Not Getting Over 25 MPG With A Mostly Stock V6 4X4 Tacoma? It's Your Damn Fault. Friday Edition.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TRD-ED, Apr 26, 2022.
  1. Jul 12, 2022 at 7:50 AM
    #241
    Syncros
    Syncros Well-Known Member
    I'm averaging 18.9mpg in a '10 Frontier Pro-4x 6spd manual with 265/75R16 LRE KO2s. It consistently does just shy of 23mpg on long trips (10% city, 90% highway). I'll often drive all day in 4hi on rough gravel roads (<40mph) with a bit of 4lo action here and there and see 20mpg. Short, frequent city trips? 15-16mpg, especially in winter.
  2. Jul 12, 2022 at 7:51 AM
    #242
    TRD-ED
    TRD-ED [OP] Well-Known Member
    Lenoir NC.
    2020 Army Green TRD PRO - 2023 Genesis GV70
    Stock FOX 275/65/18 At3w 18X9 Fuel Vapor's
    Probably so. Considering you live in CO.
  3. Jul 12, 2022 at 7:57 AM
    #243
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    I got 20-21 occasionally depending on where I drove but over 9 full tanks I think I averaged about 19.7. Biggest mpg killer is speed and tires. I noticed mpg drops at speeds over 65 especially around 80-85
  4. Jul 12, 2022 at 8:01 AM
    #244
    Gen3TacomaOBX
    Gen3TacomaOBX Well-Known Member
    S
    2018 Tacoma DCSB SR 4x4
    Bilstein 6112 front / 5100 rear (extended) shocks, Headstrong AAL, Firestone airbags, 4.88 gears, OME Carrier bearing drop kit, Aluminum 1/4" skids (engine to transfer). Custom sliders (1.75" HREW tube w/ 3/16" base plates). Custom front bumper and high clearance rear bumper (1/4" steel plate, 1.75" tube.) Apex 5500 winch w/synthetic line (36lbs) and required accessories for an underpowered winch (snatch blocks and extra line.) Tekonsha P3 brake controller, remote start, any-time-backup camera w/ front facing camera, Leer 100R shell (w/e-track single slot tie-down mounts for removable Yakima EasyTop.) Cat shields by CaliRaised. Husky liners, window tint, heated seat (passenger only.) Relentless bed rail brackets with QuickFists (shovel/axe/fire extinguisher.) Hondo Garage Un-holey vent mount. Anytime rear with front facing camera. Billet front seat risers. Viair 88p. 265/75r16 Goodyear Ultra-terrain tires.
    Exactly and thank you.
    When someone posts "running XX inch tires" in a MPG thread without specifying the size and weight it really doesn't help since tires can vary drastically.
    We see it day-in-day-out here on TW when new Taco owners immediately switch out their stock 31 lb oem balloon tires for 70 lb E-rated heavy MFers and then proceed to biatch about mileage.
    33yrsoftoys and SwollenGoat like this.
  5. Jul 12, 2022 at 8:06 AM
    #245
    33yrsoftoys
    33yrsoftoys Over 40yrs now
    joel
    mid Michigan
    2021 dcsb off road 6 speed manual
    Bilstein 6112's 5th clip 1/4" spacer driver's side. Icon tubular UCA's with Delta joint, wheelers superbumps, ECGS bushing. Allpro standard leaf packs, 5160's, U bolt flip kit with wheelers super bump's, extended stainless steel brake lines, carrier bearing drop. Icon rebounds 17" with Nitto terra grappler G2's 285/70/17's.
    It's been my observation that they love flat ground and low elevation too. I have a 21 OR MT lifted 2 1/2" with 285/70/77 nitto Terra grapplers that weigh 44.53#. Adjusted 1.34mpg for tire size. This is my last 5 tanks doing the hard math,,,
    20.8
    21.3
    21.3
    21.5
    20.6
    250 to 300mi between fills.
    This is flat ass central Michigan, 55-65mph roads with few stops. Around 10% city, and I time the lights. Light pedal, shifting between 1800 to 2000rpm. If I run these 75-85mph freeways around here, 18-18.5 if I'm lucky.
    That's the best hard data I have.
  6. Jul 12, 2022 at 8:17 AM
    #246
    Gen3TacomaOBX
    S
    Those are respectable MPG numbers for having a manual transmission and ~45lb 285s (stock wheels?)
    I agree with the flat ground and low elevation for reproducible 20+ MPG tank averages (w/"normal" driving) and believe it'd due to our low torque #s in the hyper-mile sweet spot of 1650-1700 rpm (at least that's the sweet spot for my AT SR 4x4 v6 w/265s at 40lbs.)
    As much as we biatch about the truck.. I enjoy that I can stretch the MPG when wanted by driving like a grandpa and still get 15 mpg when driving like a hooligan (I'm a flat-lander most of the time.)
  7. Jul 12, 2022 at 8:29 AM
    #247
    33yrsoftoys
    joel
    mid Michigan
    LOL, you're right about that. I've always been able to beat mpg estimates in the city and 55-60 mph roads, but these 75mph freeways are a mph killer for the MT. At 75-80 I'm running 2600-2700rpm. Can't fix that.:annoyed::thumbsup:
    Gen3TacomaOBX[QUOTED] likes this.
  8. Jul 12, 2022 at 8:32 AM
    #248
    BrassEnthusiast1
    BrassEnthusiast1 Member
    SE Michigan
    '22 TRD OffRoad
    Do these trucks tend to break in and get better MPG as they settle in and get a little wear on them? My first tacoma, currently getting at best 21 on the highway, all stock.
  9. Jul 12, 2022 at 8:36 AM
    #249
    EarthCruzn
    EarthCruzn Well-Known Member
    Florida
    2022 TRD V6 4WD Manual 6 Speed
    DCSB SPORT
    Yes, the Tacoma has a transfer box for the 4WD that allows 2High - 4High - 4Low selections.
    Gas mileage is less due to 600lbs of weight (4WD equipment) and usually larger tires.
    Some have lower gearing as well, I have the 6 speed manual and it has 4:30 gears.
    Automatics have 3:909 gears stock.
    Here is the options and reasons;
    https://youtu.be/9DA2M3G7pqs
    stftaco[QUOTED] likes this.
  10. Jul 12, 2022 at 8:39 AM
    #250
    TRD-ED
    Lenoir NC.
    I think most agree that after around the 10K-15K miles. The mileage does improve some.
  11. Jul 12, 2022 at 8:42 AM
    #251
    33yrsoftoys
    joel
    mid Michigan
    I think so. Mine seemed to. Really hard to tell for me though, I took delivery of mine the end of October 21. Right into cold temps and winter gas so my experience might not be accurate. My truck really didn't like the cold weather for MPG's. 17-18mpg stock. No noticable change when I lifted and went to the bigger tires either. Big change when it got warmer.
  12. Jul 12, 2022 at 8:43 AM
    #252
    BrassEnthusiast1
    SE Michigan
    '22 TRD OffRoad
    Ill have to keep an eye on it and see if it improves after putting some miles on it. Only have about 1k on it now
    33yrsoftoys[QUOTED] likes this.
  13. Jul 12, 2022 at 8:43 AM
    #253
    digitalzombie
    digitalzombie Well-Known Member
    4x4 long bed, 15mpg ish...
  14. Jul 12, 2022 at 8:44 AM
    #254
    SSMTRDOR
    SSMTRDOR Well-Known Member
    2020 TRD OR 4X4
    Normally ~19/19.5 per tank. OP is correct, my foot's kind of heavy.
    TRD-ED[OP] likes this.
  15. Jul 12, 2022 at 9:08 AM
    #255
    TRD-ED
    Lenoir NC.
    SSMTRDOR[QUOTED] likes this.
  16. Jul 12, 2022 at 9:09 AM
    #256
    Gen3TacomaOBX
    S
    Are you rolling on 35 inch 73 lb tires and talking MPGs?
  17. Jul 12, 2022 at 10:14 AM
    #257
    JoeCOVA
    Joe
    Colorado Springs
    Those numbers were stock tires and stock gearing at the time. I have an MPG chart in my 5.39 thread as I tracked mpgs on stock tires with stock gears, stock tires and 5.29 and then with 35s.
  18. Jul 12, 2022 at 10:15 AM
    #258
    Newwt
    Newwt Well-Known Member
    Tampa, FL
    21 SUPER WHITE TRD OR 4X4 , 24 BCM TRD OR
    I feel like gas changed at some point this year when the prices went up, I used to get ~19 and now I average around 16 on a stock trdor
  19. Jul 12, 2022 at 10:24 AM
    #259
    TRD-ED
    Lenoir NC.
    Probably like everything else. Shrinkflation. You're not getting a full gallon of gas.
  20. Jul 12, 2022 at 10:26 AM
    #260
    BigDaveP
    BigDaveP Member
    Dave
    ‘21 Tacoma TRD Off Road
    KDMax Pro tune (new in November ‘21)
    I run bone stock, tires and everything. I can reset the overall mileage while I'm rolling, and if I keep the cruise at 65, I can coax 23 mpg out of my 2021 TRDOR. Go to 70 and it will still barely stay over 20 mpg. But any passing revs, or stops and starts on the trip, and the mpg drops under 20.
    I didn't buy it for mileage, and considering what it is, the mileage is quite acceptable.
