Northern Virginia Roll Call
Discussion in 'Virginia' started by r6hokie, Nov 17, 2011.
  1. Apr 14, 2017 at 11:44 AM
    LocoLocal
    LocoLocal Aspiring Polymath
    39.081221472127545, -77.45538862919935
    Large American
    I am in but need to disassemble my struts and put the spacers in, then put them back together.
    Mr. Projekt[QUOTED] likes this.
  2. Apr 14, 2017 at 11:51 AM
    LocoLocal
    Large American
    @fatfurious2 is probably sick and tired of hearing me talk about doing this. Actually everyone in this thread probably is. I just need to grow some balls and go get the tool from Advance Auto for $30.
    Edit: unless anyone has one I can borrow?!
  3. Apr 14, 2017 at 11:53 AM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    What tool are you talking about?
  4. Apr 14, 2017 at 11:54 AM
    LocoLocal
    Large American
  5. Apr 14, 2017 at 11:55 AM
    Mr. Projekt
    Mr. Projekt Well-Known Member
    Caleb
    Harpers Ferry, WV
    2021 DCLB TRD-OR 4x4 Army Green
    I'm not sure about 2nd gens, but arent the stock struts super difficult to compress and everyone recommends to have a shop do it and not rent the tool?
    fatfurious2 likes this.
  6. Apr 14, 2017 at 11:57 AM
    fatfurious2
    David
    Ashburn, VA
    They are pretty dangerous.
    What spacer are you trying to install? Usually they just go in between the top of the strut and the coil bucket. And you dont need to disassemble anything
  7. Apr 14, 2017 at 11:58 AM
    LocoLocal
    Large American
    Yes, hence my trepidation. I am just hoping someone has done it themselves. The issue is the shops either want to charge an outrageous amount, or they won't put in the parts that I have bought used due to liability concerns. Which is fine with me. Is double d still around? Maybe I could just have him put the spacers on the struts at his shop (I have a new set of struts I am going to use), and then install them myself.
  8. Apr 14, 2017 at 12:00 PM
    fatfurious2
    David
    Ashburn, VA
    Ive put a top plate spacer on @boogie3478 front shocks. It just sat on the top. No need to take anything apart. I can take a look at what you are trying to do. And then advise from there
    boogie3478 likes this.
  9. Apr 14, 2017 at 12:01 PM
    Mr. Projekt
    Caleb
    Harpers Ferry, WV
    yep, that was going to be my next suggestion is take it to @DOUBLLD
    yea that would be pretty simple, but I think he has a spacer that preloads the spring
    fatfurious2[QUOTED] likes this.
  10. Apr 14, 2017 at 12:02 PM
    LocoLocal
    Large American
    Here is what I am trying to install: http://toyteclifts.3dcartstores.com/TAC2--2-Front-Spacer-Kit_p_305.html.
    And here are the instructions: .
    Maybe I am missing something, and for that I would be very embarrassed, but I believe I need to disassemble.
  11. Apr 14, 2017 at 12:09 PM
    fatfurious2
    David
    Ashburn, VA
    For that one, disassembly is required.
    It can be done with the coil spring compressor linked a couple posts up, but its kinda dangerous. I can help you, but we would need to be super careful.
    Is there not another way you can get 2" of lift? Can you look into getting bilsteins from @HeadStrong Off-Road ?
  12. Apr 14, 2017 at 12:18 PM
    LocoLocal
    Large American
    I had looked into it but I piecemealed a lift kit together buying parts on here. This all started when I needed new leaf springs and rear shocks. I didn't even want a lift, but we all know what this forum can do to you. Ended up with nearly brand new SR5 front and rear shocks and leaf springs, and 2" front spacers and 1" blocks and new u bolts for the rear - all for $180. I don't do any rock crawling and have had spacer lifts on other trucks that were fine for my uses, so I was pretty happy with the deal I got. At this point I have installed the new leaf springs and rear shocks, but haven't done the lift or front at all.
  13. Apr 14, 2017 at 12:23 PM
    fatfurious2
    David
    Ashburn, VA
    So you are rocking reverse bro lean/hot rod :rofl:
    Coot83 and VA SOFTACO like this.
  14. Apr 14, 2017 at 12:24 PM
    fatfurious2
    David
    Ashburn, VA
    Im up to the challenge of taking yours apart. If you want to try it.
    If not, @DOUBLLD can definitely do it.
  15. Apr 14, 2017 at 12:25 PM
    LocoLocal
    Large American
    Haha no I haven't put the blocks in (part of "the lift" IMO) for that reason.
  16. Apr 14, 2017 at 12:26 PM
    LocoLocal
    Large American
    Yeh I may just have him do it. At this point its taken so long I just need to get it done.
  17. Apr 14, 2017 at 12:37 PM
    jschona1
    jschona1 Well-Known Member
    Jeff
    Loudoun County
    A Corolla...
    And finished, plus some Huskey front mud flaps that I had purchased from awhile back.
    Thank you @fatfurious2
    ready6delta, quis23 and fatfurious2 like this.
  18. Apr 14, 2017 at 12:43 PM
    Ryan.orr87
    Ryan.orr87 Well-Known Member
    Thanks
    Thanks! I have no complaints with them at all they are great. I need to find a better place to mount them so they can be closer to the ground and more effective as fog lights. But I love them
  19. Apr 14, 2017 at 1:04 PM
    Coot83
    Coot83 DORKEL NATION
    Scottsdale, Az
    2012 Baja TX
    TC 3.5 LT, RCV axles, Demello sliders, BD light bar/fogs, LP6, DMZ rear, SOS skids, custom bumper, King 16" triples, Locked-on hydro rear bumps...
    Your bed supports are painted and arnt raw metal right?
  20. Apr 14, 2017 at 1:07 PM
    jschona1
    Jeff
    Loudoun County
    A Corolla...
    Rustoleum in flat black plus a clear coat protectant.
    Coot83 likes this.
