Northern Virginia Roll Call
Discussion in 'Virginia' started by r6hokie, Nov 17, 2011.
  1. May 9, 2017 at 6:52 PM
    CanisLupus
    CanisLupus Member since 2011
    Stokesdale | NC
    ‘19 Honda Civic Hatchback
  2. May 9, 2017 at 6:55 PM
    Mr. Projekt
    Mr. Projekt Well-Known Member
    Caleb
    Harpers Ferry, WV
    2021 DCLB TRD-OR 4x4 Army Green
  3. May 9, 2017 at 7:09 PM
    jschona1
    jschona1 Well-Known Member
    Jeff
    Loudoun County
    A Corolla...
    Great, get a link to a group buy for LR UCAs and now @fatfurious2 has me shopping to piecemeal a Fox suspension kit.
    ready6delta, Coot83 and fatfurious2 like this.
  4. May 9, 2017 at 7:20 PM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    @90yota started this whole mess! :boink:
    Coot83 and 90yota like this.
  5. May 9, 2017 at 7:24 PM
    90yota
    90yota Instagram: 90_yota
    Dixon, CA/Truckee,CA
    88 T4R / 15 F350
    Stock....ish
    :anonymous:
    Coot83 and fatfurious2[QUOTED] like this.
  6. May 9, 2017 at 9:11 PM
    LocoLocal
    LocoLocal Aspiring Polymath
    39.081221472127545, -77.45538862919935
    Large American
    Met Corey @moe2o4 up in Uniontown, PA to pick up my cap. I think it looks pretty good, and will serve me even better. Corey has a pretty sick truck too.
  7. May 10, 2017 at 4:02 AM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    OH I PM'd him already. I'm not leaving my hi-lift attached. Just wanted to post a quick pic. :)
    fatfurious2[QUOTED] likes this.
  8. May 10, 2017 at 4:02 AM
    ilubtimmyhos
    ilubtimmyhos Brewer
    Adam
    Haymarket, VA
    2012 Blue Tacoma 4x4 Pre-Runner
    4x4 Conversion w/ FJ T-Case, King 2.5 Extended Travel Coilovers w/ JBA UCAs, King 12" 2.0 Smoothies w/ BAMF relocate in the rear, OME Dakar leaf pack, 4.56 gears w/ ARB air locker, Archive Hammer Hangers w/ crossbar brace, ARB Snorkel, Custom Bed cap w/ Roofnest Sparrow XL, Retrofit Headlights, Wrapped in 3M Satin Perfect Blue
    Apparently some years involve grinding to do an AAL so yesterday took me a lot longer than planned. Sorry I missed y'all last night.
    Gained 1.5" in the rear, as well as leveled out the rear. My old Leaf pack was apparently sagging on the driver side.
  9. May 10, 2017 at 4:03 AM
    fatfurious2
    David
    Ashburn, VA
    Truck looks good now though
    DOUBLLD likes this.
  10. May 10, 2017 at 4:05 AM
    ilubtimmyhos
    ilubtimmyhos Brewer
    Adam
    Haymarket, VA
    Thanks. I have a quarter inch spacer coming in to level out the driver side lean in the front. Didn't manage to get the shocks done yesterday in the rear because I can't find a 5mm wrench to save my life.
    DOUBLLD likes this.
  11. May 10, 2017 at 4:06 AM
    boogie3478
    14 TRD Off-Road V6
    All the mods
    Top plate spacer?
  12. May 10, 2017 at 4:08 AM
    ilubtimmyhos
    ilubtimmyhos Brewer
    Adam
    Haymarket, VA
    Yep. The driver side is sitting 1/2" lower than the passenger so I'm just going to throw that on top to even it out.
    boogie3478[QUOTED] likes this.
  13. May 10, 2017 at 4:26 AM
    TacoCat
    TacoCat These pretzels are making me thirsty
    Johnny-5
    Chantilly, VA
    25 Crosstrek Premium CVT (first ever automatic!)
    I'm not sure I have anything that small, but can take a look this afternoon when I get home. I think most of my metric tools start around 10mm.
    fatfurious2 likes this.
  14. May 10, 2017 at 4:26 AM
    TacoCat
    Johnny-5
    Chantilly, VA
    also what did you need a 5mm for? I don't remember needing one for anything.
  15. May 10, 2017 at 4:28 AM
    DOUBLLD
    DOUBLLD Well-Known Member
    Daniel
    Bluemont, VA
    05 Tacoma LS Swap Twin Turbo
    Alot
    i usually pull the boot down and use a pair of channel locks or vise grips to hold the stem of the shock. or you can cut the nut off the top. that spot on the stem of the shock usually rounds your truck looks newer so may not be a issue
    LocoLocal, TacoCat and boogie3478 like this.
  16. May 10, 2017 at 4:29 AM
    ilubtimmyhos
    ilubtimmyhos Brewer
    Adam
    Haymarket, VA
  17. May 10, 2017 at 4:30 AM
    fatfurious2
    David
    Ashburn, VA
    You dont need that. Just use vise grips. Or you might need to cut them off
  18. May 10, 2017 at 4:32 AM
    TacoCat
    Johnny-5
    Chantilly, VA
    Ohhhhh yeah that little pos. I ended up rounding mine off with a set of vise grips when i did mine. Ended up using the method @DOUBLLD mentioned above on one of them, and had to cut the shock off on the other one cause it was so FUBAR.
    Coot83 likes this.
  19. May 10, 2017 at 4:32 AM
    ilubtimmyhos
    ilubtimmyhos Brewer
    Adam
    Haymarket, VA
    Yeah I tried with my vice grips yesterday and it wasn't having it. I hit it with some PB Blaster and didn't have it in me to work at it long last night. I'll probably try again today. Keep in mind I'm replacing this with a new pair of the same thing so I'm still going to need to be able to hold it.
  20. May 10, 2017 at 4:33 AM
    ilubtimmyhos
    ilubtimmyhos Brewer
    Adam
    Haymarket, VA
    @Me. Projekt what did you use, since you just took these off yours?
