NorthWest MOAB 2012 Team
Discussion in 'North West' started by MapleMoose, Jan 24, 2012.
Who will be the first to break down?
  1. Ben
    6 vote(s)
    22.2%
  2. Adam
    0 vote(s)
    0.0%
  3. Mark
    0 vote(s)
    0.0%
  4. Monte
    9 vote(s)
    33.3%
  5. Mike
    0 vote(s)
    0.0%
  6. Ian
    3 vote(s)
    11.1%
  7. Chris
    0 vote(s)
    0.0%
  8. Brady
    0 vote(s)
    0.0%
  9. Potato
    9 vote(s)
    33.3%
  1. May 1, 2012 at 10:12 PM
    #1381
    BradyT88
    BradyT88 Well-Known Member
    HOLY MOTHER OF GOD!!!!!!!!!!!!:eek: That would be rough...
  2. May 1, 2012 at 10:14 PM
    #1382
    The Raisin
    The Raisin Well-Known Member
    Mark
    Spanaway, WA
    streetqueen
    Badlands front bumper with a Smittybilt 8K winch, synthetic winch line. Demello sliders and bedbar. Custom rear bumper. Custom skid plates. Flex-a-lite tranny cooler with fan mounted in bed. Bilstein 5100's with SAW coils, AllPro UCAs, NW offroad rear springs (garbage), 4.88s and front and rear lockrights. Lots of custom sheetmetal work.
    Mike has some pics of my truck from the time the bolts holding the lower bj to the spindle let go. I got lucky I was on the trail and just creeping when it happened. Had to leave the truck on the trail over night and fix it the next morning. Maybe he can post up a few.
  3. May 1, 2012 at 10:15 PM
    #1383
    Twistedfreedom
    Twistedfreedom welcome to the incredibuild
    Adam
    Seattle
    in progress
    modded the F*ck out
    you asked...
  4. May 1, 2012 at 10:30 PM
    #1384
    The Raisin
    Mark
    Spanaway, WA
    streetqueen
    Yeah we tried a couple of different things to try and get it out of the trail. Had to at least get it off the trail and out of the way.
  5. May 1, 2012 at 10:39 PM
    #1385
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    IMO, bens clunk is not a bj noise. However, I haven't heard it for myself so I can't be certain.
    I don't think bj clunk when worn, they just fail. Something else is clunking. :cool:
  6. May 1, 2012 at 10:42 PM
    #1386
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    what do you think it could be?
  7. May 1, 2012 at 10:49 PM
    #1387
    Digiratus
    Roaming the PNW
    The RedHead
    Which one is leaking? You have 4. I saw the two pics (1 upper and 1 lower) you posted on the other thread and neither one of those looked like they were leaking. Besides a leak does not automatically translate to a clunk or an immediate failure.
  8. May 1, 2012 at 10:52 PM
    #1388
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    Ben just for peace of mind had eyou checked your battery tie down?
  9. May 1, 2012 at 10:55 PM
    #1389
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    could be your clunk. :notsure:
  10. May 1, 2012 at 10:57 PM
    #1390
    Digiratus
    Roaming the PNW
    The RedHead
    Lots of thinks can make a clunk. Check the torque on all 8 lower bj bolts. All 6 top strut bolts too. Is the bottom of the strut moving. A visual inspection of the lower strut bushing should indicate a problem but grab ahold of the shock and see if it moves.
    As Jace mentioned, take weight off the wheel and see if you can wiggle it at all. Grab the tire at the 12 and 6 o'clock positions and see if you can make it move (or clunk). Do the same at the 3/9 o'clock positions.
  11. May 1, 2012 at 10:57 PM
    #1391
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    Personally, if it were my truck. I'd jack it up. Wiggle a pry bar under the tire and pry every which way. Push and pull. If it moves, determine if it's a ball joint of a wheel bearing, replace. If it doesn't move, check torque values on 4 bolts holding LBJ to knuckle and run her.
    A hole in the boot doesn't imply imminent failure. Perhaps increased rate of wear as you slowly loose grease though. An open boot that lets in dirt and lets out is no good though as you'll quickly develop play and then things will start to wear, not your case, just saying.
  12. May 1, 2012 at 10:59 PM
    #1392
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    I can come down friday/saturday if you need a hand with anything Ben. but sunday I'm booked solid.
  13. May 1, 2012 at 11:02 PM
    #1393
    Digiratus
    Roaming the PNW
    The RedHead
    That doesn't look fresh to me. A slow leak maybe. What does the other side look like? Same? Which side is the clunk coming from?
  14. May 1, 2012 at 11:06 PM
    #1394
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    ok If you need a hand let me know.
  15. May 1, 2012 at 11:06 PM
    #1395
    Digiratus
    Roaming the PNW
    The RedHead
    When Mark's failed it wasn't the lbj itself, it was the 4 bolts that held it onto the spindle. They are the ones in that picture below the bj. Check yours to make sure they are tight too. 14 mm I think. they look OK in the pic but check them anyway.
  16. May 1, 2012 at 11:09 PM
    #1396
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    DON'T YOU DARE PUT VIVE GRIPS ON ANY OF THOSE PARTS
  17. May 1, 2012 at 11:10 PM
    #1397
    Digiratus
    Roaming the PNW
    The RedHead
    :rofl:
  18. May 1, 2012 at 11:11 PM
    #1398
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    Sometimes you can't re-create the stress on random bushings that the vehicle does, especially off road.
    However, you can try. Check, however you can, LCA and UCA bushings, sway bar bushings and links, steering rack bushings, front diff mount bushings, TREs, BJs, wheel bearings, and shock lower bushings.
    Get a few pry bars and go to town.
    Or use a go pro to film your driver's side suspension while you do some light wheeling.
  19. May 1, 2012 at 11:15 PM
    #1399
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    ben, what is the clunk lol? i get a weird noise on my drivers side very rarely and i dont know what it is.
    It is on the front driver side
    It sounds like a rock is dislodging from the tires and shooting into the wheel well
    It only really happens when i get on the highway after driving through down town from school
    I usually park in a dirt lot with small ish rocks, but it is unlikley it is actually a rock
    It is the same side that I put the coils on the new 5100s, dont hear it from the side that got the coild put on at a shop
    everything drives fine and nothing appears missing broken or lose from the couplof quick checks i have done.
  20. May 1, 2012 at 11:16 PM
    #1400
    Digiratus
    Roaming the PNW
    The RedHead
    SIR! PUT DOWN THE VICE GRIPS AND STEP AWAY FROM THE TRUCK! KEEP YOUR HANDS WHERE I CAN SEE THEM!
    :eek:
