    Louisa County, VA
    If you get the TW discount gears only are right at the 2k mark plus tax. But who wants to just do gears? If you are going to open up 3rd members might as well throw a locker or 2 in.
  11. Feb 27, 2017 at 7:06 AM
    TacoCat
    TacoCat These pretzels are making me thirsty
    Johnny-5
    Chantilly, VA
    25 Crosstrek Premium CVT (first ever automatic!)
    Having someone pumping the brakes while the bleeder valve is open is easiest. A third person up front to keep an eye on the brake resi is even better. If i was ever able to get a hold of the mongoose cable, the techstream will do that for you if i remember correctly.
    Coot83 likes this.
  12. Feb 27, 2017 at 7:14 AM
    fatfurious2
    David
    Ashburn, VA
    I just got off the phone with Steven at ECGS. He quoted me $1875 installed for 4.56 front and rear. If I wanted the front locker installed its an additional $875, with no more labor. :D:D:D
    Remember I have the e-locker rear already
    ready6delta, 16Tacos and boogie3478 like this.
  13. Feb 27, 2017 at 7:22 AM
    TacoCat
    Johnny-5
    Chantilly, VA
    Not bad. Maybe you shoulda held off changing the diff fluids then if you are heading down there in a couple months
    fatfurious2 and Coot83 like this.
  14. Feb 27, 2017 at 7:24 AM
    TacoCat
    Johnny-5
    Chantilly, VA
    @fatfurious2 i am gonna hold off doing the coilover install for now. Either spring when it warms up or ill sell, still not 100% either way. If you want help with your spark plugs you can stop by tomorrow. Theyre pretty easy so it shouldn't take long.
    fatfurious2 likes this.
  15. Feb 27, 2017 at 7:32 AM
    DOUBLLD
    DOUBLLD Well-Known Member
    Daniel
    Bluemont, VA
    05 Tacoma LS Swap Twin Turbo
    Alot
    is that to regear? or is it the pumpkins you swap in?
  16. Feb 27, 2017 at 7:36 AM
    TacoFMS
    Justin
    Louisa County, VA
    You don't think 4.56 is going to be over geared for 33's?
    Lot of guys run 4.56 for 35's.
    Coot83 likes this.
  17. Feb 27, 2017 at 7:36 AM
    TacoFMS
    Justin
    Louisa County, VA
    Regear
  18. Feb 27, 2017 at 7:39 AM
    DOUBLLD
    Daniel
    Bluemont, VA
    Alot
    dang if yall get the parts and hand me the diffs i could do it.
  19. Feb 27, 2017 at 7:40 AM
    Coot83
    Scottsdale, Az
    2012 Baja TX
    Hmmmmmmm......that would be WAY more ideal instead of having to spend two days commuting back from ECGS David.
    Coot
    boogie3478 likes this.
  20. Feb 27, 2017 at 7:41 AM
    fatfurious2
    David
    Ashburn, VA
    Its the front and rear gears, I think in a different casings.
    4.56 for 33s, 4.88 for 35s. I have no plans of doing 35s
