Not exactly level!
Discussion in 'Suspension' started by Jpf8653, Jul 26, 2009.
  1. Jul 26, 2009 at 5:25 PM
    Jpf8653
    Jpf8653 [OP] Well-Known Member
    Justin
    Baton Rouge,LA
    Revtek 3" lift, Tinted Windows Wheels n' Tires Door Sill Protectors Rockford fosgate P3 shallow w/ alpine mono 500 amp in a MR MARV PORTED box Weathertech floor liner Rear TSB Pioneer 3200BT Double Din touch screen
    I have a 3" rev spacer kit on my DC and with the rear tsb done my truck doesn't sit level plus i wouldnt mind fitting full 33s without trimming. basically what im going for is there anything else i can do to lift the front just slightly to balance or even have the front just a little bit higher.
    I dont know if UCA's or something like that would do it or not. Do they make like a 1" body kit or something i can apply just to the front or even the whole truck just to fit 33's without rubbing.HELP!
  2. Jul 26, 2009 at 5:37 PM
    RDAY
    RDAY Well-Known Member
    NY
    07 Tacoma SR5 4x4
    not sure what the prob is i went with a 3" toytec coilover kit and a 1.5" add aleaf for tsb and mine sits perfectly level not sure if its a diff because u went with spacer and i went with coilover.
  3. Jul 26, 2009 at 5:53 PM
    Jpf8653
    Justin
    Baton Rouge,LA
    Its not like its really bad. its actually not bad at all. i just like the exact or slightly higher in the front look. and TIRE size
  4. Jul 26, 2009 at 6:39 PM
    r12rex
    r12rex Well-Known Member
    Cleared headlights, Black emblems, Painted black valence on front bumper, 2.5" 5100 Billys front, 1.5" AAL rear, Satin black TRD O/F wheels with 265/75 16 Definity M/T, Spidertrax spacers
    The rear TSB does not provide enough height to level the rear of the truck with a 3" lift up front. You will need to purchase a TSB AAL from toytec that adds 1.5" of additional lift to the rear. Your truck will be level and you should have no problems with 33" tires. Minor trimming is involved in the front though.
    Kind Regards,
    Hope that helps!
  5. Jul 27, 2009 at 6:18 AM
    Jpf8653
    Justin
    Baton Rouge,LA
    I have the complete revtec system not just the front spacers I have the blocks in back with the tsb. The nose is not level. The back is higher. Guess I should have been more specific.
  6. Jul 27, 2009 at 8:20 AM
    sirsaechao
    sirsaechao Well-Known Member
    Tim
    Commifornia
    2002 Toyota Tacoma SR5 TRD 3.4L 4X4 V6
    To much to list...see sig for more...
    BL is just like it says...and no they do not make a BL for the front only. My only suggestions is wait for it to settle or spend some money and get some adjustable coilovers up front. Another suggestion is ditch the rear blocks and have either a custom leaf pack made or get a TSB AAL or custom shackles.
  7. Jul 27, 2009 at 6:59 PM
    Jpf8653
    Justin
    Baton Rouge,LA
    Well i HAVE the TSB AAL!! And im not woried about the back. blocks dont bother me and never have on any of my trucks. And far as body lifts i was asking if they make something small such as a 1" or 2". Thanks for answering if they made front only ones. Didnt think they did just curious though.
