Nose High With 5100's
Discussion in '2nd Gen. Tacomas (2005-2015)' started by aryant, Jan 16, 2016.
  1. Jan 16, 2016 at 2:41 PM
    aryant
    aryant [OP] Well-Known Member
    Eagle, CO
    MGM '13 TRD OR
    So just a little info on my set up: I've got 5100's in the front and rear, with the front set at 1.75". I immediately noticed that it was nose high, so I added the Wheeler's Progressive AAL in the rear, which added very little lift to the rear, if any at all. And I also don't have the TSB, my local dealership tells me there is no TSB for my vehicle.
    As it currently sits, it appears to be nose high quite a bit, and it's driving me nuts. Do you guys think that if I dropped it back down to .85" it will correct the issue?
    Is it also safe to assume that perhaps the AAL didn't give me the lift I was looking for because of the shell?
    Thanks guys!
  2. Jan 16, 2016 at 3:10 PM
    Fitz235
    Fitz235 Well-Known Member
    Rob
    New Hampshire
    Black '22 DCSB TRD Offroad 4WD
    - TRD T4R Pro Wheels - TRD Lift Kit - TRD Skid Plate - 265/70/17 Toyo Open Country 3's - OEM Bed Lights - OEM Bed mat - Alpharex Tail Lights - TacomaBeast LED Interior Lights - Green Lane Offroad Aluminum Sliders - Place Holder for More Bad Financial Decisions...
    The only way to know for sure is with before, and after measurements. Your going to lose ~ 1" in the front, if you drop down to .85. Take some measurements, and you'll know for sure. To me, based on that pic, I would think you would be level if you dropped to .85. Also, it doesn't look like level ground where your parked.
  3. Jan 16, 2016 at 3:12 PM
    aryant
    Eagle, CO
    MGM '13 TRD OR
    Unfortunately I did not take measurements before and after. I'm really just basing it off of appearances, which IMO seem obvious.
    The ground I am parked on probably isn't perfectly level, but the truck looks like this pretty much everywhere it's parked.
  4. Jan 16, 2016 at 3:22 PM
    Fitz235
    Rob
    New Hampshire
    Take some measurements now to get an idea. Hub to bottom of fender. Like I said, if you drop down to .85, your going to lose ~1" up front. Depending on goals/budget are/is, you could also just go with a full leaf pack to raise the rear some more, and leave the front as is.
  5. Jan 16, 2016 at 4:03 PM
    el_turks
    el_turks Well-Known Member
    Southern California
    2024 OR, 2009 PreRunner
    My nose is high with my 5100 887 setup... and I am waiting to see what I get with the leaf spring recall. I will do the ICON AAL and see how it goes..... please post your solution..
  6. Jan 16, 2016 at 7:53 PM
    aryant
    Eagle, CO
    MGM '13 TRD OR
    I'm not really looking to add any more lift, so more than likely I will just be dropping the front back down. I'm ok with it being leveled out, or even a little rake. I just wanted to get some other opinions on what kind of drop I might get going down one level.
  7. Jan 16, 2016 at 8:00 PM
    pudge151
    pudge151 Well-Known Member
    Sean
    Connecticut
    2015 Tundra Platinum
    Are you sure that the spring perches are on correctly. We have seen many times people have gotten more lift than expected when they are installed upside down
  8. Jan 16, 2016 at 8:00 PM
    aryant
    Eagle, CO
    MGM '13 TRD OR
    I went with the Wheeler's, and I gotta say, I am extremely disappointed with it. The ride is fine, but it's advertised as giving a 1.5" lift, and I'm not certain I got any lift at all. Not to mention the main reason I went with it was to get rid of the nose high lean....
  9. Jan 16, 2016 at 8:02 PM
    aryant
    Eagle, CO
    MGM '13 TRD OR
    I'm not 100% sure on that. I can post some pictures tomorrow in the daylight. From what I remember they are installed correctly, cup side down, facing the snap ring.
  10. Jan 16, 2016 at 8:03 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    It's a 1.5" lift without a camper shell on the bed, bro.
    1.5" lift is quoted for a stock truck, which yours isn't.
    You bought the wrong parts. I would try a block, or sell that 1.5" AAL and get RideRites instead.
    Or drop that thing to .85! Sorry to speak matter of factly but you were either ill informed about those AALs and what 5100 setting to use with your shell or you just totally misunderstood everything.
    Kyitty and Justinlhc like this.
  11. Jan 16, 2016 at 8:03 PM
    pudge151
    Sean
    Connecticut
    Pics will help. This is a very common issue
  12. Jan 16, 2016 at 8:04 PM
    Justinlhc
    Justinlhc Not looking for a relationship
    Is the overload still in the leaf pack? I put the Icon 3-leaf(basically the same exact item)on my truck withOUT the overload and I got at least 1.5" of lift. I do not have a topper though.
  13. Jan 16, 2016 at 8:05 PM
    aryant
    Eagle, CO
    MGM '13 TRD OR
    Yes, the overload is still in. It was my understanding though that leaving it in would add lift.
  14. Jan 16, 2016 at 8:07 PM
    aryant
    Eagle, CO
    MGM '13 TRD OR
    Fair enough, I just wouldn't assume the camper is heavy enough to sag 5 leaf springs and an overload that badly.
  15. Jan 16, 2016 at 8:07 PM
    Justinlhc
    Correct. How heavy is that topper?
    Keep in mind dropping the front down will require a new alignment.
  16. Jan 16, 2016 at 8:07 PM
    T4RFTMFW
    Other posters need to not fill his head with nonsense.
    The front looks perfect for that setting. They're not installed wrong, if they were he'd be twice as high up front as he is now.
    His shell is drooping his springs too hard and the 1.5" AAL makes maybe a half inch of lift with a shell on the bed. I had the same setup, and went with new leafs after the shell was thrown on just for this reason. I also had the same leafs as OP does. Everything is normal. He just has the wrong expectations out of the rear AAL and too much preload up front
    Justinlhc likes this.
  17. Jan 16, 2016 at 8:08 PM
    aryant
    Eagle, CO
    MGM '13 TRD OR
    I'm not sure of the exact weight, but if I remember correctly, somewhere in the neighborhood of 200-250lbs
  18. Jan 16, 2016 at 8:08 PM
    T4RFTMFW
    The stock pack is weak, and the AAL only helps marginally with a shell.
    I got 2" of lift with the overload left in, and it all went away except half an inch when I installed my shell which is 225 lbs.
    JohnNP likes this.
  19. Jan 16, 2016 at 8:10 PM
    TXTaco13
    TXTaco13 Taco/T4R Enthusiast
    Dallas, Texas
    4TH GEN V8 4X4 T4R
    '83 CJ7 '19 MT 07
    You aren't going to get much lift with that shell, unless you use a block, or new leaf pack (best option)
  20. Jan 16, 2016 at 8:10 PM
    aryant
    Eagle, CO
    MGM '13 TRD OR
    That makes sense. What do you think about dropping the front down to .85"? Should that level it back out and still be healthy for the suspension?
