Not abusing suspension towing
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Akarantinos, Jul 20, 2022.
  1. Jul 20, 2022 at 9:48 PM
    Akarantinos
    Akarantinos [OP] New Member
    2012 DCLB supercharged TRD Tacoma
    I have 6112s with a preload collar and shim kit on my front end(wescott designs). In the rear I have 5160’s with the full set of Icon RXT’s. I just replaced my old suspension because I have to tow a trailer relatively often and suspension was shot in the rear. Should I go with air lift or some type of summo bump stops? Don’t want to go through this set fast. Thanks
  2. Jul 20, 2022 at 10:01 PM
    Bishop84
    Bishop84 Well-Known Member
    Bags to take load off when towing will reduce fatigue. Sumo's will only contact when loaded and with the RXT's it may only contact some of the time with the trailer.
    A WD Hitch is another consideration.
    TnShooter likes this.
  3. Jul 21, 2022 at 7:38 AM
    MR5X5
    MR5X5 Well-Known Member
    Make sure you load your trailer to keep tongue loads appropriately small.
  4. Jul 21, 2022 at 7:46 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    If the weight of the trailer will remain fairly constant, get a WDH and take the time to set it up correctly. It'll take some of that tongue weight and put it on the front axle of the truck as well as the axles of the trailer. It also provides sway control, depending on which kind you get. I can cruise down the highway at 70-75 mph and the trailer pulls like a dream.
    Bone stock tundra suspension with an 800ish pound tongue weight. Initially, the rear end dropped 3" but once I got the WDH setup, the front and rear both dropped 1/2". WDH are underappreciated, they're pretty clever.
    https://www.youtube.com/watch?v=XBZu39pQ8Gg
