Not Good Vibrations
Discussion in 'General Tacoma Talk' started by D Dawg, May 23, 2024.
  1. May 23, 2024 at 11:59 AM
    D Dawg
    D Dawg [OP] New Member
    2012 Grey Tacoma Rerunner
    Hey all I'm new here. About 3 months ago on my 2012 Prerunner, I had all 3 U joints replaced, as well as the carrier bearing. Also had the drive shaft balanced...twice. This mechanic normally does good work as he did on my 2008 but he was having a tough time in the middle of moving his shop so I gave him the benefit of the doubt.
    Since then I've noticed a vibrating. Pretty sure it's not the tires. I had two of them replaced (by his suggestion) which were plugged previously. All four were balanced. The vibrating seems to happen now when I let off the gas, coasting down the highway at about 40mph the slowest speed which it happens, whereas before it was vibrating when I gassed it. Seems to be a slight jolt when I gas it again this time. Does the whole drive shaft need to be replaced? What do you guys think? Could it be a motor mount?
    Thanks
  2. May 23, 2024 at 12:01 PM
    D Dawg
    Pretty sure it's not the front end either
  3. May 23, 2024 at 12:07 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    Did this start with the work that was done to the Driveshaft?
    michael roberts and D Dawg[OP] like this.
  4. May 23, 2024 at 12:11 PM
    D Dawg
    Not long after. Within a few weeks.
  5. May 23, 2024 at 12:38 PM
    HondaGM
    James
    South-Pole, Alabama
    2023 access cab V6
    Been under it and looked at the driveshaft..any play?
  6. May 23, 2024 at 1:35 PM
    HondaGM
    James
    South-Pole, Alabama
    2023 access cab V6
  7. May 23, 2024 at 4:44 PM
    Shelf Life
    Shelf Life Well-Known Member
    Rob
    Central Oregon
    '06 ACC CAB 4x4 TRD OFF ROAD
    Are the tires you replaced the same tread pattern as the other two?
