NorthWest MOAB 2012 Team
Discussion in 'North West' started by MapleMoose, Jan 24, 2012.
Who will be the first to break down?
  1. Ben
    6 vote(s)
    22.2%
  2. Adam
    0 vote(s)
    0.0%
  3. Mark
    0 vote(s)
    0.0%
  4. Monte
    9 vote(s)
    33.3%
  5. Mike
    0 vote(s)
    0.0%
  6. Ian
    3 vote(s)
    11.1%
  7. Chris
    0 vote(s)
    0.0%
  8. Brady
    0 vote(s)
    0.0%
  9. Potato
    9 vote(s)
    33.3%
  1. Feb 16, 2012 at 11:52 AM
    #441
    MapleMoose
    MapleMoose [OP] Drunk Canadian
    Ian
    West Kootenays
    1996 Tacoma SR5
    3" Eibach Coils, 3" AP Springs, AP 6" Shackles Toytec Diff drop, BAMF Sliders, Deck plate mod,Volt meter, Highbeam mod, PIAA fogs, 18" Magnaflow, LED dash swap, Color matched Satoshi Grille, Custom Rear Plate Bumper
    yea it is better for wear.
    Whats the smallest winch you can have with a 1st Gen?
  2. Feb 16, 2012 at 11:58 AM
    #442
    Twistedfreedom
    Twistedfreedom welcome to the incredibuild
    Adam
    Seattle
    in progress
    modded the F*ck out
    get a winch thats rated at 2x the truck weight
  3. Feb 16, 2012 at 3:59 PM
    #443
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    8000lbs i believe is the min
  4. Feb 16, 2012 at 4:33 PM
    #444
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    Do we need to convert this to metric?
  5. Feb 16, 2012 at 4:57 PM
    #445
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    Or 2 wooly mammoths
  6. Feb 16, 2012 at 7:37 PM
    #446
    MapleMoose
    Ian
    West Kootenays
    1996 Tacoma SR5
    theres something wrong with you guys
  7. Feb 16, 2012 at 7:37 PM
    #447
    bulhas
    bulhas the habs fan
    Joe
    Edmonton, Alberta
    1997 Rexus
    LS Swap 500 hp......
    no they are just perfectly normal
  8. Feb 16, 2012 at 7:58 PM
    #448
    MapleMoose
    Ian
    West Kootenays
    1996 Tacoma SR5
    mhmm :rolleyes:
  9. Feb 16, 2012 at 8:43 PM
    #449
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    I gotta agree with you.
    It is sorta like that thing about the sum of the parts being more... Space definitely gets warped when adam and ben get too close together. :eek:
    It depends on how much weight you've added with armor and bigger tires, canopies, racks, lights, yada,yada,yada.
    One of the reasons I upgraded to a 10,000lbs winch. (or in terms that adam (4545.5 Kgs) and Ben (6.666666666667 mooses :)) can grasp.
  10. Feb 16, 2012 at 8:56 PM
    #450
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    i conveniently have this gift certificate for a full lube/grease and oil change. which will be due right before moab, so win for me!
    i sure do hope i can get those on before moab, god i dont wanna destroy the body lol.
    i hear somewhere gas might be 5 bucks by the summer...does that scare anyone else?
    also i am claiming myself as the official "bro" of the northwest team. dirtbike shirts, baggy shorts, poofy skate shoes (ill bring boots too), flat bill hats and monsters...there is no denying it haha
  11. Feb 16, 2012 at 9:01 PM
    #451
    bulhas
    bulhas the habs fan
    Joe
    Edmonton, Alberta
    1997 Rexus
    anyone know of any dealers of RTT's that are on the way to MOAB as i want to save the cost of shipping and duties
  12. Feb 16, 2012 at 9:02 PM
    #452
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    rofl i was laughing to hard my chest started to hurt:rofl::rofl:
  13. Feb 16, 2012 at 9:37 PM
    #453
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    you can have it shipped to my house and I'll bring it down for you :devil:
  14. Feb 16, 2012 at 9:38 PM
    #454
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    Thank you Stephen hawkings
    PS it's not space that gets warped its time. :cool: :D
  15. Feb 16, 2012 at 9:42 PM
    #455
    Digiratus
    Roaming the PNW
    The RedHead
    Under normal circumstances this would be true...these are not normal circumstances. :evil:
  16. Feb 16, 2012 at 9:44 PM
    #456
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    Mike im excited to meet you actually, ben says you have a pretty sweet rig.
  17. Feb 16, 2012 at 9:53 PM
    #457
    Digiratus
    Roaming the PNW
    The RedHead
    What does ben know... Look what he is driving. :rofl:
  18. Feb 16, 2012 at 9:55 PM
    #458
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    HAHAHAHA, i feel bad that ben has become a quasi internet punching bag
  19. Feb 16, 2012 at 9:57 PM
    #459
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    Quasim3oto
  20. Feb 16, 2012 at 10:08 PM
    #460
    Digiratus
    Roaming the PNW
    The RedHead
    Ben deserves every bit of the attention he gets. :rolleyes:
