NOS In a 4cylinder?
Discussion in '4 Cylinder' started by OFFROADCARWASH, Apr 30, 2009.
  1. Apr 30, 2009 at 5:39 PM
    OFFROADCARWASH
    OFFROADCARWASH [OP] Well-Known Member
    Jacktown, Mississippi
    2000 Taco customized
    Custom badged black, 100watt LOUDSPEAKER mounted under toolbox, UWS toolbox, All terrain Tires, K&N Ram Air Intake, HUGE flood lights mounted to Tool Box, Cobra CB radio, Francis Antenna, HELLA Blue Headlights, 12 Pad LEDS in Cab lights, Husky Liners, Tinted Windows at 15%, Thrush Glass Pack (burned Out) with 4inch Tip..Remote Crank and Intry, 2 12" subs, Blacked out head lights and tail lights.
    I have a chance right now to run Nitrous Oxide in My 2.7L 4Cylinder.
    Could I do it or what are the problems?
  2. Apr 30, 2009 at 5:41 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    How much of a shot? Are you going to add fueling, or is it a wet kit?
  3. Apr 30, 2009 at 5:42 PM
    dud122
    dud122 rabble rabble rabble
    Dan
    Riverdale Park, MD
    2002 Tacoma DC
    OME up front, Dakar in the back, Elite front bumper, Warn winch, Tactical rear bumper with tire swing/jerry cans/hi lift, Revenge Fab. sliders, Tundra brakes, Camburg UCA's, Safari Snorkle, FJ TRD wheels, Truxedo, Bed Rug, Lights, CB, Switches, skids, LED's... OH MY!
    NOS in general wears a lot on engines...if it is any worse on 4 the 4 banger i couldn't tell ya....
    seems like a lot of ricers out there do it though
  4. Apr 30, 2009 at 5:43 PM
    beastlytaco
    beastlytaco Well-Known Member
    Ian
    08 Access Cab SR5
    well, if its not done right theres always the chance of blowing your engine, and your truck catching on fire. Its a Good idea to ALWAYS have a fire extinguisher on board.
  5. Apr 30, 2009 at 5:44 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    If done right, It shouldnt do any more damage than a turbo, or SC. The main 2 benafits of No2 are, it cools the intake temp, and adds more oxogen to the charge. I have used it many times, and the only problem I had was when my buddy hit it (150 hp set up) while my car was in neutral. :(
  6. Apr 30, 2009 at 5:52 PM
    Brunes
    Brunes abides.
    Rotorhead
    AHHHHHHHHHHHHH.....I think you mean EX-buddy no??
    Much like chris said-
    I've had this discussion with several folks who have installed/used NOS for various things. If you spend the time and money to do it right....You are not at any additional risk of damage to the car than you are from driving it at all.
    That being said- Wide Open Throttle and some other things need to happen most of the time you are going to ride the bottle- What are you trying to do with your truck that you are thinking about spray??
  7. Apr 30, 2009 at 5:56 PM
    dud122
    Dan
    Riverdale Park, MD
    2002 Tacoma DC
    i guess i didn't mean damage... more like faster wear... which could lead to damage
    do the tacoma's have forged internals (pistons, rods...etc)? or are they cast?
    stronger internal components will allow your engine to take higher shots due to the tremendous amount of heat and force the results from the nitrous
  8. Apr 30, 2009 at 6:09 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Pistons are Cast. The con rods and crank are forged. Though the pistons are cast, strength is not compromised due to the design of the piston, and being as the 1 GR-FE has a relatively long stroke, the piston sheds any heat build up rapidly. From what I have heard, the piston on the 1 GR-FE can stay around 300* under WOT, so heat wont be an issue to weakening it either.
  9. Apr 30, 2009 at 6:10 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    After detroying the top end of my 327.....Yes....very much an EX friend. :)
  10. Oct 29, 2009 at 9:28 AM
    silverback
    silverback Well-Known Member
    central CA
    2006 Prerunner SR5
    painted door handles, bilstein 5100's front and back, K&N air filter. Precision power component speakers and Kenwood deck.
    Honestly WTF I dont understand why you bought a toyota 4 banger to try and make it go fast. All this talk of superchargers and nitrous makes me sick. If you want a fast vehicle by a sportscar. If you need the supercharger for offroad capabilities then I sorta understand. But otherwise Its a fcukin truck man.
  11. Oct 29, 2009 at 9:39 AM
    Toyota Truck
    Toyota Truck Well-Known Member
    JT
    Texas
    2008 Prerunnner
    Magnaflow Muffler-TSB springs-Nuvi 265wt-aFe pro dry s filter-Husky Liners-Blue dome light-extra d-rings-OME 90000 sport struts-885 coils-N182 shocks-TSB AAL-LR UCAs-procomp black alloy rims- nitto terra grapplers-20% tint
    He just wants the best of both worlds.
  12. Oct 29, 2009 at 9:41 AM
    08pretaco
    08pretaco Almost there
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    AFE pro dry s, Husky X-act Contour
    why do you want to run nos? what are you looking to gain from this?
  13. Oct 29, 2009 at 9:45 AM
    mjp2
    Milton Juevos Portimous II
    NJ
    '06 TRD Access Cab, v6, 6-speed
    Scaffolding and a painted grill
    You resurrected an old thread just to complain?
  14. Oct 29, 2009 at 5:01 PM
    silverback
    central CA
    2006 Prerunner SR5
    no I simply told my view on a stupid decision. I dont care about any old thread before this. Why were on this why dont we put nos on our lawnmowers also, and then you could race other lawnmowers at the lawnmower strip.
  15. Oct 29, 2009 at 5:03 PM
    DanGer
    DanGer Avatar approved by 98tacomav6
    Northern Virginia & Blacksburg
    07 Base 4Cyl 4x4 Manual
    White Head Light mod, White shorty antennae, Doug Thorley Long Tube headers, AFE Drop in air filter, Secondary Air Filter Removed,
    Does it make you feel better to complain about it rather than not open/ignore the thread?
  16. Oct 29, 2009 at 5:05 PM
    JDMcQ
    JDMcQ Well-Known Member
    The Mushroom Capital of the World
    2006 Toyota 4Runner SR5 V8
    It really bothers me that people refer to Nitrous Oxide as NOS. N.O.S is a Company (Nitrous Oxide Systems). N2O is nitrous oxide. It bothers me even more when people say the word NOS instead of the initials N.O.S.
    Sorry about the bitching.
  17. Oct 29, 2009 at 5:07 PM
    NumNutz
    NumNutz One of the original 7928
    Virginia Beach, VA
    07 Tacoma 4x4 - Kings, TC, Dakars, broken stuff
    Lots.
    So can I twin turbo and supercharger my taco while running my 100 shot?
    I'm also trying to keep around 22mpg.
  18. Oct 29, 2009 at 5:08 PM
    Kelson
    Kelson My Truck is Cuter than Yours
    Kelson
    Honolulu, Hawaii
    08 5-Lug Reg. Cab SR5
    SR5 Exterior/Interior (Color matched Front Bumper, Chrome Grille Surround and Chrome Rear Bumper/Silver Scoshe Dash Kit, A/C Bezel, A/C Vent Surround) LED license plate and white interior lights, Wet Okole Seat Covers, iPad in-Dash, JL CL-RLC, JL 13TW5 sub, JL 500/1 Slash V1 amp, JL XR 6.5 Components, Rockford Fosgate 6X9s in Boxes Front XRunner Coils, DJM Control Arms and Rear 4X4 Leafs, Custom 2" Angled Streetacos.com Blocks Front XR Bilstien Struts and Rear XR Bilstien Shocks, CravenSpeen Antennae, RX-8 Rims w/ Fronts:235/40-R18 Sumitomo HTR Rears:245/40-R18 Goodyear Eagle GT, 35% Tint front windows, OEM Sliding Privacy Glass w/ 5% Ceramic Tint, Flowmaster Super 44 dumped before the axle, URD Short Throw Shifter, Door Sill Protectors, Door Edge Guards, OEM Sport Pedals,The Retrofit Source Morimoto Mini D2S Stage III 35W 5K HID Headlights, OEM Fog Lights w/ piss yellow bulbs, OEM Cruise Control, Porsche 944 Bucket Seats, BeefedTaco Skid Plate, Whale
    power to weight ratio maybe? a better balanced vehicle? better handling characteristics vs. the 6? maybe the whole THEY DON'T MAKE REGULAR CABS WITH V6s....
  19. Oct 29, 2009 at 5:09 PM
    DanGer
    Thats exactly what I was thinking, but didnt waste my breath.
  20. Oct 29, 2009 at 5:09 PM
    JDMcQ
    I think that double forced induction will support a 150 shot, get to it!
