Not Cool
Discussion in '2nd Gen. Tacomas (2005-2015)' started by boulderz, Jun 1, 2019.
  1. Jun 1, 2019 at 8:42 AM
    boulderz
    boulderz [OP] Well-Known Member
    So it is almost hot enough in Vermont to start thinking about air conditioning I don’t have. Was told by the dealer the low pressure AC line is the source of the leak and quote of $500-$600.
    Where’s the low pressure AC line and what’s involved to replace?
    Will worry about vacuum/recharging later.
    Thanks
  2. Jun 1, 2019 at 8:57 AM
    Clearwater Bill
    Billy
    Largo Florida
    It's the line with the fitting that the dime store pressure gauges fit.
    Once you locate that line, look it over and decide if it's something you want to tackle.
  3. Jun 1, 2019 at 9:10 AM
    IwasDacapsterAz
    IwasDacapsterAz Well-Known Member
    Cap
    14 4w4 Taco Access
    Bamf and Bilstien
    Yea there is this little thing about certification, your not allowed to willy nilly let those gases go into the atmosphere, Online course and recovery equipment are required. That said invite me over when you do and I'll turn you into the EPA and get a cool 10K. )
    Crodell6 likes this.
  4. Jun 1, 2019 at 10:26 AM
    boulderz
    Pretty sure the gases are already gone.
    And please don’t turn me in, I’m begging you. Next..
  5. Jun 1, 2019 at 10:32 AM
    IwasDacapsterAz
    Cap
    14 4w4 Taco Access
    Bamf and Bilstien
    Hahaa
    If I had the machine I would help you for free
    PzTank likes this.
  6. Jun 1, 2019 at 11:12 AM
    ChemDawg
    ChemDawg Well-Known Member
    Maine
    2005 sr5 4x4
    :facepalm:
    Crodell6 and Jeffch like this.
  7. Jun 1, 2019 at 11:47 AM
    CurtB
    CurtB Old Timer knowitall
    Curt
    Kansas
    2010 Tacoma SR5
    The high pressure line is far more likely to leak. I suggest making sure where the leak is, unless you trust a dealer.
  8. Jun 1, 2019 at 3:51 PM
    Jeffch
    Jeffch Well-Known Member
    Jeff
    Vermont
    2018 off road
    Running 285/75/16s
    Where you at in VT?
    It got up to like 60 and no sun today.
    I have a rodent free garage we can do it in.
    I got the tools needed.
    Did my compressor a couple yrs ago.
    Put some of the dye stuff in and see if you can find the leak.
    doorsidedown and IwasDacapsterAz like this.
  9. Jun 1, 2019 at 8:06 PM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    This ^
    Jeffch[QUOTED] and doorsidedown like this.
  10. Jun 1, 2019 at 8:10 PM
    doorsidedown
    doorsidedown Well-Known Member
    Haha I see what u did there. Literally “not cool” ... well played. I’ll see myself out.
    :cheers:
  11. Jun 2, 2019 at 1:04 AM
    jboudreaux1965
    jboudreaux1965 Ragin Cajun Fan
    Joseph
    Hub City
    2023 TRD Sport
    If line failed the refrigerant probably leaked out. But to be safe, tap the valve and see if anything comes out. If not, replace the line, have a shop Evac the system, pull the remaining oil out, put fresh oil and refrigerant. $150 or so for part, oil, refrigerant, and an hour labor (if you buy and install part yourself).
  12. Jun 2, 2019 at 1:13 AM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    That was a very misleading title, haha.
  13. Jun 2, 2019 at 1:18 AM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    I guess I won't be getting my certs, then will I?
  14. Jun 2, 2019 at 1:25 AM
    koditten
    Kirk
    Central Michigan
    The dye does work, but you have to charge the system and run it with the leak.
    Pressurizing the system with nitrogen then spraying every component with soapy water works very good. Plus you are not venting R134 to the atmosphere.
    I'm betting you find the bubbles pretty quick.
  15. Jun 2, 2019 at 3:07 AM
    Athlaos
    Athlaos Destruction Mode
    Leigh
    Edmonton
    2011 SR5 Manual TRD SC 1.87" pulley
    A flux retro-capacitance encabulator
    I like to vent to atmosphere because I'm libertarian and don't care about regulations or laws.
    Alexely999 and fixer5000 like this.
  16. Jun 2, 2019 at 5:01 AM
    Berniebikes
    Berniebikes Well-Known Member
    Bernie
    Williamsburg, VA
    2015 White TRD OR Double Cab
    this is the way to go. Buy yourself a set of gauges ($40 or so from Harbor Freight) and a bottle of nitrogen (available at a HVAC supply place). Connect up the gauges and bottle, and charge to 30 or so on the low pressure side, the larger of the two ports. Mix a sparay bottle of water with an ounce or so of dish soap and with the AC system running after the charging spray around hoses and fittings till you find the leak. It should bubble enough you will see where the system is leaking. Once you find the leak, change out the line/fitting/part and take it to a good shop to have it fully evacuated (very important) and recharged. I would also suggest you change/replace the filter/dryer. Good Luck
  17. Jun 2, 2019 at 6:16 AM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 DCLB 4WD
    He's right. OP, online course and recovery equipment are required. I had to fullfill both requirements before charging my a/c recently. These are mine:
    [​IMG][​IMG]
    RacecarGuy likes this.
  18. Jun 2, 2019 at 6:19 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I’m a very DIY guy but IMO AC is one of the things I’ll just let the professionals handle.
  19. Jun 2, 2019 at 6:30 AM
    boulderz
    Hey thanks for the offer. Tools and garage are no problem, I do all my own work just wanted to see if anyone had done the job and if it was a PITA or anything.
    I’m in Rutland county. Down in CT this weekend wishing AC was working!
  20. Jun 2, 2019 at 6:37 AM
    boulderz
    I may end up going this route, some things are better left to a tech but then there’s the side of me that hates paying through the nose for something I could do. Then I do it and wish I had paid somebody..
    EatSleepTacos[QUOTED] likes this.
