Not getting fuel to engine.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by waydwnsouth, Mar 8, 2019.
  1. Mar 23, 2019 at 8:29 AM
    #81
    waydwnsouth
    waydwnsouth [OP] Active Member
    Could my fuel pump regulator be the culprit?
  2. Mar 24, 2019 at 3:49 PM
    #82
    waydwnsouth
    I give in at this point, going to try and find a mechanic. Thanks for all the help guys.
  3. Aug 10, 2019 at 1:07 PM
    #83
    digitalferg
    digitalferg Well-Known Member
    Southern Utah
    2006 1G Tundra DC TRD 4x4
    Hey @waydwnsouth , did you ever get this no-start issue figured out? I seem to have a real similar issue... Drove my truck down a pretty bumpy dirt road, drove the few minutes home and parked it, came out a few hours later and have crank, but no-start. Digging in with Techstream, seems to be electrical, but I am not an engine troubelshooting wizard. Curious where yours ended up...
  4. Aug 10, 2019 at 1:10 PM
    #84
    waydwnsouth
    Never did. I started driving my other trucks.
  5. Mar 31, 2020 at 7:28 PM
    #85
    Hgian808
    Hgian808 New Member
    06 tacoma TRD sport
    @digitalferg
    Hey did you get your truck running? Now i have this problem.. no codes but turns over with starter fluid in intake.
  6. Jan 4, 2022 at 12:26 PM
    #86
    FishaRnekEd
    FishaRnekEd Well-Known Member
    New Orleans, LA
    2005 4.0 6spd 4x4 Dbl Cb short bed
    Yep, same problem here...
  7. Jan 4, 2022 at 12:31 PM
    #87
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Check the IGN no.1 fuse
  8. Jan 5, 2022 at 5:29 AM
    #88
    FishaRnekEd
    New Orleans, LA
    Thanks. I did. I checked every fuse and replaced all the relays. The truck starts and runs fine one day, but at random, it will crank and not start.
    When it does that, i can spray starter fluid and it will run on that for a minute.
    I even unplugged the fuel pump resistor and jumped the wires, that didn't make a difference.
    Then, it will randomly start and run fine. When it starts, it runs fine.
    I've been chasing wires looking for a damaged connection or something.
    About to pull the bed off and look at the fuel pump.
    Truck is an 05 4.0 4x4 with 180k
    Absolutely no obd2 codes at all. No gas in the oil, no other symptoms. I pulled the fuel line under the hood and it did squirt while cranking. But i haven't gotten a fuel pressure gauge yet.
    I'm thinking that the factory filter in the tank is probably clogged. Seafoam and other cleaners haven't appeared to make a difference (i always put a cleaner once a month)
  9. Jan 5, 2022 at 5:31 AM
    #89
    FishaRnekEd
    New Orleans, LA
    I might take the fuse box apart. Could be a spider nest in there or something coroded maybe. IDK
  10. Jan 5, 2022 at 6:12 AM
    #90
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    180k, I have a feeling that your fuel pump is about aged out.
    Should all wiring be good.
    You said you had a squirt. That could be interpreted a few ways. However, a better check would be to disconnect the fuel line by the tank. Point it into a bucket, and have someone crank the engine to start. That fuel should come out with a good force. Simple man's test.
    This is one reason why I wish OEM made it easier to have a gauge installed for testing. URDUSA.com does have an adapter that attaches between the fuel rail and the fuel pressure regulator, if you wanted one for keeps.
    b_r_o and BassAckwards like this.
  11. Jan 5, 2022 at 6:15 AM
    #91
    BassAckwards
    It certainly does seem like a fuel pump issue.. If you're gonna go through the effort to get to the old one, you should go ahead and upgrade the pump and convert to an external filter like w/ the kit URD offers. That's where i'd start at least
    https://urdusa.com/urd-2005-tacoma-v6-fuel-pumpfilter-upgrade-kit/
    Torspd likes this.
  12. Jan 5, 2022 at 6:18 AM
    #92
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    I’m going to guess ecu
    b_r_o likes this.
  13. Jan 5, 2022 at 6:19 AM
    #93
    FishaRnekEd
    New Orleans, LA
    I ordered one two days ago. They replied that they are out...
    Torspd likes this.
  14. Jan 5, 2022 at 6:21 AM
    #94
    FishaRnekEd
    New Orleans, LA
    Thanks. I'm solo right now, so i just cranked it quickly in a cup just to see.
    I got an extra pair of hands coming later to help take the bed off
    Torspd[QUOTED] likes this.
  15. Jan 5, 2022 at 6:22 AM
    #95
    FishaRnekEd
    New Orleans, LA
    I really effin hope not
  16. Jan 5, 2022 at 6:24 AM
    #96
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    That would definitely suck.
  17. Jan 5, 2022 at 6:41 AM
    #97
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    When it doesn't start do you have a flashing security light in the middle of the dash next to the clock?
    It's not very common for a fuel pump to be intermittent, when they quit they usually stay broke.
    b_r_o and TnShooter like this.
  18. Jan 5, 2022 at 10:46 AM
    #98
    FishaRnekEd
    New Orleans, LA
    No
    My 05 base model doesn't have any security.
    Not even a clicker to open the doors LMFAO
  19. Jan 5, 2022 at 10:49 AM
    #99
    FishaRnekEd
    New Orleans, LA
    Update, here is how intermittent the problem is. Truck left me stranded for a few days now, i decided to change the plugs (ngk iridium, only 50k and looked fine) and oil while I'm waiting for a fuel pump.
    She starts as normal now, repeatedly.
    I bet if i go somewhere without a backup plan, she won't start again.
  20. Jan 5, 2022 at 10:58 AM
    #100
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    I was thinking all the v6 2nd gens had an immobilizer weather they had keyless entry or not but I could be mistaken.
