not a happy driver so far
Discussion in '2nd Gen. Tacomas (2005-2015)' started by panicfan, Mar 31, 2014.
  1. Apr 2, 2014 at 4:35 AM
    #41
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Replace the automatic with a stick axle wrap won't bother you any more. Want to see a bed move around drive a Chevy. Want to feel gas slush around in a tank drive some thing that holds 35 gallons and has a steel tank.
  2. Apr 2, 2014 at 6:29 AM
    #42
    panicfan
    panicfan [OP] Active Member
    Atlanta
    Tacoma
    This is why I dont even know where to start....
    I just know I wanted a Taco for a while, finally got one, making payments on it, and already trying to figure out whats wrong with it...:mad:
    I love good vibes...but these are making me crazy.
  3. Apr 2, 2014 at 8:45 AM
    #43
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    most are fitted with internal baffles, however they do not extend from bottom to top as they are mainly used for keeping fuel near the pump when the tank is low. If your gas is "thudding" then you're slamming the brakes. Sloshing gas will not thud unless the tank is loose.
    someone had mentioned this to me as well and it kind of makes sense. If I come to a stop going under 20mph it's fine. If I come to a rapid stop, when I let off the brake I get a "release" of something that i can only feel in the cab, no "thud" or noise, almost like the drive-line is preloaded and then released. I can also put it in neutral and get the same result.
  4. Apr 2, 2014 at 10:06 AM
    #44
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 DCLB 4WD
    Just researching the Tacoma "clunk" on TW, Chris4x4 explanation made the most sense to me:
    "Mostly what happens (with automatics) when you are stopping, power is still being sent to the axel. As the power is being sent, the pinion angle moves up, and when stopped, the brakes are holding it in that position. When the brakes are released, the axel is free to return to its original position, causeing a "Thump". "
    As for as a fix,:notsure:, but doesn't hurt to try the cheapest route by greasing the drive shaft.
  5. Apr 2, 2014 at 12:03 PM
    #45
    TacoSupreem
    TacoSupreem Dirty Trucker
    Hayden
    Kentucky
    2013 MGM DCSB 4x4 Sport
    Makes sense
  6. Apr 2, 2014 at 12:06 PM
    #46
    panicfan
    Atlanta
    Tacoma
    I called to get a quote from Toyota on the TSB fix , of course they wont price anything without looking first.
    Anyone paid for this service? How much?
  7. Apr 2, 2014 at 12:08 PM
    #47
    panicfan
    Atlanta
    Tacoma
    where the thump is annoying as hell. The vibrations from 20-30mph and 55-70mph are what really drives me nuts. Took a friend to pick up his car, he said dang man whats wrong with your truck? pretty embarrasing.
  8. Apr 2, 2014 at 12:26 PM
    #48
    Stocko
    Stocko Well-Known Member
    CT
    09 TRD Offroad
    3" ToyTec Suspension Lift, Light Racing UCA's, Spidertraxx 1.5" Wheel Spacers, Mickey Thompson 33" Baja MTZ's, OKLED 40" Cree Double Row Light Bar, GrillCraft Mesh Grille
    :ohsnap:
  9. Apr 2, 2014 at 12:44 PM
    #49
    chas44
    chas44 Well-Known Member
    Virginia
    2012 TRD Sport
    Didn't pay for the TSB service since I am under warranty, but no vibes here anymore.
  10. Apr 2, 2014 at 12:51 PM
    #50
    romeo
    romeo Wombat
    Luis
    Lacey, Wa
    Silver 4x4 DC Sport
    didnt read through all the replies that people have posted but i know a few have mentioned balancing your tires, its good to have them balanced every few thousand miles due to wear and sometimes uneven wear.
    another one that i havent seen but sure has been mentioned is that your drive shaft might need to be checked too, make sure that it doesnt have any dents in it.
  11. Apr 2, 2014 at 2:18 PM
    #51
    ihatecorollas
    ihatecorollas Active Member
    WI
    Icon Coilovers with bypasses. Total Chaos UCA's. Kender Klever At2's
    Can't believe this hasn't been said yet, unless I'm blind, but this guy^
    He's right. Check your u joints. I had the clunk and vibrations of which you speak at certain mph. Replaced rear u joint last week & no vibration or clunk. Jack up the truck & wiggle the Driveshaft. You should be able to feel play.
  12. Apr 2, 2014 at 7:04 PM
    #52
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    I had a 55 gallon Titan tank (unbaffled) in my '06 Duramax and never felt a "bump" from fuel.
  13. Apr 2, 2014 at 7:14 PM
    #53
    wannabetrd
    wannabetrd Well-Known Member
    Zach
    Michigan
    SR5
    3inch front 2inch rear lift with add a leaf and extended brake lines trd exhaust
    For your thud when coming to a stop or taking off mark the two pieces of your rear drive shaft and slide the two pieces apart and put some grease on the splines of the slip joint that should help a little
  14. Apr 7, 2014 at 8:05 AM
    #54
    panicfan
    Atlanta
    Tacoma
    FWIW. Went by Discount tire right by the house to have them inspect tires and balance. They said they wouldnt balance and align because the tires were coned. He said they were fairly cheap tires and were not properly aligned. THey suggested I replace.
    So after checking around - with rebates, the toyota dealer was about the cheapest in town and i could get them to make sure they understood all my issues.
    I went with a set of michelin's ($150 rebate)
    They showed me where i was slightly low on tranny fluid and I had a small leak so they replaced the tail shaft seal.
    While I was there (and had a coupon) I had them replace and resurface front brakes.
    Ride is smooth like it should be now. Shifts so much cleaner than before and the
    all the shakes and vibes seem to be gone.
  15. Apr 7, 2014 at 8:11 AM
    #55
    Fluffymonkey
    Fluffymonkey Token
    College Station, TX
    2013 Trd Sport DC, 07 DC sr5, 03 Prerunner
    2003: Stock 2007: Avid Offroad sliders, 30% front tint, bed mat, Truxedo low-pro qt tonneu cover, aero turbine 2525 muffler w/ 8'' tip, AR25 Resonator, 16x8 Dick Cepek DC-1 w/ 265/75 Goodyear Wrangler Duratracs, 2010 headlights, ome 884 coils with .5'' top plate spacer, OME sport front shocks, bilsten 5100s rear, 2'' aal, locking gas cap, LR ucas, Viper 2-way remote start, afe drop in filter, Rocky locking bike mounts, gear chest, scangauge, pop n lock tailgate lock 2013: most things transferred over from my 07, 5100s @ .85 + eibachs and Toytec tps for 3'' front lift, wheelers progressive aal w/ overload; compustar 2-way remote start; Antennex shorty antenna, pop n lock tailgate lock with programmable key, seat covers, Toyota's crappy all-weather floor mats (should have got Husky's or Weathertechs), TRD skid plate, led light pods mounted in front bumper valence w/ Eyourlife wireless harness and remote, led bed lights, light pods mounted in bed, Devil Horns emblem from Diaz Fabrications, rear facing pod lights in bed, under seat lights,
    Glad to hear you're getting the issues resolved. Any word on the thud?
  16. Apr 7, 2014 at 8:48 AM
    #56
    tacoma guy
    tacoma guy Well-Known Member
    Joe
    Phoenix Az.
    2011 Tacoma Prerunner TRD
    Bilstein 5100's on all four corners. Front set @ 0 with OME 883x coils. Alcon leaf springs. Viper Alarm. Wet Okole seat covers. WeatherTech Floor liners front and back. Oem Toyota chrome exhaust tip. ARE Shell. America Outlaw Wheels.
    X2 ^ A vibration in the steering wheel is a tire balance problem.
  17. Apr 7, 2014 at 8:51 AM
    #57
    Manwithoutaplan
    ID
  18. Apr 7, 2014 at 10:51 AM
    #58
    SGTCap
    SGTCap Well-Known Member
    Cap
    Summerville, SC
    4x4 6-spd,
    37s, 4x4 6-spd, OME 886s, Allpro Expos, SOS sliders and front/rear bumpers,Rack,Skids, 4.56s, Lockers,Recon Winch, TJM RTT, Lots of tools, boxes and gear. Shaggy mutt behind the seat
    People complain about the weirdest stuff
  19. Apr 8, 2014 at 5:46 AM
    #59
    panicfan
    Atlanta
    Tacoma
    Yes, its almost like the OP wants to get his moneys worth out of his investment.
  20. May 10, 2014 at 12:19 PM
    #60
    wileyC
    wileyC Well-Known Member
    Centerville, OH
    2012 PreRunner Double Cab TRD Sport
    ...actually, there is another thread addressing the "thud/thump" thing, ...there is a TSB that was put out for it... I have noticed this on my Tacoma for some time now, ..it's an annoyance... I just don't know if it's worth taking it to a dealer to address it or not...
