Not good. Got the <check engine> + <trac off> warning Codes Added
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Ionnaeus, Oct 9, 2019.
  1. Oct 9, 2019 at 9:55 AM
    Ionnaeus
    Ionnaeus [OP] Well-Known Member
    Jon
    Tennessee
    2016 Quicksand SR5 DCSB
    So I cranked up this lovely Fall morning and lo and behold, I get the Check Engine light plus Trac Off light. So I come here as my think tank for all things Tacoma.
    I read parts of a 54 page thread and my takeaway was - buy a tuner. That was on Gen 2 Tacos and different engines
    Anyone solve this problem?
    Solved without buying something other than a parts replacement?
    Don’t let me down Tacomaholics.
  2. Oct 9, 2019 at 9:57 AM
    Dor
    Dor Well-Known Member
    James
    '18 MB ACLB TRD-OR
    You should probably start by pulling the code to see what the deal is, imo. Can go from there on diagnosis.
  3. Oct 9, 2019 at 10:02 AM
    Technique
    Technique Well-Known Member
    Alex
    Utah
    2017 Silver Offroad DCSB
    -285/70/17 Toyo AT3 -Tuned
    Yeah, see what the code is...maybe something as simple as your gas tank lid not on...
  4. Oct 9, 2019 at 11:00 AM
    jake72
    jake72 Well-Known Member
    Jake
    N.E. PA
    2019 trd off-road dcsb mt
    Sounds like crank position sensor
    shakerhood and Skydvrr like this.
  5. Oct 9, 2019 at 11:12 AM
    Winch
    Winch Well-Known Member
    2019 TRD OR MT V6
    None yet
    On my Solara, the Trac light always came on when I got a CEL. Probably not related to the Trac.
  6. Oct 9, 2019 at 12:11 PM
    Gerbs667
    Gerbs667 Member
    2020 Army Green TRD Pro
    I had my 2016 OR stall and have those lights on, turned out to be crankshaft position sensor like Jake was saying. Mine was one of the ones that there was a recall for that sensor, I just hadn't gotten it done since I was living in Alaska at the time far from a dealership.
    shakerhood likes this.
  7. Oct 9, 2019 at 12:20 PM
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
    yes but... still gotta pull that code first lol
    Junkhead likes this.
  8. Oct 9, 2019 at 1:31 PM
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    My dad has this issue and it was diagnosed as a faulty wheel speed sensor, which also affects ABS. But he lives in San Diego and nearly never drives on loose surfaces, so instead of replacing the sensor, his solution was to put a piece of black tape over the dash lights.
    Hofmann’s Tacos likes this.
  9. Oct 9, 2019 at 3:35 PM
    mpmoody
    mpmoody Active Member
    Goodyear, AZ
    2018 TRD Offroad
    Mine was for three fuel injectors that shit the bed.
    eggs likes this.
  10. Oct 9, 2019 at 3:39 PM
    Hofmann’s Tacos
    Hofmann’s Tacos Professional Asian
    Nor Cal / South FL
    2020 off-road 6MT (SFOB 2.0)
    SFOB 2.0
    Never seen that before... good thing you’re under warranty still!
  11. Oct 9, 2019 at 3:48 PM
    Ionnaeus
    Jon
    Tennessee
    Yep, that's the one. It's went off and on all the way home. I'll try to find what codes it's throwing
  12. Oct 9, 2019 at 4:12 PM
    bluzharp
    bluzharp Well-Known Member
    Central AR
    19 OR DC LB Cement (the slowest color)
    Pro Suspension, Roadmaster overloads, Diamondback
    I got that once. I have a scangauge so I just pulled over and read the code and cleared it. Truck was back to normal and it hasn't popped up again. Love the scangauge.
  13. Oct 9, 2019 at 4:16 PM
    Bishop84
    Bishop84 Well-Known Member
    It's just one code. But manufacturers place backup measures to ensure shady stuff like bulb deletes don't affect the consumers ability to detect faults.
    Old days you could remove the CEL bulb and never see it again. But standards have changed to ensure that cars arent running around with faults undetected, so other modules have to alarm the driver as well.
  14. Oct 9, 2019 at 4:45 PM
    rtzx9r
    rtzx9r Well-Known Member
    Bueller
    2016 TRD Sport
    LS1 swap with nitros.
    Bishop84 and shakerhood like this.
  15. Oct 13, 2019 at 4:27 PM
    Ionnaeus
    Jon
    Tennessee
    Codes are as follows:
    P043E
    P043F
    P2401
    P2402
    P2419
  16. Oct 13, 2019 at 5:56 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    First thing that crossed my mind too.
  17. Oct 13, 2019 at 5:58 PM
    Bishop84
    Charcoal canister failure. You can try to remove it and see if any dirt is clogging it up. These series of codes is common, 99% of the time the canister requires replacement. Its big money, 300$ for a knock off, 800$ for oem.
    Ionnaeus[QUOTED][OP] likes this.
  18. Oct 13, 2019 at 6:02 PM
    OMGitsme
    OMGitsme Well-Known Member
    Sold
  19. Oct 13, 2019 at 6:04 PM
    OMGitsme
    Sold
  20. Oct 13, 2019 at 6:35 PM
    Ionnaeus
    Jon
    Tennessee
    And that's why this place is the best! Thanks fellas. I'll try to troubleshoot next weekend.
