Not Able To Get Tsb Done?
Discussion in 'Suspension' started by IRISHDEVIL, Jan 11, 2008.
  1. Jan 11, 2008 at 10:16 AM
    IRISHDEVIL
    IRISHDEVIL [OP] Well-Known Member
    I was unable to get the TSB done on my 07 dble cab because i had already put in my Revtech lift.
    I was able to figure out a cheap and effective way to get more lift as well as keep it from sagging. The kit that i got had AAL 'S and it wasnt or didnt even seem level, guessing because of the sagging spring. So i got a second set of AAL's and had them cut on each end about 1 1/2 to 2 " . I put the new leafs in just like it would be in a more expensive spring pack. Im also still running the stock Bilstiens in the rear.
    Now i have a slight foward rake just like it would be stock, just 2" high.
    Il try and get some pix up of whats been done soon.
  2. Jan 11, 2008 at 12:08 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Sounds like a plan...
    Just keep an eye on your stock leafs.
    When you mix & match leafs (AAL's) - the spring arche probably doesn't match to the original leaf pak and that can cause 'stress' the the leafs.
  3. Jan 11, 2008 at 1:47 PM
    IRISHDEVIL
    I think i really need to get pix up
