Nose high with 5100s at 1.75 and rear leaf TSB
Discussion in 'Suspension' started by Rhody76, May 25, 2012.
  1. May 25, 2012 at 8:21 PM
    Rhody76
    Rhody76 [OP] Well-Known Member
    Rhode Island
    2011 SR5 DCLB 4x4
    Rear leaf TSB, Bilstein 5100s set at 1.75",1" blocks, UWS low profile toolbox in black, husky liners, tint, LED interior and reverse lights, yellow fogs
    Hey All-
    I've got 5100's installed in front with rear leaf TSB and its a little nose high. I am considering a 1" block in back. I don't do any serious offroading. just want it to look right.
    What do you guys think about this? From what I've heard a block in back isn't all that bad as long as your not off roading hard. Its easy to install and relatively cheap compared to AAL or new leaf packs.
  2. May 25, 2012 at 8:28 PM
    Highland Logan
    Highland Logan UBIQUE
    Frank
    Nova Scotia, Canada
    2011 Black AC TRD Off Road w/ factory tow pkg
    Icon Stage 2 w/ overload left in, SPC LR UCA, 265/75 16 BFG KO2, front and rear Weathertech floor liners, OEM (Extang) solid fold tonneau, OEM bed mat, OEM front skid plate, OEM billet oil cap, "TOYOYA" tailgate decal
    Stock coils or eibachs?
  3. May 25, 2012 at 8:31 PM
    lj973gm
    lj973gm Sold it, dont miss it yet.
    Ohio
    06 DCSB 4wd
    In the heading it states he is at 1.75 on the billies so eibachs are out of the question.
    Did you measure or does it just look like it is nose high?
    I put on billies at 0 with eibach and it looked front high kinda but I measure and I am taller in the rear by 1 inch with my TSB leafs.
    Most on here are going to tell you to do a AAL since blocks are so bad but the only AAL are 1.5 inches and higher.
    I personally would run a 1" block and not worry about it. If you do not like it just take it back out.
  4. May 26, 2012 at 10:29 AM
    Rhody76
    Rhode Island
    2011 SR5 DCLB 4x4
    I measured. Its about 1/8" higher in front. I had the TSB done about a year ago so I think it has settled. Plus i do a little towing
    I don't want to make the ride any stiffer which i heard the AAL will cause. What negative effects could the blocks cause? Does it compromise the weight capacity or towing ability?
  5. May 26, 2012 at 10:47 AM
    Leggo
    Leggo slow is smooth, and smooth is fast.
    Newton,Ma.
    10 TRD Sport AC 4x4 MGM
    Kenwood HU,Infinity Kappa speakers (x4), Infinity reference tweeters(x2),10" Kicker sub, Box by Subthump, Infinty Five channel amp,DVD anytime bypass, DTRL Mod, Xtang trifecta, Fogs anytime Mod, Bed Mat,Westin running boards, Console vault, Maglite mod, Weathertechs,Autopage remote starter, Power tailgate lock, HID Bi Zenon, Hella Supertones,Rain guards,Rear leaf TSB,Steering shaft TSB, Fisher Homesteader plow, 886 reverse lights mod, Redline Hood struts, Hankook Dynapro ATM LT265/70R17, power sliding rear window, Auto dimming/on anytime Bed lights, Blue Sea fuse panel & 100amp Breaker, de- badged,Rear headrest's removed, imMrYo mirror relocation,Homeroshi grill
    Only potential problems with blocks I know of is axle wrap under heavy acceleration? Maybe rear end hopping under heavy acceleration? Drive average and it should be fine I guess.
  6. May 26, 2012 at 1:25 PM
    ae111black
    ae111black Well-Known Member
    Kimo
    Hilo Hawaii
    10 TRD off road doublecab 4x4 silver
    plenty
    If you'r not wheeling hard you'll be fine. OE manufacturers have been using blocks out back for ever for setting ride height. They just arn't the best option. but they do indeed work.
  7. May 26, 2012 at 3:27 PM
    Rhody76
    Rhode Island
    2011 SR5 DCLB 4x4
    Keen observation Gelo76. Problem is I prefer the factory rake over the nose high look.
    Does anyone know if the block installation would cause any issues with the brake lines? Ive read that sometimes they need to be lengthened
  8. May 26, 2012 at 3:33 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Drop the 5100's down .... (I personally hate blocks)
    I've had the TSB for about 5 years now and it only sits about 1" higher than stock.
  9. May 26, 2012 at 3:39 PM
    iRepLONGBEACH
    iRepLONGBEACH SoCal Reppin
    SoCal
    10 MgM dcsb TRD Sport
    Maybe ur 5100s just needs to settle if u just installed them. I have the same setup and I'm pretty much leveled.
  10. May 26, 2012 at 3:45 PM
    Zimaura
    Zimaura Well-Known Member
    Nj
    San jose, CA
    05 4x4 Double Cab. level Kit, 33 inch BFGs
    Level Kit, 16inch Moto Metals, 33 BFGs, Flowmaster, tinted taillights, silver billet grills
    In my opinion and experience, nothing wrong with blocks.
    I have them, and. I tow a little. Not a problem!
  11. May 26, 2012 at 4:29 PM
    KenLyns
    KenLyns 8-in. Third Member
    Belly of the Beast
    4x4 TRD Off Road Full-Auto
    All-Pro Bumper, CBI Sliders, Icon Coilovers, BudBuilt Skids, aFe Intake, Icon VS Rear Shocks, Timbren Bumpstops, All-Pro UCAs, JDM Steering Wheel, ViAir Compressor, Klearz LED 3rd Brake Light, Pop-N-Lock Tailgate Handle, Husky Front Flaps
    Not all AALs are created equal. Toytec AAL is just a single leaf. Icon's AAL is a progressive 3-leaf pack, with better ride.
    http://www.trdparts4u.com/scripts/prodView.asp?idproduct=-8788
    Do you intend to install a winch and/or plate bumper in the near future? The extra front end weight will cause the front springs to settle a bit more and level the truck.
