northwesttaco's SOLD LT Build w/ 35's and BS
Discussion in '2nd Gen. Builds (2005-2015)' started by NorthwestCruiser, Sep 8, 2014.
  1. Nov 23, 2016 at 12:52 PM
    #3981
    TheNatural
    TheNatural Well-Known Member
    Fort Nelson, BC
    '12 DCLB
    Lots of bolt on chrome stuff
    This is exactly how my truck sounded when the upper uniballs were starting to go. It drove me crazy. I cleaned, lubed, and retorqued everything but still sounded like an asshole in drive thru. No sign of play in the uniballs at that point but it came soon after.
  2. Nov 23, 2016 at 12:54 PM
    #3982
    Tretiak30
    Tretiak30 Well-Known Member
    Roman
    Cleveland, Ohio
    THE Ohioan.
    neo-garage.com
    The snow won't help fix that problem:rofl:
  3. Nov 23, 2016 at 12:56 PM
    #3983
    NorthwestCruiser
    NorthwestCruiser [OP] Well-Known Member
    Brian
    Snohomish, WA
    1996 Land Cruiser
    Custom 3 link, 40's etc..
    Ugh.. in the upper or lower?
  4. Nov 23, 2016 at 12:57 PM
    #3984
    TheNatural
    Fort Nelson, BC
    '12 DCLB
    Upper. my LCAs are stock
  5. Nov 23, 2016 at 12:58 PM
    #3985
    NorthwestCruiser
    Brian
    Snohomish, WA
    1996 Land Cruiser
    Well at least it isn't the lower I guess..
  6. Nov 23, 2016 at 1:00 PM
    #3986
    TheNatural
    Fort Nelson, BC
    '12 DCLB
    Have you changed yours out yet?
  7. Nov 23, 2016 at 1:07 PM
    #3987
    utroda
    utroda Well-Known Member
    Jared
    PNW
    06 DCSB SR5 4x4
    its pretty sad if the uniball is already going out, he's had this setup for only a couple of months.
  8. Nov 23, 2016 at 1:09 PM
    #3988
    Honeybadger
    Honeybadger Powaaaaaah!
    Alex
    Kirkland, Wa
    05 Tacoma TRD Sport 05 4Runner Lmt
    ARB: Front bumper, compressor, tire repair kit, deflate 4xinnovations: Full skids King Racing: extended travel coil overs. Bamf shock relocation buckets with 12" smoothies. EBC: Slotted/drilled brakes with Yellowstuf pads Pioneer: Deck, speakers Wheelers: Front and rear superbumps, extended brake lines Homemade: Rear HC bumper with swingout Toyo: 255/85R16 Open Country MT
    Exactly what I was thinking...I just ordered my TC uniball uppers with the Mt setup.... got me nervous now....
  9. Nov 23, 2016 at 1:10 PM
    #3989
    TheNatural
    Fort Nelson, BC
    '12 DCLB
    Ouch. that is pretty early. the clay here eats mine quick, but I get around 20k miles out of a pair. it's become an annual spring maintenance item.
    NorthwestCruiser[OP] likes this.
  10. Nov 23, 2016 at 1:10 PM
    #3990
    NorthwestCruiser
    Brian
    Snohomish, WA
    1996 Land Cruiser
    I've had it for 3 months.. probably about 5k miles if that.
  11. Nov 23, 2016 at 1:11 PM
    #3991
    NorthwestCruiser
    Brian
    Snohomish, WA
    1996 Land Cruiser
    Everyone else gets plenty of use, Dakota has had his for almost 2 years now I think. I wouldn't be, probably just a lemon
  12. Nov 23, 2016 at 1:12 PM
    #3992
    NorthwestCruiser
    Brian
    Snohomish, WA
    1996 Land Cruiser
    TC should have some kind of warranty right?
  13. Nov 23, 2016 at 1:12 PM
    #3993
    Honeybadger
    Alex
    Kirkland, Wa
    I wonder if the icon uniball ucas might be better since they have a sealed dustcap? I know it won't do you any good since your LT
  14. Nov 23, 2016 at 1:12 PM
    #3994
    TheNatural
    Fort Nelson, BC
    '12 DCLB
    Could just need the lube to work its way in there more. 5k sounds too soon. :notsure:
  15. Nov 23, 2016 at 1:13 PM
    #3995
    Honeybadger
    Alex
    Kirkland, Wa
    For how much they cost I'd Def call and ask....if not ask the vendor you bought them from.
  16. Nov 23, 2016 at 1:14 PM
    #3996
    TheNatural
    Fort Nelson, BC
    '12 DCLB
    Oh when the time comes to replace them, get an AGM uniball tool. expensive but makes the process easy as pie. And considering how many times you'll use it if you keep that set up a while , it's a bargain really
  17. Nov 23, 2016 at 1:17 PM
    #3997
    utroda
    Jared
    PNW
    06 DCSB SR5 4x4
    I've had my kit for about 8 months now, never lubed and make 0 noise. I thought they were making noise, but it was my limit straps, fixed them noise was gone.
    I find it hard to believe that its a uniball, but if it is i would contact TC and see if they stand behind the product they sell.
    Honeybadger likes this.
  18. Nov 23, 2016 at 1:18 PM
    #3998
    NorthwestCruiser
    Brian
    Snohomish, WA
    1996 Land Cruiser
    Contacted @2ndGenJonny and he's checking for me
  19. Nov 23, 2016 at 1:38 PM
    #3999
    2ndGenJonny
    2ndGenJonny Well-Known Member Vendor
    Jon
    Gilbert, AZ
    I highly doubt its a case of worn balls as much as shitty lube. That TriFlow is crap in cool weather, looks like baby batter and wont dissolve. I live in PHX and it gets maybe 30° here at the absolute coldest.
    I switched to this stuff
    SDHQ carries it for 25$, but im sure you can find it or a similar dry lube in an aerosol can. I really thought mine were going out but after a thorough cleaning with water, simple green and a rag and application of this stuff, they are quiet again.
    The lowers definitely are harder to lube but I was told by Cliff that you can add a wd40 tip with straw. I haven't done that yet cause I had the tires off and good access when i cleaned.
  20. Nov 23, 2016 at 1:41 PM
    #4000
    utroda
    Jared
    PNW
    06 DCSB SR5 4x4
    If the uniballs are teflon lined why lube? I can see it maybe if you are in the silt and sand but idk :anonymous: enlighten me.
