Not getting any electrical power
Discussion in 'Technical Chat' started by Penten, Oct 24, 2017.
  1. Oct 24, 2017 at 6:01 PM
    Penten
    Penten [OP] Well-Known Member
    Peter
    Iowa
    Alright gonna try to be as detailed as possible here, I have a 96 4runner 5 speed. I blew a clutch and decided to change it out. So I dropped the transmission and replaced the clutch. However now I have no dome light or anything. I will say before I loaded it up on a trailer to move it I had full power , I rolled down the windows and everything. also note I had all the harnesses coming off the tranny while I still had power and before I loaded it.
    Things I've done already-
    Replaced and tested new battery
    Replaced 100AMP fuse
    Replace 30AMP power fuse under the steering wheel
    Ran a test light to all 4 batteries coming off the battery ( All tested good with a test light)
    I also replace the head, starter, and heater fuse just because
    Now I was able to get a door chime by prodding the test light into a harness running into the ECU but it was very weak.
