Not going into gears easily in MT
Discussion in 'Technical Chat' started by Bobo_1, Aug 12, 2010.
  1. Aug 12, 2010 at 6:23 AM
    Bobo_1
    Bobo_1 [OP] Well-Known Member
    Bobo
    Maryville, TN
    09 TRD Sport L-Bed
    I just bought a new 09 Tacoma but didn't trade the old 1996 T100 truck in. I am not sure if I will keep it or just sell it for cheap. Engine is in good shape. Within the year replaced front and rear main seals and a new clutch. I bought the new truck because the T100 is having trouble going into a gear. Is there anything I can do to rectify this beside replace/rebuilding the manual transmission? What is the cause? Shift forks?
  2. Aug 12, 2010 at 6:26 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    If you have an issue with just one particular gear, it is more than likely the synchro for that gear. About the only thing you can try (without actually replacing the synchro) is changing to a synthetic gear oil. I would suggest Mobil 1 or Amsoil severe gear.
  3. Aug 12, 2010 at 8:13 PM
    Bobo_1
    Bobo
    Maryville, TN
    09 TRD Sport L-Bed
    How involved is replacing a synchro? Not as involved as a rebuild or does it require a rebuild?
  4. Aug 13, 2010 at 5:27 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
  5. Aug 14, 2010 at 7:47 AM
    Bobo_1
    Bobo
    Maryville, TN
    09 TRD Sport L-Bed
    Thanks for the reply and links. I don't want to do a rebuild as any time I have needs to go to the new truck and my bikes. Will see if the sythentic gets me a little further. And then I may have to just sell it or give it to charity.
  6. Aug 14, 2010 at 7:50 AM
    HondaGM
    HondaGM Roll Tide
    James
    South-Pole
    09 DC 4x4 Blown Honda VTEC V8
    trd exhaust,step bars,vent visors,bed lights,tailgate mod
    does it shift good when the engine is off,if so your pressure plate may not be fully releasing
  7. Aug 15, 2010 at 11:22 AM
    Bobo_1
    Bobo
    Maryville, TN
    09 TRD Sport L-Bed
    Ooooh, good one. Have to check that!
  8. Aug 15, 2010 at 6:18 PM
    Bobo_1
    Bobo
    Maryville, TN
    09 TRD Sport L-Bed
    Thanks for the pointer! If I can't get it into reverse I can turn the engine off and then it will just slide right in.
    When I had the clutch replaced (less than a year ago) we replaced the hydraulics too. I have replaced the clutch on my Trans Am and there was no adjustment that I can remember for the pressure plate. Is there something that I can do on the T100 to get the pressure plate to fully release? Looking at the manual doesn't seem I have many adjustments beyond pedal free play.
  9. Aug 15, 2010 at 6:27 PM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    The reverse thing is normal. If you got to first then to reverse it should slide right in. There is no adjustment.
  10. Aug 16, 2010 at 7:12 AM
    Bobo_1
    Bobo
    Maryville, TN
    09 TRD Sport L-Bed
    Clutch pedal free play. Adjusted that and all is good again. Now to sell this thing for new Tacoma parts :D
