Northern Virginia Roll Call
Discussion in 'Virginia' started by r6hokie, Nov 17, 2011.
  1. Apr 19, 2017 at 5:45 AM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    I paid $54 for 2 colors
    Ryan.orr87[QUOTED] likes this.
  2. Apr 19, 2017 at 5:45 AM
    fatfurious2
    David
    Ashburn, VA
    Could be. Expect 4 hours though
    Mr. Projekt likes this.
  3. Apr 19, 2017 at 5:46 AM
    Coot83
    Coot83 DORKEL NATION
    Scottsdale, Az
    2012 Baja TX
    TC 3.5 LT, RCV axles, Demello sliders, BD light bar/fogs, LP6, DMZ rear, SOS skids, custom bumper, King 16" triples, Locked-on hydro rear bumps...
    I hear the decals are more than worth it though in terms of finish and durability. I don't think I would consider any other guy over him for getting decals.
    Ryan.orr87 likes this.
  4. Apr 19, 2017 at 5:46 AM
    Ryan.orr87
    Ryan.orr87 Well-Known Member
    I think I'm doing my brake lines, pads and rotors Friday afternoon.
    Casper66 and fatfurious2 like this.
  5. Apr 19, 2017 at 5:48 AM
    Mr. Projekt
    Mr. Projekt Well-Known Member
    Caleb
    Harpers Ferry, WV
    2021 DCLB TRD-OR 4x4 Army Green
    why not! haha we'll do the 3 of ours... my lift, your snorkel, and David's bed decal and roof rack
    fatfurious2 likes this.
  6. Apr 19, 2017 at 5:51 AM
    Coot83
    Scottsdale, Az
    2012 Baja TX
    Are you going to extended brake lines? If so, def have the right wrench for the brake lines.
  7. Apr 19, 2017 at 5:53 AM
    Ryan.orr87
    I was going to ask if I need a special tool... I am doing extended lines
  8. Apr 19, 2017 at 5:57 AM
    Coot83
    Scottsdale, Az
    2012 Baja TX
    Def get a "flare nut" wrench. They have a very tight tolerance over a standard wrench. I would hit the brake line connections with some pb blast or liquid wrench to let it soak up a little before doing them. They tend to be really tight from the factory and that wrench will help from stripping it when you first loosen them up.
    @fatfurious2 might still have his wrench that we used when doing mine.
  9. Apr 19, 2017 at 6:04 AM
    90yota
    90yota Instagram: 90_yota
    Dixon, CA/Truckee,CA
    88 T4R / 15 F350
    Stock....ish
    @Ryan.orr87 not white lithium like last time lol
    Coot83[QUOTED] and Ryan.orr87 like this.
  10. Apr 19, 2017 at 6:05 AM
    Ryan.orr87
    It's all I had bro! give me a break! lol
    Coot83 likes this.
  11. Apr 19, 2017 at 6:06 AM
    Coot83
    Scottsdale, Az
    2012 Baja TX
    Sounds like a good story!
    90yota[QUOTED] likes this.
  12. Apr 19, 2017 at 6:10 AM
    fatfurious2
    David
    Ashburn, VA
    I may also need to diff fluid change. I need to do 200 miles after i get back to fully break in my gears.
    @Ryan.orr87 i have a 10mm flare nut wrench
    Coot83 and Mr. Projekt[QUOTED] like this.
  13. Apr 19, 2017 at 6:13 AM
    TacoFMS
    TacoFMS Bubble bubble bubble pop
    Justin
    Louisa County, VA
    Just a vehicle to take trash to the dump
    One or two things modded... Check out the build thread
    Thought it was 500 miles???
    Casper66 and Coot83 like this.
  14. Apr 19, 2017 at 6:13 AM
    fatfurious2
    David
    Ashburn, VA
    It is. Raleigh is 300 miles from home. Still need to do 200 after i get back
    Mr. Projekt and TacoFMS[QUOTED] like this.
  15. Apr 19, 2017 at 6:14 AM
    Ryan.orr87
    I guess that's what I need... Can I borrow it from you? Or you can come help with brakes on Friday! :thumbsup:
  16. Apr 19, 2017 at 6:14 AM
    Coot83
    Scottsdale, Az
    2012 Baja TX
    I would of thought the same...everytime I did my gears, I had a 500 mile break in. I would think after that to flush when things are good and solid.
    TacoFMS[QUOTED] likes this.
  17. Apr 19, 2017 at 6:18 AM
    TacoFMS
    Justin
    Louisa County, VA
    Ahhh, I see now. Just don't forget no more than 55mph for the first 500. No jack rabbit starts and can only drive it constantly for an hour at a time before letting it rest for 20 minutes.
    So with that said it should take you a day and a half to make it home....
    TacoCat, Coot83, 90yota and 1 other person like this.
  18. Apr 19, 2017 at 6:18 AM
    fatfurious2
    David
    Ashburn, VA
    Im off today and tomorrow. I work Friday-Sunday
  19. Apr 19, 2017 at 6:19 AM
    fatfurious2
    David
    Ashburn, VA
    Yep. The ecgs site is slightly different. But ill clarify when im there
  20. Apr 19, 2017 at 6:22 AM
    Coot83
    Scottsdale, Az
    2012 Baja TX
    RTT FTMFW!!!!
