Not getting fuel to engine.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by waydwnsouth, Mar 8, 2019.
  1. Mar 12, 2019 at 11:11 AM
    #41
    waydwnsouth
    waydwnsouth [OP] Active Member
    Finally got around to getting a fuel pressure gauge. What range am I looking for?
    b_r_o likes this.
  2. Mar 12, 2019 at 11:25 AM
    #42
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    While running/cranking, ~43.5 psi.
    b_r_o likes this.
  3. Mar 12, 2019 at 11:27 AM
    #43
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Thank you. He's now the 3rd with this setup. @loginfailed was the second. I took his welded-on plate idea, and did it to Lucario's. Mine, I bolted through the bottom of the frame. As I couldn't weld at the time.
    Super functional and can handle any fuel type. Easy to add a pressure gauge tap as well.
    Lord Helmet, loginfailed and b_r_o like this.
  4. Mar 12, 2019 at 12:32 PM
    #44
    FrostyEldin
    FrostyEldin Well-Known Member
    Austin
    Lewiston, ID
    2008 SR5 Impulse Red
    Try disconnecting your battery for a few minutes and then reconnect it, should reset the ECU.
  5. Mar 12, 2019 at 1:22 PM
    #45
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    What other fuels have you used in your truck?
  6. Mar 12, 2019 at 3:07 PM
    #46
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    :hattip:
  7. Mar 12, 2019 at 3:21 PM
    #47
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Can. Have not used any other than gas with ethanol.
    b_r_o[QUOTED] likes this.
  8. Mar 12, 2019 at 3:33 PM
    #48
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    How are you planning on attaching the pressure gauge? Does it have fittings to adapt to the OEM lines?
  9. Mar 13, 2019 at 12:58 PM
    #49
    waydwnsouth
    I got a loaner from the parts house, can’t figure out how to attach it to the fuel line. Doesn’t have a fitting like other make vehicles.
  10. Mar 13, 2019 at 1:14 PM
    #50
    waydwnsouth
    Gauge jumped up to 100 psi. Held steady at 80 while cranking.
  11. Mar 13, 2019 at 7:25 PM
    #51
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    That doesn't sound right, but definitely isn't a lack of fueling, according to the gauge. Lol
    inwood customs likes this.
  12. Mar 13, 2019 at 7:38 PM
    #52
    waydwnsouth
    That’s what I said. Im not sure why it reads so high. But it’s definitely not a fuel issue. Unless it’s flooding or something.
  13. Mar 13, 2019 at 8:14 PM
    #53
    Muddinfun
    Muddinfun Well-Known Member
    You deadheaded the fuel pump. That is the max the fuel pump is capable of pumping. The fuel pressure regulator is not involved in your pressure test.
    blu92in99, Torspd and b_r_o like this.
  14. Mar 14, 2019 at 7:39 AM
    #54
    waydwnsouth
    This is the line I tested circled in red. On the metal tubing side.
    b_r_o likes this.
  15. Mar 14, 2019 at 9:32 AM
    #55
    DriverSound
    DriverSound Señor Member
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    This. The fuel pressure regulator is located on the back side of the fuel rail. Your test PSI is correct.
  16. Mar 14, 2019 at 9:34 AM
    #56
    waydwnsouth
    I gotcha. I thought 43 PSI was a lot for a V6 engine.
    So I'm getting fuel and spark, but still won't fire. What else can I check for?
  17. Mar 14, 2019 at 9:36 AM
    #57
    DriverSound
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    I am unsure if our fuel rails even have a port to check for pressure but I'd check the regulator just in case.
  18. Mar 14, 2019 at 11:17 AM
    #58
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Lord Helmet and DriverSound like this.
  19. Mar 14, 2019 at 11:21 AM
    #59
    waydwnsouth
    Yeah 75 is a little much for something like that. I mean I pulled my spark plugs and they have fuel, just will not fire up at all. You'd think it'd at least spit and sputter if it was a fuel delivery problem.
  20. Mar 14, 2019 at 11:25 AM
    #60
    DriverSound
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    The no idle doesn't seem like a fuel issue to me unless the regulator completely failed and blocked which I've never actually come across before.
