Northern Virginia Roll Call
Discussion in 'Virginia' started by r6hokie, Nov 17, 2011.
  1. Apr 12, 2017 at 7:26 AM
    Coot83
    Coot83 DORKEL NATION
    Scottsdale, Az
    2012 Baja TX
    TC 3.5 LT, RCV axles, Demello sliders, BD light bar/fogs, LP6, DMZ rear, SOS skids, custom bumper, King 16" triples, Locked-on hydro rear bumps...
    YASSS
  2. Apr 12, 2017 at 7:27 AM
    ilubtimmyhos
    ilubtimmyhos Brewer
    Adam
    Haymarket, VA
    2012 Blue Tacoma 4x4 Pre-Runner
    4x4 Conversion w/ FJ T-Case, King 2.5 Extended Travel Coilovers w/ JBA UCAs, King 12" 2.0 Smoothies w/ BAMF relocate in the rear, OME Dakar leaf pack, 4.56 gears w/ ARB air locker, Archive Hammer Hangers w/ crossbar brace, ARB Snorkel, Custom Bed cap w/ Roofnest Sparrow XL, Retrofit Headlights, Wrapped in 3M Satin Perfect Blue
    Im going half to sling an RTT up by myself if i go home soon
  3. Apr 12, 2017 at 7:28 AM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    I was told no, by High Tech. But maybe ask them..
  4. Apr 12, 2017 at 7:28 AM
    Coot83
    Scottsdale, Az
    2012 Baja TX
    Well damn son. PICS!
  5. Apr 12, 2017 at 8:22 AM
    Mr. Projekt
    Mr. Projekt Well-Known Member
    Caleb
    Harpers Ferry, WV
    2021 DCLB TRD-OR 4x4 Army Green
    it says my tires are out for delivery!!!
  6. Apr 12, 2017 at 8:26 AM
    ilubtimmyhos
    ilubtimmyhos Brewer
    Adam
    Haymarket, VA
    Yes! I'm excited to take the old ones off your hands!
  7. Apr 12, 2017 at 8:26 AM
    fatfurious2
    David
    Ashburn, VA
    use C&C auto for mount and balance
  8. Apr 12, 2017 at 8:27 AM
    Mr. Projekt
    Caleb
    Harpers Ferry, WV
    for sure! I'm excited to see how they look on yours
  9. Apr 12, 2017 at 8:27 AM
    Mr. Projekt
    Caleb
    Harpers Ferry, WV
    where are they located? somewhat close to us?
  10. Apr 12, 2017 at 8:29 AM
    fatfurious2
    David
    Ashburn, VA
    10 min. Near Dulles Town Center Mall/Best Buy in Sterling. Also @DOUBLLD shop is next to it.
    45661 Woodland Rd
    Sterling, VA 20166
    ready6delta likes this.
  11. Apr 12, 2017 at 8:30 AM
    Mr. Projekt
    Caleb
    Harpers Ferry, WV
    Nice! I'll call and see if they have anything open on Saturday
    fatfurious2[QUOTED] likes this.
  12. Apr 12, 2017 at 8:31 AM
    Coot83
    Scottsdale, Az
    2012 Baja TX
    YASSS
  13. Apr 12, 2017 at 8:34 AM
    Mr. Projekt
    Caleb
    Harpers Ferry, WV
    Coot83[QUOTED] likes this.
  14. Apr 12, 2017 at 8:35 AM
    Coot83
    Scottsdale, Az
    2012 Baja TX
    YASSSSSSSSSSSSSSSSS
    ilubtimmyhos likes this.
  15. Apr 12, 2017 at 9:45 AM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    They better than High-Tech in Chantilly?
  16. Apr 12, 2017 at 9:51 AM
    fatfurious2
    David
    Ashburn, VA
    Im not exactly sure. They are more of a general automotive shop. Whereas High-Tech, in my opinion, is more of an off road/lifted trucks shop, although they can do general automotive too
  17. Apr 12, 2017 at 9:56 AM
    Mr. Projekt
    Caleb
    Harpers Ferry, WV
    i am probably going to go w/ C&C to get mounted / balanced.... but go to High-Tech for the actual alignment post lift.
    now: question for you guys.... when I did my lift on the 4Runner(s), I just pried the LCA down and put the coil in....but I see in all of the Low Range Offroad videos, they loosen the LCA bolts and it swings down.....
    which would be easier for my Taco?
  18. Apr 12, 2017 at 10:00 AM
    Coot83
    Scottsdale, Az
    2012 Baja TX
    I disconnected the spindle towards the top so the uca and lca could be independent. After that, I would use my little OEM Toyota soda can jack and jack up the lca until the eyelet met the bottom of the coil. Put the bolt in and then fasten the spindle back up.
  19. Apr 12, 2017 at 10:01 AM
    fatfurious2
    David
    Ashburn, VA
    I would think it would be easier to take the UCA ball joint castle nut off, so that could be lifted out of the way. Youre going to get an alignment anyways, so you might as well make it easier on yourself, instead of prying stuff.
    I think you are leaving your sway bar on, but thats easy enough to disconnect while you disconnect things to put the coil in. I forget if @boogie3478 had his sway bar on or not.
  20. Apr 12, 2017 at 10:04 AM
    boogie3478
    14 TRD Off-Road V6
    All the mods
    Nope, I ditched my sway bar about 2 years ago ... of course I drive my truck like a truck and not a car so I barely notice it.
