NorthWest MOAB 2012 Team
Discussion in 'North West' started by MapleMoose, Jan 24, 2012.
Who will be the first to break down?
  1. Ben
    6 vote(s)
    22.2%
  2. Adam
    0 vote(s)
    0.0%
  3. Mark
    0 vote(s)
    0.0%
  4. Monte
    9 vote(s)
    33.3%
  5. Mike
    0 vote(s)
    0.0%
  6. Ian
    3 vote(s)
    11.1%
  7. Chris
    0 vote(s)
    0.0%
  8. Brady
    0 vote(s)
    0.0%
  9. Potato
    9 vote(s)
    33.3%
  1. Feb 28, 2012 at 10:17 PM
    #561
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    We'll be heading out first thing sunday morning. You? I have to be at work tuesday the 22nd at 7 am.
  2. Feb 28, 2012 at 10:32 PM
    #562
    Digiratus
    Roaming the PNW
    The RedHead
    It is a little over a 1000 mile return trip for us. And towing is a little slower that would be otherwise. By the time we break camp sunday morning and get all loaded up, it'll be mid morning.
    I'm thinking we wont be able to do any trail running on sunday. :(
  3. Mar 1, 2012 at 11:12 PM
    #563
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    aww but i was hoping to hit that. We are gonna have to split into a lot of groups anyways as there will be tons of ppl there
  4. Mar 2, 2012 at 12:07 PM
    #564
    Twistedfreedom
    Twistedfreedom welcome to the incredibuild
    Adam
    Seattle
    in progress
    modded the F*ck out
    ben let's go now
  5. Mar 2, 2012 at 12:19 PM
    #565
    NYCO
    NYCO go explore...
    bOb
    Colorado
    Blue Betty - '06 TRD OR
    dents & scratches
    i recommend it...did it a couple years back and had a good time...just make sure you have a map of the trail..i didn't and got lost, then stuck in 3 feet of sand (first time i got to use my winch!)
    it has a couple obstacles to keep you busy...some ledges, a mini crack and some fun slick rock (tippy dome and the butte area in general was fun as hell)
  6. Mar 2, 2012 at 12:20 PM
    #566
    NYCO
    NYCO go explore...
    bOb
    Colorado
    dents & scratches
    we plan on having evening runs and night runs throughout BFE as added bonuses...and strive ravine will be a fun way into the campsite...the trail ends right next to camp
  7. Mar 2, 2012 at 12:24 PM
    #567
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    MOAB:goingcrazy:
    im down for a night run
  8. Mar 2, 2012 at 12:27 PM
    #568
    NYCO
    NYCO go explore...
    bOb
    Colorado
    dents & scratches
    heard mixed reviewed on steel bender and metal masher...and obviously the harder trails >8 wouldn't be fun for our trucks...
    look through traildamage.com and look for ones with high scenery and other activities for easier trails..increase rock crawling and water for the harder trails..
    and keep the trails <20 miles probably...
    but hard to pick a bad one out there..just keep it within your and your truck's limits to keep the experience enjoyable
  9. Mar 2, 2012 at 12:29 PM
    #569
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    or i could work on the truck :D, that helps too. need to find some dam time:cool: cb should be in (second try) saturday, lift on before the end of march, tires over spring break, sliders (god i hope so) mid april, then im all set.
  10. Mar 2, 2012 at 12:30 PM
    #570
    NYCO
    NYCO go explore...
    bOb
    Colorado
    dents & scratches
    :notsure:
    only 6 miles long...
  11. Mar 2, 2012 at 1:04 PM
    #571
    NYCO
    NYCO go explore...
    bOb
    Colorado
    dents & scratches
    guess we'll see soon enough
  12. Mar 2, 2012 at 2:05 PM
    #572
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    Not soon enough
  13. Mar 2, 2012 at 6:32 PM
    #573
    Digiratus
    Roaming the PNW
    The RedHead
    I've found that those things (moab videos) only make it worse for me. :burnrubber:
  14. Mar 2, 2012 at 7:01 PM
    #574
    Digiratus
    Roaming the PNW
    The RedHead
    I am OK with this. That way we can do Kanes Creek, Elephant Hill and Hells Revenge later in the week with some of the guys who have more experience on those trails.
    What about doing some of this trail on Tuesday. The way NYCO described it, I would really like to see and photograph some of the vistas on this trail. Plus it might be a good one for us that are not into the really difficult shit.
  15. Mar 2, 2012 at 7:08 PM
    #575
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    I already told you I'd winch your ass up
  16. Mar 2, 2012 at 7:17 PM
    #576
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    we've been friends for to long... I'm sorry
  17. Mar 2, 2012 at 7:19 PM
    #577
    MapleMoose
    MapleMoose [OP] Drunk Canadian
    Ian
    West Kootenays
    1996 Tacoma SR5
    3" Eibach Coils, 3" AP Springs, AP 6" Shackles Toytec Diff drop, BAMF Sliders, Deck plate mod,Volt meter, Highbeam mod, PIAA fogs, 18" Magnaflow, LED dash swap, Color matched Satoshi Grille, Custom Rear Plate Bumper
    Haha
    Mark, so if Adam is going down earlier to meet up with ben I was thinking I could meet you in spokane and we could convoy down and sleep in our trucks wherever
  18. Mar 2, 2012 at 7:19 PM
    #578
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    hhokd on fonix wurkd 4 mi
  19. Mar 2, 2012 at 7:20 PM
    #579
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    Ian, Mark is like 6 hours south of spokane...
  20. Mar 2, 2012 at 7:24 PM
    #580
    MapleMoose
    Ian
    West Kootenays
    1996 Tacoma SR5
    Right... Your the one from spokane
