Not buying new catalytic converters
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 96fido96, Dec 6, 2014.
  1. Dec 6, 2014 at 3:47 PM
    Clearwater Bill
    Billy
    Largo Florida
    :lalala:
    You would get a no-start condition way before causing any internal damage. Kinda like the old potato in the tail pipe gag.
  2. Dec 6, 2014 at 3:52 PM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    thanks for the link.......screwing around in there I found out that Doug Thorley is owned by SUMMIT
  3. Dec 6, 2014 at 3:59 PM
    Lord Helmet
    Lord Helmet Prepare To Attack
    Nick
    3rd Gen Tundra WCP TRD OR I-Force Max
    Is that good or bad? :D
  4. Dec 6, 2014 at 4:06 PM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    beats me
  5. Dec 6, 2014 at 4:42 PM
    DriftDreamzSS
    DriftDreamzSS Well-Known Member
    Ventura County
    '14 TRD Sport PreRunner
    Check what the California emissions warranty on the truck is. Its generally much longer than the regular vehicle warranty but an 06 is likely too old, couldn't hurt to check tho.
  6. Dec 6, 2014 at 4:46 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    8 years for catalytic converters.
  7. Dec 6, 2014 at 4:50 PM
    96fido96
    96fido96 [OP] Well-Known Member
    ESQ
    ONTARIO CA
    6cyl 4x4 first gen
    Thanks guys
  8. Dec 6, 2014 at 5:29 PM
    jtv
    jtv Well-Known Member
    Well...Just Back From Hell
    2012 V6PreRunner TRDSport
    King all 4 corners, TRD cat back, OEM 17" TRD rims, Fold-A-Cover
    I got the same problem. But I bolts out cats, soak in soap & water over night. Came out lots of white powder(clog ash). So the cat was insuf. from clogging. I also change out o2. 22K so far no problem
  9. Dec 6, 2014 at 6:04 PM
    username
    username Fluffer
    Pendleton, Or
    05 Taco with some crap welded to it
    mostly stock
    Depends on where you go. I passed cali emissions with no cats and a bunch of missing evap stuff once, but I went to the shady mechanics where nobody spoke english. It cost me $100, but I don't know if that was because I was a white dude or what.
  10. Dec 6, 2014 at 6:29 PM
    MKW
    MKW Well-Known Member
    Murrells Inlet, SC
    2014 RC 4x4
    OME 3" lift MK6 wheels 285 Fierce MTs & 4.88s!!
    I'd move out of California and run what I wanted. Too many stupid regs out there. :D
  11. Dec 7, 2014 at 2:18 AM
    Hans Moleman
    Hans Moleman Well-Known Member
    Bay Area, CA
    2023 F-150 Powerboost
    I doubt emissions techs know how every single oem catalytic converter looks like some there are so many different make/model cars out there.
    I would just get a cheap generic high flow cat.
  12. Dec 7, 2014 at 3:50 AM
    watchdog
    watchdog Well-Known Member
    jim
    nanuet n.y.
    09 tacoma
    Rims and tires , exhaust , stereo , Bhlm ,Changed carpet to black from grey. toytec ultimate lift kit. Allpro front bumper and light bar. In process of blacking out interior. Otrattw switches, black vinyl armrest mod, clazzio leather seat covers with heaters, flowmaster dual exhaust, hornblasters train horns,
    When does the truck go for inspection? All the techs need to see is a shiny new cat on a 8year old truck and the red flags start flying. Can't find anything in the junkyard?
  13. Dec 7, 2014 at 6:02 AM
    western88
    western88 Chris b.
    ny countryside
    2014 SR5 4x4 taco Barclona Red
    beather mod Bugsheild backup light mod egr vent
    yep I would.. Calf is getting a bad place to live with soo many extreme liberal ass*ole who putting too many regs.. they gives me the hemroids when I hears about what Calf is up to.
  14. Dec 7, 2014 at 10:00 AM
    MarkH
    MarkH Well-Known Member
    Mark
    San Jose, CA
    13 PreRunner TRD Off Road
    Hard to tell if a shiny new Cat will result in increased scrutiny during a smog inspection. They do check to verify that a Cat is installed, but I have never seen them give it more than a passing check. Though running a non-CARB approved Cat is always a risk. I once failed a smog test when the tech could not connect the equipment to the gas tank to verify that the tank did not have a vacuum leak, which sent me to a State Referee station. They give the car a much more detailed inspection, and they normally have lifts if needed. Oh, and the idiot tech should have read the state testing guidelines before failing my car, turns out my older BMW was exempt from the gas tank test as the equipment could not be connected to the gas tank filler.
    Generally the smog test stations want to get you in and out as fast as possible and will do the minimum required to meet the state testing guidelines. So if they see a Cat, they just move on to the next item on the visual inspection.
  15. Dec 7, 2014 at 10:17 AM
    #35
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DCSB 4x4
    Yes
    CA is very different, that will not work you must have CARB engraved components AND those components must be registered or listed on the CARB website. As of today there are zero aftermarket cats listed for a 2nd gen Tacoma and that includes any universal cats...none are approved. OE " manifolds " for $1,000 each are the only option in CA. When the tech does the inspection they do a thorough visual inspection of all emission components and reference the CARB site.
    Magnaflow has a very nice header/cat and even y pipe for the 4 cylinder that is CARB certified but there is nothing for the 6 cyl. I called Magnaflow and they stated that they were not pursuing having the 6 cyl version CARB certified :/
  16. Dec 7, 2014 at 10:45 AM
    #36
    96fido96
    ESQ
    ONTARIO CA
    6cyl 4x4 first gen
    Magnaflow I believe has the header/cat for 1st gen Tacoma only not for 2nd gen
  17. Dec 7, 2014 at 10:56 AM
    #37
    Evenflow
    San Diego, CA
    06' DCSB 4x4
    Yes
  18. Dec 7, 2014 at 10:59 AM
    #38
    96fido96
    ESQ
    ONTARIO CA
    6cyl 4x4 first gen
    A yea your right my bad. That may be the direction I will be going. Thanks for info.
  19. Dec 7, 2014 at 10:59 AM
    #39
    Evenflow
    San Diego, CA
    06' DCSB 4x4
    Yes
  20. Dec 7, 2014 at 2:40 PM
    #40
    Crosis
    Crosis Tertiary adjunct to unimatrix 01
    Dunedin Fl
    09 Tacoma 4x4 TRD Off Road
    :facepalm: No beauty is worth the slavery of living in commifornia
