Northern Virginia Roll Call
Discussion in 'Virginia' started by r6hokie, Nov 17, 2011.
  1. May 10, 2017 at 4:34 AM
    TacoCat
    TacoCat These pretzels are making me thirsty
    Johnny-5
    Chantilly, VA
    25 Crosstrek Premium CVT (first ever automatic!)
    You are replacing OEM billies with OEM billies? if you need a dremel, or angle grinder, those make quick work of the job and I have both
    LocoLocal likes this.
  2. May 10, 2017 at 4:36 AM
    ilubtimmyhos
    ilubtimmyhos Brewer
    Adam
    Haymarket, VA
    2012 Blue Tacoma 4x4 Pre-Runner
    4x4 Conversion w/ FJ T-Case, King 2.5 Extended Travel Coilovers w/ JBA UCAs, King 12" 2.0 Smoothies w/ BAMF relocate in the rear, OME Dakar leaf pack, 4.56 gears w/ ARB air locker, Archive Hammer Hangers w/ crossbar brace, ARB Snorkel, Custom Bed cap w/ Roofnest Sparrow XL, Retrofit Headlights, Wrapped in 3M Satin Perfect Blue
    I have an angle grinder and access to an air-powered cutting wheel. And yes, I'm replacing my whole setup with the oem set from @Me. Projekt because my set is pretty dead.
    Mr. Projekt and TacoCat[QUOTED] like this.
  3. May 10, 2017 at 4:43 AM
    IPNPULZ
    IPNPULZ Well-Known Member
    Deeper in the South…….
    2023 TRD Off Road Premium 4R
    going to be fun!
    Looks like Davids is short!!
    boogie3478 likes this.
  4. May 10, 2017 at 4:49 AM
    Coot83
    Coot83 DORKEL NATION
    Scottsdale, Az
    2012 Baja TX
    TC 3.5 LT, RCV axles, Demello sliders, BD light bar/fogs, LP6, DMZ rear, SOS skids, custom bumper, King 16" triples, Locked-on hydro rear bumps...
    SOUR CREAM! Proud of you man!!!
  5. May 10, 2017 at 4:51 AM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    Didn't touch anything on that plate except the GUAC
    ready6delta and LocoLocal like this.
  6. May 10, 2017 at 4:52 AM
    Coot83
    Scottsdale, Az
    2012 Baja TX
    Atleast you got what it takes to handle QUAC. You still have time to learn whats good for ya.
    ready6delta likes this.
  7. May 10, 2017 at 5:06 AM
    Ryan.orr87
    Ryan.orr87 Well-Known Member
    I ended up having to cut mine out.
    ilubtimmyhos and TacoCat[QUOTED] like this.
  8. May 10, 2017 at 5:51 AM
    DOUBLLD
    DOUBLLD Well-Known Member
    Daniel
    Bluemont, VA
    05 Tacoma LS Swap Twin Turbo
    Alot
    if they dont break free after i try vise grips i just cut them. saves alot of time.
    TacoCat and Coot83 like this.
  9. May 10, 2017 at 6:25 AM
    LocoLocal
    LocoLocal Aspiring Polymath
    39.081221472127545, -77.45538862919935
    Large American
    ^^^ what I had to do with mine, Wasn't saving them, so I cut away.
    DOUBLLD[QUOTED] likes this.
  10. May 10, 2017 at 7:00 AM
    ilubtimmyhos
    ilubtimmyhos Brewer
    Adam
    Haymarket, VA
    So, who knows a good place to get an alignment in NoVA, near Alexandria preferably?
  11. May 10, 2017 at 7:03 AM
    fatfurious2
    David
    Ashburn, VA
    @Coot83 might know that place. I like going to High Tech in Chantilly. Their alignment is around $150. @Sand_taco works at Ptuning in Manassas and can get you aligned for around $120.
    If you are on stock suspension still, might as well go to a standard place
  12. May 10, 2017 at 7:06 AM
    ilubtimmyhos
    ilubtimmyhos Brewer
    Adam
    Haymarket, VA
    My suspension is def stock enough for a normal alignment.
    fatfurious2[QUOTED] likes this.
  13. May 10, 2017 at 7:08 AM
    Coot83
    Scottsdale, Az
    2012 Baja TX
    I went to merchants for mine and paid I think $89 for 6 months of coverage on alignments. I know they are only merchants, but since you don't have anything crazy suspension wise, that might be ideal for you since in some ways you are considered "stock" with your suspension set up.
    You could also look into firestone where they offer the "lifetime" alignment for $150. If you ever get crazy with your suspension, this could void it, but currently I don't think you would have any issue.
    ilubtimmyhos likes this.
  14. May 10, 2017 at 7:25 AM
    Sand_taco
    Sand_taco Well-Known Member
    2016 quicksand Trd off road
    if its a stock Tacoma we could do $100 for the alignment
  15. May 10, 2017 at 7:28 AM
    ilubtimmyhos
    ilubtimmyhos Brewer
    Adam
    Haymarket, VA
    It has an AAL, but besides that its all OEM.
  16. May 10, 2017 at 7:30 AM
    DOUBLLD
    Daniel
    Bluemont, VA
    Alot
    i can get it done for 80 for you? but im in sterling
  17. May 10, 2017 at 7:32 AM
    Coot83
    Scottsdale, Az
    2012 Baja TX
    Nice man I didn't know you had the capability to do alignments.
  18. May 10, 2017 at 7:34 AM
    DOUBLLD
    Daniel
    Bluemont, VA
    Alot
    friend of mine does them for me. we dont have a alignment rack at our shop. i used c&c but he wont do custom specs so i take it a local high performance shop. does amazing work
  19. May 10, 2017 at 7:35 AM
    DOUBLLD
    Daniel
    Bluemont, VA
    Alot
    cars are more since they usually have front and rear adjustment. since our trucks are just front can do it cheaper
    Coot83 likes this.
  20. May 10, 2017 at 7:39 AM
    Sand_taco
    That should be no problem
