NorthWest MOAB 2012 Team
Discussion in 'North West' started by MapleMoose, Jan 24, 2012.
Who will be the first to break down?
  1. Ben
    6 vote(s)
    22.2%
  2. Adam
    0 vote(s)
    0.0%
  3. Mark
    0 vote(s)
    0.0%
  4. Monte
    9 vote(s)
    33.3%
  5. Mike
    0 vote(s)
    0.0%
  6. Ian
    3 vote(s)
    11.1%
  7. Chris
    0 vote(s)
    0.0%
  8. Brady
    0 vote(s)
    0.0%
  9. Potato
    9 vote(s)
    33.3%
  1. Mar 14, 2012 at 4:42 PM
    #741
    Twistedfreedom
    Twistedfreedom welcome to the incredibuild
    Adam
    Seattle
    in progress
    modded the F*ck out
    that's why i want blue because they have higher CCA
  2. Mar 14, 2012 at 4:45 PM
    #742
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
  3. Mar 14, 2012 at 4:46 PM
    #743
    MapleMoose
    MapleMoose [OP] Drunk Canadian
    Ian
    West Kootenays
    1996 Tacoma SR5
    3" Eibach Coils, 3" AP Springs, AP 6" Shackles Toytec Diff drop, BAMF Sliders, Deck plate mod,Volt meter, Highbeam mod, PIAA fogs, 18" Magnaflow, LED dash swap, Color matched Satoshi Grille, Custom Rear Plate Bumper
    I would do one red one yellow. Blue is a marine battery, pretty sure theyre not meant for trucks
  4. Mar 14, 2012 at 4:52 PM
    #744
    Blackdawg
    Monte
    Wyoming/St. Louis
    my source is telling me that red tops have a higher CC..800amps..
    yellow and blue are 750 CC
    Odessy 1400 is 820 CC..1150 MCA...damn..only like 20 bucks more..i think those are what ill run.
  5. Mar 14, 2012 at 4:55 PM
    #745
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    OPTIMA BLUETOP STARTING AND DUAL PURPOSE BATTERIES
    MODEL NUMBER
    D27M
    34M
    D34M
    D31M
    PERFORMANCE
    Voltage 12v 12v 12v 12v
    Cold Cranking Amps @ 0 F 800 800 750 900
    Cranking Amps @ 32 F 1000 1000 870 1125
    Reserve Capacity 140 100 120 155
    Capacity (C/20 rate) 66 50 55 75
  6. Mar 14, 2012 at 4:56 PM
    #746
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    OPTIMA REDTOP STARTING BATTERIES
    MODEL NUMBER
    34 & 34R
    75/25
    34/78
    78
    25 & 35
    6V
    PERFORMANCE
    Voltage 12v 12v 12v 12v 12v 6v
    Cold Cranking Amps @ 0F 800 720 800 800 720 800
    Cranking Amps @ 32F 1000 910 1000 1000 910 1000
    Reserve Capacity 100 90 100 100 90 100
    Capacity (C/20 Rate) 50 44 50 50 44 50
  7. Mar 14, 2012 at 4:58 PM
    #747
    Blackdawg
    Monte
    Wyoming/St. Louis
  8. Mar 14, 2012 at 5:06 PM
    #748
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    the 35 series fits in the tacoma, Yes I will have to move some things around. if the battery is bigger or smaller I'll make it fit that's how shit gets done.
    the kit isn't a straight bolt in for the 4 banger.
    straight from your link*** 2005-Current Tacoma V6 and inline 4 cyl (2.7L requires further modification to vehicle. Specific 2.7L revision pending)***
    I've already emailed them about a month ago and they haven't gotten to the design.
  9. Mar 14, 2012 at 5:09 PM
    #749
    Blackdawg
    Monte
    Wyoming/St. Louis
  10. Mar 14, 2012 at 5:10 PM
    #750
    Blackdawg
    Monte
    Wyoming/St. Louis
    And damn! Those Odessy battries look bad ass man. can get 880 CC and 1250 MCA
  11. Mar 14, 2012 at 8:36 PM
    #751
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    thank you ^^^
    Edit: I had heard that trail was very scenic. Now, I really was to photograph it after seeing this video. :goingcrazy:
  12. Mar 14, 2012 at 8:47 PM
    #752
    Digiratus
    Roaming the PNW
    The RedHead
    Tell me the connection between the white rim trail and the black dragon canyon (trail??).
  13. Mar 14, 2012 at 8:56 PM
    #753
    Digiratus
    Roaming the PNW
    The RedHead
    I can't find any information on it in the guide book. :confused:
  14. Mar 15, 2012 at 12:43 AM
    #754
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    I think that if we are going to do one of the All day long trails we need to do it before the rest of the group gets there. I would prefer to do it in two days leave monday evening camp out and relax then finish it tuesday morning.
  15. Mar 15, 2012 at 6:49 AM
    #755
    Blackdawg
    Monte
    Wyoming/St. Louis
    This sounds like a good and fun way to do it
  16. Mar 15, 2012 at 8:32 PM
    #756
    Digiratus
    Roaming the PNW
    The RedHead
    I didn't say rimjob.:D I think you still have that image of the finger in the po... nuttella.:eek:
    Are you guys talking about camping on the white rim trail on Tuesday eve? This is sort of what I initially proposed.
    We could setup main camp at ABFE on Monday afternoon and leave it setup. Our trailer and the tundra will be there.
  17. Mar 15, 2012 at 9:05 PM
    #757
    Digiratus
    Roaming the PNW
    The RedHead
    Hey, I have a great idea. Let's meet in Moab on Monday afternoon, say... about 1:00 pm?? I'll be there, stocking up on ice and groceries for the next couple of days.
    I'll be listening for ya on channel 22 on the CB. :thumbsup:
  18. Mar 15, 2012 at 9:09 PM
    #758
    MapleMoose
    Ian
    West Kootenays
    1996 Tacoma SR5
    AAAAAAACHOOOOOOOOOO!
  19. Mar 15, 2012 at 9:51 PM
    #759
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    I be riding solo till wednesday so I don't care what the plans are but i would like to camp out away from BFE on night, I'm going to bring a telescope for those of us who are a little nerdy
  20. Mar 15, 2012 at 10:12 PM
    #760
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    hahaha sorry buddy!
