Not engaging gears
Discussion in '1st Gen. Tacomas (1995-2004)' started by Yourstruly_diego, Aug 14, 2018.
  1. Aug 14, 2018 at 5:13 PM
    Yourstruly_diego
    Yourstruly_diego [OP] Member
    2004 Toyota Tacoma trd v6 4x4
    So my Truck was driving fine and shifting smoothly. I parked in the garage after a drive and when i got in the truck the following morning to take her out I couldn't get her into reverse to back her out of the garage. I also can't get her into any of the other gears unless I use both my hands and use all my force while my foot on the clutch all the way to the floor to engage the gears. How can I fix this before it gets worse? Thx
    2004 Tacoma v6 4x4 5spd
  2. Aug 14, 2018 at 6:48 PM
    Bahamayellow
    Bahamayellow Well-Known Member
    2002 tacoma sr5
    Check you clutch master cylinder to makes sure its not low on fluid. Could be bad clutch master cylinder or clutch.
    Russianman92 likes this.
  3. Aug 14, 2018 at 7:05 PM
    E30325
    E30325 Well-Known Member
    Nick
    2000 Tacoma TRD 5spd
    5100's and OME 881's, AAL and KM3's
    Could be the slave cylinder too. Do all the gears shift fine with the truck off?
  4. Aug 15, 2018 at 3:56 AM
    Yourstruly_diego
    Yeah they shift fine but it seems 3-5 gears are not going into place. Mannn this morning it was hard putting it in reverse and taking it out of reverse, I was stuck in the middle of the neighborhood street for 8min trying to put it in neutral.
  5. Aug 15, 2018 at 3:58 AM
    Yourstruly_diego
    Fluid is fine and leveled but I was thinking of bleeding it possibly there could be air in it
  6. Aug 15, 2018 at 4:10 AM
    Clearwater Bill
    Billy
    Largo Florida
    If the master has failed via an internal bypass, the fluid level will be fine with no clutch response.
  7. Aug 15, 2018 at 6:22 AM
    Russianman92
    Russianman92 Well-Known Member
    Dunwoody GA
    1995 White Tacoma 3RZ 4x4 5 speed
    bilstein shocks/struts Add-a-leaf Mostly stock. Running 31x10.5 r15
  8. Aug 15, 2018 at 5:42 PM
    Yourstruly_diego
    Russianman92[QUOTED] likes this.
  9. Aug 15, 2018 at 9:14 PM
    Topic Thunder
    Topic Thunder Active Member
    Hamner Head
    03 Tacoma Sr5 2wd 2.4 5spd
    Currently taking off decals. New wiper blades and vent visors
    My 03 started having trouble going into 4th every once in a while. I changed the shifter bushing and the little ball that is on the bottom of the stick. It was like 25 bucks from the dealer for both pieces. Very easy to do. Just search shifter bushing replacement on google for your vehicle. Maybe your ball broke and it wont engage any gear? Either way its fairly easy to check at least. Good luck and keep us posted.
  10. Aug 16, 2018 at 4:37 AM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    Mine was popping out of gear and not going in all the way to 4th. It was the shifter bushings. Id get that done first as its probably your cheapest option.
  11. Aug 16, 2018 at 9:04 AM
    Xbeaus
    Xbeaus Well-Known Member
    Beau
    Black hills South dakota
    98 Tacoma 3.4 5 speed SR5 limited TRD 4x4
    Toytec coilovers. Height adjustable Bilstein's. 265/75/16 MT. TRD wheels. Rebuilt r150f. Marlin clutch kit. All kinds of new parts...
    Careful yanking on the shifter. Don't want to damage the shift forks or better yet - shear a bolt off in there. Ask me about that last part ;) Can you pull up on the shifter and notice any play? I second the slave and master cylinder replacement. It's relatively inexpensive to replace them if you do it yourself. How many miles on the clutch? do you know? Could be a host of things.
  12. Aug 26, 2018 at 7:36 PM
    Yourstruly_diego
    Whatsup guys I did change out the slave and master cylinder and it seems to work way better now so far.
    Russianman92 and Bahamayellow like this.
  13. Sep 17, 2018 at 8:20 AM
    LoneStarTaco
    LoneStarTaco Well-Known Member
    Skylar
    Longview
    01 Xtra Cab TRD 4x4 Std
    Toolbox, 265/70/16 BFG AT's
    Any tips on the master/slave replacement? Having the same issue and probably doing the same thing this weekend.
  14. Sep 17, 2018 at 10:40 AM
    Xbeaus
    Beau
    Yes. Have the proper 10mm flare nut wrench. You strip those brake line fittings and it will ruin your day. Make sure to get all air out of lines. Pretty straight forward easy repair
  15. Sep 17, 2018 at 11:08 AM
    LoneStarTaco
    Skylar
    Longview
    Cool thanks. I'll go get a flare nut wrench before I start.
  16. Oct 30, 2018 at 11:50 AM
    Russianman92
    Dunwoody GA
    Don't know if you have already done this but a tip for bleeding the clutch:
    Get a 1 foot piece of Vacuum line that can fit over the end of an oiler can that you can pick up at any auto parts store. kinda like this one but maybe bigger: https://shop.advanceautoparts.com/p/toughone-engine-1-4-pint-pump-oiler-w241/7070012-P
    Add a little bit of brake fluid to the master (only enough to fill the reservoir 1/8 of the way) leave the top off.
    Take the oiler and fill it up with brake fluid. Open the slave cylinder under the truck, open the nipple and stick the vacuum line on it. Start pumping till you fill the reservoir 3/4 the way up (you can kinda guess how much you added) then close the nipple and pump the pedal. If done correctly your pedal should feel perfect since you just bled the clutch system from the bottom and just need to finish adding a little bit of fluid to the master.
